Old 31st May 2007, 10:13   #16
navin's Avatar
Thanked: 4,282 Times
Originally Posted by austere_sly View Post
Navin ji, a little OT here. I am not sure whether i am right or wrong, but shouldn't 'prescribe' be used here instead of 'subscribe'. Or is it something to with American / British english difference.
BTW what is epoxy cement ? Is it normal cement , white cement or some other special cement ?
CD players are fragile equipment and i guess CD will be more prone to scratches if the ride is very rough. If you are looking to buy a mp3 player, why not get a flash based mp3 player and connect it to aux in. No jhanjhat related to HU now.
prescribe is more proper as we on TBHP stick to Queen's English. Sorry.
Araldite is a commonly available epoxy cement
Many CD players have a buffer memory so that could help.
Old 31st May 2007, 10:27   #17
Thanked: 294 Times
Araldite (or fevitite) is a type of epoxy cement......One more thing cement does not mean solid in raw shape it can be in viscous liquid shape also....
Ya now days pen drives has changed quite a lot of things.....
Old 31st May 2007, 10:39   #18
tsk1979's Avatar
Thanked: 16,420 Times
How about using a rubber washer. I have seen that in heavy vibrating machinery many screws use rubber washers, and it ensures that the screws don't come loose.
Old 31st May 2007, 11:09   #19
Thanked: 294 Times
rubber washer is good but the quality of rubber which is required as rubber will detoriate with time and this type of rubber will not be avalable easily it is better to use spring washer which will keep the screw tight and it will not unscrew....
Spring Washers
Old 1st June 2007, 05:54   #20
mithun's Avatar
Thanked: 58 Times
I've also seen some ICE Installers covering some sort of M-Seal like substance on all the screws.
Old 1st June 2007, 08:26   #21
condor's Avatar
Thanked: 4,895 Times
May not be that much of a problem in this specific case since the washers will be inside the car, and not much exposed to the elements, esp moisture.
Old 1st June 2007, 10:05   #22
navin's Avatar
Hey if you are doing that why not consider a lock nut.
Old 1st June 2007, 10:24   #23
Thanked: 294 Times
one would not get good quality rubber washers....they will get hard or crack even when installed inside the car cabin....
Cheap "do-it-all" car for rough use The Iceman What Car? 81 28th May 2014 11:47
Which Special Needs car in India? For the disabled? Steeroid The Indian Car Scene 19 7th December 2012 12:28
Special needs. Linea vs. Aveo vs. Fiesta devarshi84 Sedans 31 4th March 2009 12:48
