Old 4th May 2011, 13:02   #61
condor's Avatar
Thanked: 4,907 Times
Default Re: Glass Antenna - Is it effective ?
Originally Posted by DCEite View Post
Even the Indica has it. But at the front.
Indica has a small internal antenna, that is not on integrated on the glass/windshield.
Old 4th May 2011, 19:46   #62
mercedised's Avatar
Thanked: 177 Times
Originally Posted by DerAlte View Post
Strange. Is it the thin wire type stuck to glass (like the rear glass heater) or is the small antenna with 2 prongs sticking out just behind the RVM? Only cyano-acrylate glue ('Superglue' etc.) will stick reliably to glass. If it is the prong antenna, you can also do a jugaad by using a bent stiff copper or aluminium wire to hold it to the roof lining.
Yes, it is of the tyoe found in Indica's, the 'small antenna with 2 prongs sticking out'. Are they available outside? what is the alternative cure? Help please.
Old 5th May 2011, 15:55   #63
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by mercedised View Post
... Are they available outside? ...
Errr... may I ask how bad a shape is it in? Unless one has done desi kushti with it, it is always reusable.
Try this:
* Clean the windscreen inside part (where it was stuck before) with spirit
* Stick one side of a large piece of double-sided tape to the antenna body
* Make sure the connecting wire is connected properly to the antenna
* Stick the other side of the DS tape in the place it was stuck earlier
DerAlte is offline   (1) Thanks Reply With Quote
Old 6th May 2011, 21:40   #64
AbiS's Avatar
Thanked: 7 Times
Default Internal Car Antenna
I do not have an external antenna installed in my car. I am searching for antenna for my Linea but teh dealer says No stock and in outside also its not available. I have asked the dealer to order it for me couple of time but no result. So I am planning for an internal antenna.
Has anyone installed an internal antenna ? I know they fit it behind the rear view mirror. But my questions are:
1) Does the sound quality good in internal antenna?
2) I heard they use a wire to plug it into the system. Does that wire visible to outside and does that create any problem in viewing ?
3) Is there any good brand available ?
4) What is the price and any recommended store in pune ?
Thanks a lot in advance !!!
Last edited by AbiS : 6th May 2011 at 22:08. Reason: Please use Search before opening a new thread. Thanks
AbiS is offline   Reply With Quote
Old 6th May 2011, 23:26   #65
DerAlte's Avatar
1. Depends on signal strength, generally they are good
2. It is run inside the edge of the roof lining, down the A-pillar on the left side and into the center console cavity - not visible at all, nor does it obstruct vision
3. Never heard of any recognizable brand in such antennas
Old 6th May 2011, 23:45   #66
Thanked: 9 Times
good discussion... just one thing to add.. the shark fin antenna and the short-rod antenna usually have some small electronics attached with the antenna (the piece of wire). The electronics amplifies the signal before passing it onto the HU. The effect is that the HU sees increased signal strength.
How is this better than a simple dipole? Nothing in terms of reception at the antenna but much better at the HU as the signal losses when transmitting the signal from the antenna to the HU are compensated by the amplification.
And yes, some shark fins and the short rods also contain AM/FM antenna. They work on a 1/4-wavelength or sometimes even shorter principle
bzr77k is offline   Reply With Quote
Power Antenna vivaid In-Car Entertainment 21 5th January 2014 08:58
XYG Glass or Saint Gobain glass HappyRoadie Technical Stuff 10 2nd June 2011 19:50
Someone Broke my Radio Antenna! amit The Indian Car Scene 7 15th October 2004 21:48
