Old 23rd June 2007, 22:41   #46
flipsyde's Avatar
Thanked: 62 Times
yeah it sounds more like a whine..... this is very clearly audible when the volume on the HU is left at 0 and the engine is revved. i will check the power cable thingy.
also....the rear ovals are hardly audible....probably because it is running directly off the HU but still is there a way to make them more audible?
flipsyde is offline   Reply With Quote
Old 24th June 2007, 13:08   #47
DerAlte's Avatar
Thanked: 2,879 Times
Your setup need tuning, so that the front and rear are balanced.
The gurus can suggest a better method, but here's a simple version:
1. Set your amp gain to mininum, and set Fader to 0
2. Bring up the HU volume till the rears sound nice
3. Increase the gain of the amp for the front till both sound kinda same level
4. Use the Fader in the HU to check if the levels sound OK when faded totally Rear or Front; if not adjust gain till you are able to fine tune that
5. Check if the levels are close when you play at low, medium or high volume on the HU
But, first check if the Fader is set to Front already; if so, set it to 0 and check if everything is OK before doing the above
Old 24th June 2007, 13:51   #48
flipsyde's Avatar
Thanked: 62 Times
thanks a lot DerAlte! will try it tonight and let you know the result
Big Boy Toyz opens new showroom in Gurgaon GTO Super-Cars & Imports in India 52 30th May 2017 22:56
Boy oh boy! I'm so excited to be here Obi-Wan Introduce yourself 3 15th January 2016 15:41
Hyosung GT250R: Big Boy Launched @ 2.75 Lakh parrys Motorbikes 50 30th November 2015 15:05
Wonder why the big multi-axles are big killers? ph03n!x Commercial Vehicles 8 6th May 2011 09:44
A big big "Hi!" from Chity Bang chity_bang Introduce yourself 5 25th June 2007 23:26
