Old 10th February 2009, 13:41   #16
chiragh_bir's Avatar
Thanked: 70 Times
Originally Posted by DerAlte View Post
Compo = COMPOnents, i.e. separate mid-bass + tweeters (2-way, most common) or mid-bass + mid-range + tweeters (3-way; don't go there - way to complex to implement);
For example:
2-way: Blaupunkt THc 172, Hertz ESK 165, Infinity 6020cs, JBL GTO 607 or CS2165c
3-way: Blaupunkt Vc172
vc 172 are 2 way component speakers not 3 way ..1 midbass + Tweeter
3 way components is GZ 2165t 2 mid bass + 1 tweeter
equaliser is present in both
the best value for money HU is 5090 with B&w for 7000/- may be less now
chiragh_bir is offline   Reply With Quote
Old 12th February 2009, 00:19   #17
Originally Posted by DjNik View Post
Plz post full details of your ICE for us to help you better.
well I have a 4 channel alpine amp( dont know the model number but it says V12 )
pioneer 306c sub (boxed with a glass cover)
4 stock speakers which say max 40w and which I intend to change if needed
2 stock tweeters
a stock kenwood 4070 2din hu which also i intend to change
my total budget is around 15k.. i need a clear sound with good bass.
manujkansal is offline   Reply With Quote
Old 12th February 2009, 12:09   #18
DjNik's Avatar
I hope tht your AMP is orignal and not a desi rip off.
Besides that get components infront-JBL/Blau/Illusion/Hertz.-5-7k
Get Rear oval speakers-JBL/Illusion-4k
Put the sub in a calculated sealed box if not already.
Make sure Good quality RCA has been used, if not change.
HU-Pio/Kenwood-6k upward, with three pre outs.
DjNik is offline   Reply With Quote
Old 12th February 2009, 14:43   #19
yeah the amp is original . and I am planning to change the front speakers with JBL comp 608C and the HU to pioneer 6050 2din. will that be fine or do I really need to changer the rear ovals ?
Old 12th February 2009, 19:09   #20
DjNik's Avatar
It would certainly be better to change the rears as the stock speakers aren't any good, but the final take is yours.
Old 12th February 2009, 19:56   #21
The Amp is not original. Its a desi rip off.
It has V12 Written on red base with silver or else with any other color. Its not original alpine.
You can check from alpine website
Piyush_Vroom is offline   Reply With Quote
Old 13th February 2009, 00:19   #22
k I'll check but for now leave the amp aside and just tell me about the other configuration ? should I go for the components in front or some good ovals in tha back . I can just afford any one of them ..
Old 13th February 2009, 09:12   #23
DjNik's Avatar
Go for the components upfront.
Old 13th February 2009, 21:11   #24
Default HU question for new Verna
Keeping the earlier Verna in mind (the one that never came pre-fitted with an MP3 player), I had decided on the Kenwood 6539U; however, the new Verna already comes equipped with a 2 DIN MP3 Player.
A few Qs:
1. Is it possible to connect an iPod to it?
2. Can this pre-fitted MP3 player be taken out and a new HU be fitted without any problems?
3. Is it necessary to get only a 2 DIN HU?
luvjascha is offline   Reply With Quote
Old 15th February 2009, 02:00   #25
A few Qs:
1. yes its possible to connect the iPod to it but you will not get a good sound as only front speakers would work.
2. yes it can be perfectly done . I got mine changed to a pioneer 6050.
3. a 2din would be a better option but you can go for a single din also then you will have to use a plate to cover up the remaining area.
and I would advise you to change the HU if you want a good output.
Old 17th February 2009, 16:08   #26
Default Stock HU with USB/AUX?
How does the iPod connect to the stock HU - via USB or AUX?
Is the new Verna also fitted with Kenwood as the stock HU? It just says '2 DIN MP3 player' on the Verna site; am just curious if it has provisions for USB/AUX, like the stock HU in the old Verna.
BTW, why do just the front speakers work after connecting the iPod?
Old 19th February 2009, 16:49   #27
actually i don't know much about it. I just got the aux wire out .But the system has a male female kind of connection port. I don't know if you are able to understand that.
and the HU in new Verna is also that of Kenwood only without a USB port but it is indeed better than the previous HU in terms of sound output quality
Old 19th February 2009, 17:34   #28
I know that the stock HU in the new Verna is a Kenwood; however, is it the same model (DPX-MP4070) that used to be in the old Verna?
BTW, I never knew that the stock HU (old Verna) had a USB port!
Old 19th February 2009, 19:39   #29
frankmehta's Avatar
Thanked: 2,334 Times
does it??? i thought it only had an aux input!
Old 19th February 2009, 20:10   #30
Got me! I thought the same.
JVC Head Unit Problem. revtech In-Car Entertainment 13 5th October 2015 12:05
reading on head unit amit_sound In-Car Entertainment 5 15th May 2006 12:49
Can it happen?? - Replacing a 2 DIN Head Unit SRK In-Car Entertainment 9 8th May 2006 11:37
Need a DVD head-unit Sahil In-Car Entertainment 1 24th June 2005 13:43
Pioneer 5750 Head Unit neverclever In-Car Entertainment 4 14th June 2005 07:09
