Old 13th August 2007, 17:34   #16
Thanked: 294 Times
Sam Bhai and Navin Ji. I think he will not be running ICE directly from the power supply. I think he will be running it in the car and will be add it there. If there will be a battery in the car he would not be needing a 50 amps power supply as the music is not continuous sine wave consuming 100 power. I think adding a 10 amps power supply in parallel to the battery will do a fine JOB.
Old 13th August 2007, 18:04   #17
Awaiting Email Confirmation
Would that be cheaper? I mean, significantly cheaper?
vidvai is offline   Reply With Quote
Old 13th August 2007, 20:54   #18
Sam Kapasi's Avatar
Thanked: 1,452 Times
I fully understand this LBM. But when the drain is greater than the charge, for how long will the battery last?
Agreed with a 10A supply, the battery will last significantly longer. But surely his drain will be more than 20A?
He wants to have a party, without starting his car. The party will not last more than a couple of hours.
The ONLY way for him to run it indefinitely is to connect a power supply that is greater than his drain. Remember the battery does not generate current, so it can only deplete.
The only time the battery will charge, is when his drain is lower than the charge.
Old 14th August 2007, 00:01   #19
Thanked: 294 Times
I agree with Sam Bhai here fully 100 %
Strange Rule-Can't buy a C segment car if you done have any of A or B segment girlieonwheels Indian Car Loans & Insurance 40 22nd August 2008 17:56
Free service can be done at any dealer service station? dsinz Indian Car Dealerships 8 15th September 2006 11:55
What Mods can be done on this car? sambhav Modifications & Accessories 1 16th March 2006 20:13
Camry What Can Be Done! vishnugnair Modifications & Accessories 15 12th March 2005 02:51
