Old 25th May 2007, 17:37   #1
romyeo4u's Avatar
Thanked: 13 Times
Default JBLY'fed SANTRO
Hey Guys at last
PIMP MY ICE or JBLY'fed SANTRO
here goes the pictures.
THE MAN
The MACHINE
The ICE
Amp:
JBL GTO 607
JBL GTO 937
JBL GTO 4-12 the SUB
romyeo4u is offline   Reply With Quote
Old 25th May 2007, 17:41   #2
romyeo4u's Avatar
Thanked: 13 Times
The Sub
The Sub
The Sub Box
Sub Installation
the sub install
Old 25th May 2007, 17:44   #3
romyeo4u's Avatar
Thanked: 13 Times
The 607 component
The 607
After the install
GTO 607 - Installed
The Sound machine
GTO 937 on a wooden plank
Old 25th May 2007, 17:45   #4
moralfibre's Avatar
Thanked: 6,149 Times
romyeo4u,
Nice install. Congratulations. What cables did you use? How much did the entire setup cost?
I liked the way the components are mounted! Neat work.
Old 25th May 2007, 17:46   #5
romyeo4u's Avatar
Thanked: 13 Times
From Rear
Old 25th May 2007, 17:48   #6
romyeo4u's Avatar
Thanked: 13 Times
Other Products worth capturing..
wish my bank balance was high :
Infinity SUB ( Worth a Pic)
JBL 1204 Sub
Old 25th May 2007, 17:49   #7
Thanked: 294 Times
nice tweeter location......but take care of them when you open the door when it is raining outside....
Also you have post several pic twice in the above post.....check it and edit you post accordingly....
Old 25th May 2007, 17:51   #8
Thanked: 11 Times
Nice Install.. Congrates..
Mugen_Power is offline   Reply With Quote
Old 25th May 2007, 17:52   #9
romyeo4u's Avatar
Thanked: 13 Times
Here's the config Team:
Pio 5990 IB
JBL GTO 607c - Front 6500/-
JBL GTO 937 - Rear 4950/-
JBL GTO 4-12 - SUB 4990/-
JBL GTO 75.4 - Amp 12990/-
Wiring Monster 2490/-
Wooden Plank 850/-
Wooden Ported Box 1600/-
Installation 1100/-
Damping needs to be done ... gonna do it next week
RCA
Old 25th May 2007, 17:55   #10
Sam Kapasi's Avatar
Thanked: 1,453 Times
Originally Posted by romyeo4u View Post
Wooden Sealed Box 1600/-
Looks like you have a Ported box to me, not sealed. Did they make it according to the sheet provided in the woofer?
It all looks good to me
Now tell us how it sounds to you.
Old 25th May 2007, 18:00   #11
romyeo4u's Avatar
Thanked: 13 Times
ooops Typo.
Yea
Sounds Excellent !!!
sometimes bass is more , when i lower the volume i wanted to listen to the lyrics of the song than the music
maybe tuning is required.
here's the tuning details.
PIO 5990
Audio Subwoofer 80 +4
HPF 80
Audio Bassbooster +2
SLA +4
FADER 0
Audio EQ High +5
Loudness Mid
Audio Sub Normal
any suggestions
Old 25th May 2007, 18:02   #12
Thanked: 294 Times
Hmmm it is a ported one with a 8-10 inch long sewer pipe to make the port....but the look box has a estimate volume of 1.2 cuft...need the exact dimmension of the same....also it is a wedge type not a fully cuboid type....
Old 25th May 2007, 18:05   #13
Sam Kapasi's Avatar
Audio Subwoofer 80 +4 This is a matter of choice, 80hz is ok, increase and decrease to taste
HPF 80 yes, this is fine
Audio Bassbooster +2 I don't think you need to use this
SLA +4 Just raises the pre out volume. No difference other than that
FADER 0
Audio EQ High +5 ooohhh, bring it down, bring it down
Loudness Mid If you like, or off. never more than that.
Old 25th May 2007, 18:06   #14
Thanked: 294 Times
HPF 80
SLA +4
FADER 0
Audio EQ High +5
Loudness Mid
Audio Sub Normal
any suggestions
audio subwoofer 80 is fine but why +4
hpf 80 is ok
audio bass booster +2 (reduce it to zero)
sla ( source level adjuster) it does not alter the sound it is like a gain thing to adjust between different sources of the HU like tuner , aux so keep it at zero
fader is ok
high eq +5 you will get irritated very fast when you keep the setup at such high treble setting....reduce it when you feel it is ok
loudness mid is a bit on the higher side try it with off or low setting (I would preffer off)
audio sub normal it is like switching the phase of the sub....there is a thread on the same...read it...
Old 25th May 2007, 18:18   #15
navin's Avatar
Thanked: 3,885 Times
Actually it does look like a ported box (the white tube is seen) but they might have covered the port. Actually that seems like a nice idea. if you want to ported turn the box so the tube faces up, if you want it sealed turn the box so that the tube faces the floor (like this install).
A lemon, my defective Maruti Kizashi. EDIT: Fed up & SOLD rockporiom Technical Stuff 180 17th August 2014 14:40
Fed up of Cheating / Short fueling by Petrol Pumps? Look here dadu Street Experiences 57 11th February 2014 16:46
FED-UP motorist gifts his Porsche to Shooting Club Sarvodaya The International Automotive Scene 13 24th June 2011 21:53
Fed up and considering alternative career? WindRide Shifting gears 74 22nd May 2010 16:28
HONDA CITY-Got fed up? Surprise Shifting gears 3 25th February 2005 10:17
