Old 14th June 2007, 16:06   #61
iraghava's Avatar
Thanked: 156 Times
Originally Posted by panky12345 View Post
Eye - opening post.....interesting finding Rags!!
Eh?? Main kahan se aa gaya bhai? Panky apni aankhen check karake aa!!!
Old 15th June 2007, 00:23   #62
gunbir's Avatar
Thanked: 25 Times
I guess Panky figured since you've moved to Mumbai, your given nickname is up for grabs. So he bestowed it upon Raghvinder (LBM).
Old 15th June 2007, 11:15   #63
panky12345's Avatar
Thanked: 151 Times
"Raghvinder = Ragu = Rags" as discussed earlier in the other thread by gurus.
Old 15th June 2007, 12:42   #64
Sam Kapasi's Avatar
Thanked: 1,474 Times
Incorrect Panky. Iraghava is Rags, a nick bestowed upon him by navin. LBM is Ragu, a nickname bestowed upon him by yours truly.
Old 15th June 2007, 14:54   #65
panky12345's Avatar
Thanked: 151 Times
I apologize, great eye opening post by our very own "RAGU".
Old 15th June 2007, 17:04   #66
Thanked: 295 Times
I think it solved now....rags , ragu , ragus....
Old 15th June 2007, 17:05   #67
clipto333's Avatar
Clip, Finolex (and many is not most ISI branded cable is perfectly good). I use Polycab for power becuase I get it for free (yeah I am a cheapskate) and it is just as good as Finolex.
This is DC we are talking about. Any GOOD, WELL SHEATHED, cable of adequate gauge will work fine. Conectors, crimping, distribution block and wiring topology will make more of a difference than cable brands at this level.
Now stop worrying.
navinji, im not at all worried about my choice. i just cant believe i was using the boss cable(it so thin even compare to 8 gauge good quality wire) the boss cables IMO will be good to wire subwoofers lol).
BTW have you heard a company named Ascon? it manufactures terminals etc. im using their terminals for my power cables. the terminal is made of copper with some silver color coating. i could see the copper after scraping off the silver thing. just wanted to ask if they are all right for the job? also rightnow my speaker wires dont have terminals. im planning to install terminals on them. any suggestions, do's and dont's etc?
Originally Posted by Sam Kapasi View Post
Given your system clipto, the L&T 25 sq. mm (4 Gauge) is a good choice. You should be very happy with the performance as you have purchased a good quality cable from India's premier engineering company. I trust L&T to deliver 100% what they have written in the spec sheet.
I can assure you, clipto, that if you change only the power cable from L&T to any brand POWER CABLE, JBL, Monster, Audison, Tsunami,l Scosche which is also 4 gauge (25 sq mm) You will see ZERO change in performance.
I would not however claim the same thing on RCA and speaker wires.
Tool and LBM need more cross sectional diameter than you, for their power cable. Because of their higher current draw. Add another 10 sqmm of cross sectional area and you have 2 gauge. Enough for their applications. LBM has taken it safer and gone thicker than that.
hi,
yes sam bhai, im really happy with the performance of the cables and i think ive made the best choice i could in my budget. like i said in another thread the major problem i was facing was of dimming of lights with bass notes. now after changing the cable(from boss to 16 mm^2 l&t and from 16 to 25mm^2) there has been a tremendous improvement. the problem is negligible now. now im thinkng of upgrading the big 3. what wire size would be optimal? and if could put my 16mm^2 wire in use that would be great(like running it twice).
also please suggest what i should do regarding the rca cables. buying a good quality cable like audison etc would be too easy a job. i would like to diy the cable with good wires and connectors. any suggestions?
i think this is not the appropriate thread for my above queries, so point me in the right direction mods. thanks
cheers
clip
clipto333 is offline   Reply With Quote
Old 18th June 2007, 14:04   #68
navin's Avatar
Thanked: 4,346 Times
clip, the sliver cating is tinnig. as long as the cable is OFC it should be good.
Old 14th February 2008, 18:31   #69
Tool's Avatar
Hello everyone...
My ID MAX is going to arrive any minute now so i thought its time for me to revive this thread as well for all my questions and for updates as well.
Now the box is my main focus of attention.
I want it to be 1.25 -1.30 cubic foot and Sealed. Also am using self tapping screwes and 1 inch thick MDF.
Should i be taking anymore precautions ? and also if there are suggestions please do feel free guru's .
Also what shape of box would be ideal of a esteem ? (Rectangular,Triangular etc.).
Thanks a lot in advance everyone
big big boom!
Tool is offline   Reply With Quote
Old 15th February 2008, 10:59   #70
Thanked: 295 Times
0.75 would be enough. But if you wanna go for 1 inch that is your wish.
Old 15th February 2008, 11:31   #71
Tool's Avatar
ok sir lbm.. .75 inch it is.. i like a lighter car and also its easier on my back too
hehehe heavy cases are back breakers.
Any other suggestions bro ?
how would a 1.3 cubic foot box sound ?
sorry for all the questions bro.
Thank you very much in advance too
Old 15th February 2008, 13:15   #72
Bass&Trouble's Avatar
Thanked: 74 Times
Construct the enclosure with a few non-parallel sides, and use bracing. 0.75" is the least thickness you can use. If possible, use 1" MDF for the front baffle.
Old 15th February 2008, 13:45   #73
Thanked: 295 Times
When I made my first enclosure for the max it was sealed with a internal of 1.1-1.2 cu ft. Dont remember exactly but it was sound good but the low end was quite less since the volume was quite less. Go for at least 1.3-1.4 cuft to make the max sing. Also I have also asked gunbir about the size of the enclosure used in your pajero. I am also going to make a new box for max to see how it play in the best recommend size. Will post the details after reviewing it.
Old 15th February 2008, 19:28   #74
Is it there already?
cyneverdie is offline   Reply With Quote
Old 15th February 2008, 19:34   #75
Tool's Avatar
Its here !!!
My ID MAX is here !!
im soo happy now . THANK YOU GUNBIR AND JB
this means a lot to me bro's
Cant believe its in my hands wooo hooooooo.
Also have got Sonus Main power 4 guage power cables for my amps power.
They were running on old 4 guage wires so far. Had only upgraded my main power wire to 2 guage and was waiting to do this for a while now.
Have got the diagrams for a 1.3 cubic foot enclosure from gunbir sirji .
Using 1 inch thick MDF for the Front and .75 inch thick for everywhere else.
Thakn you again everyone !!!
posting pictures soon
WOO HOOO!!!!
Transition underway from 2 to 4 wheels? - not sure! bigvishnu Introduce yourself 2 13th August 2011 07:21
'59 CJ3B with XDP 4.90: Mechanical lessons underway - Phase 1 Red Liner 4x4 Vehicles 10 7th January 2010 08:56
Audison Lrx 2.4, Connection options? CaliforniaKnight In-Car Entertainment 9 15th October 2009 18:34
wanted used hertz energy series speakers sanchits Shifting gears 0 2nd November 2007 22:18
Does a stinger / chamber increase performance? rankoz350 Motorbikes 18 8th March 2006 07:27
