Old 2nd September 2007, 10:10   #16
Hi gurus!
I'm back after a long long time. (Was short on moolah, so wasn't too active on ICE-ing the car, but now things have changed! )
I'm confused on what size of co-axials, the stock locations in the front door of the car can accomodate? Also, if I go for components, what size should I get installed?
I wouldnt want to rip off the door and/ or make the speakers look prominently visible.
Posting pics here to show the dims. of my speaker's stock locations.
ImageShack - Hosting :: scanimage1369qu5.jpg
ImageShack - Hosting :: scanimage1368xy3.jpg
I need your opinions on that!
Also, isn't getting the speakers installed in the doors risky?
Why I ask is.. In the rains if you open car doors, the speakers will get drenched, right? Also, I remember reading somwhere in the forum, that the water that seeps in from under the glass in the doors will go be collected inside the doors. This water has to be removed manually by unplugging a plug under the door. Won't this collected water spoil the speakers?
- EMD
EatMyDust is offline   Reply With Quote
Old 2nd September 2007, 11:26   #17
navin's Avatar
Thanked: 4,350 Times
Originally Posted by EatMyDust View Post
Hi gurus!
looks like 5" woofers will fit without modification and mabe even a 6" woofer will fit in that location. I thought the Aveo has stock tweeter pods but if it does not maybe it can be flush mounted on the door itself or on the A pillar.
most car speakers are built to withstand a bit of humidity but not a drenching. Unless your car gets flooded I dont think a drenching is really what they'll be subjected to anyway.
navin is online now   Reply With Quote
Old 2nd September 2007, 11:43   #18
hey thanks Navin for answering!
I'm planning to demo out the Illusion electra series, probably by the end of Sept. when B&T drops into bangy.
Reg. protecting speakers from moisture and humdity - I have read somewhere that "baffling" OR using "baffles" can avoid this.
Is this recommended? OR its implied that all installers use baffles? If not, maybe I should insist on installing baffles also.
Whats your opinion?
Which is better Getz Prime 1.3 or Aveo UVA amdefacto Hatchbacks 46 14th July 2010 00:57
What do you think of the Aveo UVA prabuddhadg Test-Drives & Initial Ownership Reports 2 16th March 2007 20:41
help buying audio kit for aveo-uva eo777777 In-Car Entertainment 12 10th February 2007 00:37
Optra, Aveo-UVA, Matiz OEM Service Manuals online! IMP Technical Stuff 0 23rd January 2007 22:54
GM to launch Aveo-UVA with 1.2 Ltr motor..launch by Nov/Dec'06 ashutoshb The Indian Car Scene 5 12th September 2006 03:36
