Old 3rd July 2007, 11:22   #1
Thanked: 20 Times
Default How effective is sound deadening material in tackling rattling ?
Rattling is a problem faced by many car owners. It is a thing which recurs. Will using sound deadening material be useful in curbing the menace? If possible how can it be used, like placing in panels,beadings,rubber and metal parts etc. Try to post some firsthand experience or even hearsay .
swathyd is offline   Reply With Quote
Old 3rd July 2007, 12:14   #2
Thad E Ginathom's Avatar
Thanked: 8,376 Times
rattling means something's loose.
Surely the only cure for that is finding it and stopping it rattling.
Sound deadening would seem to be a good idea against inevitable noise --- engine, road, wind etc.
Can't see the point of it for 'optional' noises.
Old 3rd July 2007, 16:09   #3
Thanked: 20 Times
I have heard people applying it for managing common ratttling.
Old 3rd July 2007, 16:19   #4
It's like allopathic versus ayurvedic/homeopathic treatment
santosh.s is offline   Reply With Quote
Old 3rd July 2007, 16:21   #5
CrAzY dRiVeR's Avatar
Thanked: 19,804 Times
know any places in trivandrum where its done properly?
I'd like to get rid of the tyre noise and engine noise too (if its possible)
Old 3rd July 2007, 16:31   #6
Thanked: 20 Times
Emperor cochin do this job. But not sure on rattling which i mentioned.
Old 3rd July 2007, 18:44   #7
DerAlte's Avatar
Thanked: 2,879 Times
How very perceptive, Santosh!
What @swathyd, or whoever told that, observed was an after-effect: in dismantling and applying sound insulation or damping sheets, the rattle-and-buss-removal would be incidental benefit if the person doing it has 'touched' each and every part without skipping anything.
The rattles & buzzes (different frequencies, that's all) are all about ill-fitting components and cables hitting against metal or FRP/ABS sheet areas. If you put dampening material, the noise of hitting reduces (gets damped out). Also, whatever was unduly loose gets tightened without making much ado. End-result: reduction in noise, which is what was desired.
Engine, tyre and road noise is another ball game. These are the root causes of the rattles and buzzes, but removing them is neither easy nor cheap. It is cheaper to apply damping sheets and tie-strips.
Old 3rd July 2007, 21:52   #8
navin's Avatar
Thanked: 4,282 Times
For the most of us all we can do is probably add a layer of damping to the floor baord from the fire wall to the rear seat and some underbody damping spray. Even this is will make a small difference moticeable below 60kmph. As one goes faster wind noise etc.. will take over.
Old 3rd July 2007, 21:57   #9
Thanked: 294 Times
there all lots of noises in the car which will take a lots of effort to eliminate them and it depends what is causing the noise.
Old 3rd July 2007, 22:58   #10
theMAG's Avatar
Thanked: 1,572 Times
Sound deadening materials work best in absorbing resonance and resultant vibrations along with external sound. Rattling is best fixed at its source
Old 16th March 2008, 00:54   #11
razor4077's Avatar
Thanked: 258 Times
Identifying the source can be a real pain in the behind.
Has anyone got a rattling dashboard fixed? In my Lancer's case, the sounds vary from rattling in various parts to squeaks and creaks from the A/C vents and the plastic trims. What would be a solution to this? The noise really gets to me sometimes.
razor4077 is offline   Reply With Quote
Old 17th March 2008, 09:11   #12
BHAGWAN's Avatar
Thanked: 13 Times
Talking Car Noise - Floor etc.
If you need to get rid of floor noise - car - i.e. You may post the querry in the car section - not in ICE.
All said, for Floor noise - wuerth makes great products. You may go on line and research it from their web site. It is sold in India.
However, for audio purposes - damping material too is essential. Specially in SPL installs.
The only drawback is the 'weight' it adds to the car.
Sprays are easy to use - however - not effective in my opinion. They are only good to reach places where the hand cannot install.
Application process too is important. Needs to be done - slowly & correctly.
I suggest you listen to a car with it & one without it & you will know what I am suggesting. The difference is too much not to nitice.
However, if you have a 'rattle' in your car from somthing that is 'loose' then fit that [fix] independently.
BHAGWAN is offline   Reply With Quote
Old 17th March 2008, 09:24   #13
hellstar's Avatar
Thanked: 17 Times
I have noticed that my under body treatment from 3M whiich leaves the underbody of the car covered with some rubber like substance considerable reduces the noise level in the cabin
hellstar is offline   Reply With Quote
Old 17th March 2008, 13:18   #14
dinu2506's Avatar
Thanked: 349 Times
When I did the damping for my ICE, I noticed that tyre noise was getting filtered to an extent.
dinu2506 is offline   Reply With Quote
Old 17th March 2008, 16:26   #15
abhibh's Avatar
Thanked: 34 Times
Well i have tried sponge and it works upto some extent to reduce rattles and boot noises.
Tried the sponge in Zen boot and it does the damping job for 1 306 DVC.
The Damping Material and Sound Deadener Thread kb100 In-Car Entertainment 1176 18th July 2018 20:05
Sound deadening for old-school Jeeps ringoism 4x4 Vehicles 15 8th September 2012 15:45
BMW 635d - Sound deadening ( Dyna-matting ) and new sub-woofer and amp. g8128 In-Car Entertainment 8 18th July 2010 18:08
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
Sound deadening materials! Harrie Modifications & Accessories 19 22nd May 2006 15:20
