Old 20th June 2007, 13:07   #31
Thanked: 294 Times
or you can put them here...
Old 20th June 2007, 13:16   #32
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by Bass&Trouble View Post
Butter Chicken without any butter, eh?
No no, butter yes, chillies/spices no!
Reminds me of my experience at a Macdonalds in Singapore:
"Gimme a burger without the burger" (wife's a vegetarian)
"Huh, whaa? Baagaa, no baagaa???" (baagaa: burger in Singlish)
1 + (-1) = 0, right? That's what the poor guy had understood.
Old 20th June 2007, 13:41   #33
hydrashok's Avatar
Originally Posted by rocksterraghu View Post
Where do you think is a good place to install it? I was thinking of the door panels, but the tweeters get really close to the ears. Do you think it would be OK to install them on the dash?
Installing them on the dash just at the point where the A-pillar meets the dash should be good. Or you can try the lower-most point of the A pillars.
You may-not be able to screw them down, and will have to use double-sided tape. Be careful of not getting them knocked off their position when you give the car for servicing.
Installing them in the door panels has the advantage that the wiring is less messy. The whole unit will be within the doors itself, without a wire needing to go to the dash. But then you can always see how it goes with the dash install and shift them later if you feel like.
EDIT: Since you don't like it too bright, I think l_b_m's pic shows a pretty good (and simple) option too.
And guys, guys, puhleeze
Old 20th June 2007, 18:03   #34
I had asked this before also, can't tweeters be flush mounted either in A-pillar or the panel behind mirrors? Will the space available be sufficient to do that (with an average sized tweeter)?
santosh.s is offline   Reply With Quote
Old 20th June 2007, 18:09   #35
Thanked: 294 Times
ya it can be done...but it will depend on the car also...
size of the tweeter...
Old 20th June 2007, 18:12   #36
I was asking for baleno itself...
Old 20th June 2007, 18:20   #37
Thanked: 294 Times
any pic of a-piller of the same....
Old 20th June 2007, 18:53   #38
panky12345's Avatar
Thanked: 149 Times
LBM, any good option of putting tweeters in my Indica somewhere, without much hassels.... poor been hanging around with a wire since the day of install.
Old 20th June 2007, 19:08   #39
Sorry, I don't have any picture of my car! Will take a snap for this purpose.
Old 20th June 2007, 19:09   #40
Thanked: 294 Times
you were coming to Faridabad...what happened to that..If you come we can personally discuss and then post it on the forum.
Old 20th June 2007, 19:14   #41
panky12345's Avatar
Thanked: 149 Times
thanks LBM, would visit shortly bro!!
Old 20th June 2007, 19:19   #42
Sam Kapasi's Avatar
Thanked: 1,473 Times
Raghu, it is refreshing to see someone that does not like highs so much. This is precisely why your head unit has a treble control. Go minus if you like, my friend,
But install the tweeters.
Old 20th June 2007, 20:40   #43
Thanked: 83 Times
OT: Sam has now officially taken up the title of 'Lord of the Yetis'
SumitB is offline   Reply With Quote
Old 21st June 2007, 01:08   #44
razor4077's Avatar
Thanked: 258 Times
You should install the tweets too. You can control the level of highs by cutting them at the crossover (there will be a -3 setting). Without the tweets, you won't get good imaging up front. I think the 937s also have a push switch that you can use to cut the high-frequency response.
How exactly do I choose a "-3 setting"? Is there a switch on the crossover or do I need to open it up? And does this reduce the brightness of the tweets appreciably?
razor4077 is offline   Reply With Quote
Old 21st June 2007, 01:40   #45
Sam Kapasi's Avatar
Yes. All thanks to you. I have.
Razor, there's a jumper in the crossover. 0 and +3.
JBLyfied i10 with Alpine + Stinger maverick236 In-Car Entertainment 21 6th April 2008 14:26
City ICE Upgrade – from Xplodyfied to JBLyfied mphsranes In-Car Entertainment 23 25th October 2007 09:21
Blueraven's magic with the JBLyfied Baleno rocksterraghu In-Car Entertainment 29 4th October 2007 11:53
Baleno BS-III to Baleno BS-II BlackBull Technical Stuff 0 22nd September 2006 21:50
