Old 21st June 2007, 14:39   #1
abhishek_rait's Avatar
Thanked: 7 Times
Default Upgrade of ICE on my baleno
hi guys ,
i want to upgrade my ice help needed of course .
currently i have a kenwoood cd player HU
front speakers are O.G. kenwood
rear are Oval's which are JBL cascade speakers .
i dont have much of boot space as i have gas installed on my machine.
what i have thought about is
1. TWO JBL amplifiers (1. 4 channel 2. channel ) pls help me with that
2. coaxial speakers from MOREL if that can fit or a component from JBL
3. A base tube again from JBL .
i dont have the model numbers that would be of gr8 help if u could tell me that with there prices
4. and a good set of power and audio cables (very important)
i simply love JBL becoz i have used them before here in India and Germany.
Are Bang and Olufsen products for car are available here in India . if Yes where can i listen to them here .
i normally listen to DOORS, pink flyod , a little of trance (electric).
Pls suggest guys . u r the supreme sound masters here !!!
abhishek_rait is offline   Reply With Quote
Old 21st June 2007, 16:28   #2
cooldude1988765's Avatar
Thanked: 108 Times
Could you provide your budget and are you sure there is enough space for a bass tube after installing gas ???
cooldude1988765 is offline   Reply With Quote
Old 21st June 2007, 16:32   #3
BUSA's Avatar
A good 4 channel amplifier from JBL is the 75.4 costs around 12k, also there is the 60.4 for 8k if you intend to use all of them for the speakers, 2 channel amplifier would be the 60.2 but if you intend to power the subs then better to go in for a monoamp like the 300.1(300Watts RMS) for 12k or 600.1(600 Watts RMS) for 20k or the GTO 1201.1(1200Watts RMS) for 32k
A good set of Compos from JBL are the GTO 607c which retails for 6.5k
The CS1204T is a good bass tube with peak power of 1000W costs 6.5k
All prices B&W
Old 21st June 2007, 19:51   #4
hydrashok's Avatar
There's a nice Baleno thread (All JBL) here: http://www.team-bhp.com/forum/sound-...ed-baleno.html
There are more Baleno specific threads (I remember 2 older threads) in the ICE section someplace
Old 22nd June 2007, 12:21   #5
navin's Avatar
Thanked: 4,265 Times
1. Why Morel? Have you heard them? Compared them to Hertz, Infinity, Focal, DLS, or Rainbow?
2. JBL 60.4 and 300.1 will cost you 20K and I think this is the cheapest JBL 4+mono combo going. Why are you considering a 2 ch. amp?
3. Why tube? I would suggest you hear the tube and the box and then decide.
Old 22nd June 2007, 13:06   #6
IronWolf's Avatar
Thanked: 36 Times
I am also looking to ICE my Baleno.. dont need something super loud.. just loud and clear for music like Pink Floyd, Led Zep, Deep Purple etc...
Meaning not too bassy, more on treble, mid range and clarity
Suggestions?
IronWolf is offline   Reply With Quote
Old 22nd June 2007, 14:55   #7
Thanked: 7 Times
* i have actually heard morel coax sounds good on mid bass frequencies. but not heard other ones so will do that asap
* 2 ch amp i was considering to power my rear speakers so that i can set them to my wish and the other 4.chn for the base tube and probably the front speakers (pls. help me out )
* tube i was considering that i dont have enough boot space now . but i can surely keep a box ( again would be glad for ur help).
Old 1st September 2007, 10:15   #8
Thanked: 7 Times
hi again good to be back on t-bhp . i am now considering to put components on my car . pls suggest .
the components which i found was infinity - rs 6000
and to power the comp and the rear speakers (jbl cascade series) inherited from my old car :- blaupunkt mxII series four channel amp for rs :- 6400
is this good? or should i search for better options
i currently have kenwood cd as my H.U ,kenwood normal speakers at the front O.E. from maruti suzuuki, JBL cascade as my Rear Speaker . JBL 2 chn Amp and a A jbl base tube . the amp is only powerin the Base tube . JBl wiring for the system .
Another Query :-
Since i got the base tube in my car the rear speakers have no treble . i.e nothing at all . i am unable to locate the problem . PLS help on this and suggestions for the components would be welcomed heartedly
Old 1st September 2007, 13:32   #9
Thanked: 43 Times
Another Query :-
Though not a guru, I had this problem recently, so may have a solution. The amp feeding the rears may have been set to filter out the highs (low pass filter). Check the switch, if there is one, that says HPF/LPF/FLAT. Set it to FLAT.
My installer had set the switch to HPF and I was getting only treble!
filcord is offline   Reply With Quote
Old 1st September 2007, 16:27   #10
rocksterraghu's Avatar
Thanked: 88 Times
It is a good decision to retain the co-axials. In the same price range for components, you may also try other brands like Hertz (DSK), JBL (GTO), Blau, Illusion, etc. Do listen to them before finalizing.
For the amplifier, you may also try the JBL 60.4, Pioneer (Forgot the Model no.).
About the 'no treble' problem, is it that you don't hear any treble in the front or no treble even when you listen with your ears close to the speakers?
Fil, his co-axials are not powered by any amplifier
Old 2nd September 2007, 01:35   #11
navin's Avatar
[quote=abhishek_rait;476041
* tube i was considering that i dont have enough boot space now . but i can surely keep a box ( again would be glad for ur help).[/QUOTE]
a dedicated mono amp is much nicer for the sub.
a tube and a box can occupy the same space. in fact if made custom, a box can be made to fit into a nook of the car's trunk and actually make more space available for other stuff.
Old 2nd September 2007, 21:00   #12
Thanked: 43 Times
Oops, Not only am I not a guru, also not a good reader!
Old 2nd September 2007, 22:50   #13
Thanked: 7 Times
there is very little treble from the rear speakers rock ,also i m not using coax in the fronts as they got spoilt the bloody guy i dont know how he managed to spoil them . thats why i am looking for a descent components . the four channel amp will only be powering the components and the rear speakers .
do u guys think that i should go with this kind of installaion . or u guys suggest . i am open to all valuable inserts .
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Partial ICE upgrade of Baleno OEM setup shuvc In-Car Entertainment 117 23rd September 2009 14:05
ICE upgrade for my recently brought baleno Mr_Bean In-Car Entertainment 5 22nd September 2009 15:22
ICE upgrade for Baleno...... BWN In-Car Entertainment 10 1st January 2008 09:09
ICE upgrade for an '06 Baleno Vxi ron_9191 In-Car Entertainment 3 15th October 2007 21:38
