Old 21st June 2007, 01:44   #46
razor4077's Avatar
Thanked: 258 Times
Hello Your Lordship!
So when Hydra said '-3' did he actually mean '0'?
0 = less treble
+3 = more treble.... right?
What's the default factory setting?
razor4077 is offline   Reply With Quote
Old 21st June 2007, 01:55   #47
Sam Kapasi's Avatar
Thanked: 1,473 Times
Default is umm 0. I think. Or is it, lol.
Yes +3 is more treble.
Last edited by Sam Kapasi : 21st June 2007 at 01:57. Reason: cos I'm a forgetful pottyhead
Old 21st June 2007, 05:42   #48
Awaiting Email Confirmation
Hi rocksterraghu could u please tell me the total cost of ur system with each component u've installed...
Nos007 is offline   Reply With Quote
Old 21st June 2007, 08:46   #49
hydrashok's Avatar
Originally Posted by Sam Kapasi View Post
Razor, there's a jumper in the crossover. 0 and +3.
0 = less treble
Only a "0" & "-3"? I was under the impression there was a "-3", "0" & "+3" setting. My mistake
Yep, by "-3" I meant less treble.
Old 21st June 2007, 08:47   #50
Here are a few snaps (of baleno's A-pillars/mirror panels)
santosh.s is offline   Reply With Quote
Old 21st June 2007, 09:17   #51
Raghu, GTO-607C's in the front door are 6-1/2", right? Did you need any cutting or spacers etc. to accommodate them in stock locations?
Old 21st June 2007, 10:36   #52
Thanked: 294 Times
it is very difficult to flush mount one there...I would prefer the door instead....
Old 21st June 2007, 11:18   #53
Thanks for the comment, LBM bro. The depth of mirror panel as measured from window glass is about 1.5". How much does a typical tweeter need?
Old 21st June 2007, 12:02   #54
navin's Avatar
Thanked: 4,286 Times
what about the mirror pod.Sam, I think had posted a series of photos detailing how to do this (or was that you or Gunbir?).
Old 21st June 2007, 12:28   #55
I think you are referring to this thread, I have read that. It is not about flush mounting, it is some complicated way to hide surface mounted tweeter, if I got it right.
http://www.team-bhp.com/forum/diy-do...-tweeters.html
Old 21st June 2007, 12:30   #56
Sam Kapasi's Avatar
It was me. And it's not THAT complicated *injured look* lol
Old 21st June 2007, 12:54   #57
Thanked: 294 Times
I did not get that part but if you made a sketch then it will help a lot...
About the Sam Bhai mounting technique it is a good way for mounting the tweeter I think you should give it a try....and it is not at all difficult....
Old 21st June 2007, 13:33   #58
I said complicated by the standard of people who want to keep changes/interference in stock parts to a bare minimum, unless it is a must Regarding 1.5", it should be clear in this picture:
Old 21st June 2007, 13:55   #59
Thanked: 294 Times
tweeter can be installed here easily...try removing it and see the space behind it...also the surface is flat there or not.....a little work will need to be done to make it flat so that the tweeter is mounted with its face matching the base.
Old 21st June 2007, 14:35   #60
I am refraining from that because I don't know locations of screws and plastic locks (whatever applicable), where all to press/pull to open! Being a car's interior, they have done a good job to hide ugly screws etc, and I am afraid brute forcing may cause (quite expensive!) damage Do you know any pointers where such apparently trivial, but important details can be found?
the triangular surface is pretty flat except near the vertical edge (bend), and I think the flat area is more than enough for typical tweeters. I was not sure about the depth only (1.5"), but you seem to say that it is sufficient too (provided the space behind happens to be empty!).
JBLyfied i10 with Alpine + Stinger maverick236 In-Car Entertainment 21 6th April 2008 14:26
City ICE Upgrade – from Xplodyfied to JBLyfied mphsranes In-Car Entertainment 23 25th October 2007 09:21
Blueraven's magic with the JBLyfied Baleno rocksterraghu In-Car Entertainment 29 4th October 2007 11:53
Baleno BS-III to Baleno BS-II BlackBull Technical Stuff 0 22nd September 2006 21:50
