Old 7th July 2007, 11:21   #31
Sam Kapasi's Avatar
Thanked: 1,472 Times
Simply a point of view LBM, there are minor differences in perception and in points of view. Read in detail and you will understand.
We are no longer giving an answer, we're having a discussion in detail. Some of my points and Der Alte's points differ slightly. It's nice to do that. That's all.
Old 7th July 2007, 16:13   #32
Thanked: 294 Times
I thought that all the above discussion were similar..thats all..no problems...
Old 10th July 2007, 06:44   #33
mithun's Avatar
Thanked: 57 Times
Will any damage happens to the electrical system/Music system if I crank the car with the HU ON (in a normal setup w/o any Subs/Amplis) ?
Old 10th July 2007, 07:04   #34
manikjeet's Avatar
Thanked: 109 Times
i was told by my installer that its better to switch of the hu before starting the car
it increase the life of the hu
manikjeet is offline   Reply With Quote
Old 10th July 2007, 10:57   #35
Sam Kapasi's Avatar
No. That is what this discussion is about. Your car puts off the HU, cranks and then switches it back on, so no harm is done.
Old 10th July 2007, 11:56   #36
tsk1979's Avatar
Thanked: 16,015 Times
I don't know if I am right, but I have seen my HU condition at startup tells me whether the battery is charged.
When the OEM battery was about to fail(it was actually an alternator failure) the HU started turning off at startup.
When the alternator got fixed and HU would keep running at startup.
then the Panasonic battery got one cell bad, and thats when the HU started this again. The HU was the indication which prompted me to put a multimeter to the terminals. This time one cell had gone bad.
Then I got Amaron, and HU did not turn off. Again same thing happened, and this time it was an alternator regulator.
Now the HU does not turn off while crank, and I can be sure that the battery is getting charged and is doing fine.
Old 10th July 2007, 12:00   #37
gopinathann's Avatar
Thanked: 20 Times
It is a new feature available in most of the recent models in order to prevent electrical damage to the compnents. In my santro also this happens. Once I gave my bike for a small repair in the night. Once the repair was done the guy told to switch off the head light and start the bike. I asked him why ? He told sometimes the headlight may go off when you start the engine with the head light on. Because of the same reason all the cars disconnect the electrical components during the engine start.
gopinathann is offline   Reply With Quote
Old 10th July 2007, 12:20   #38
Sam Kapasi's Avatar
Tsk, in your case, I can safely assume that your car does not have an auto-cutoff for the HU.
This means that your HU is physically going off when the voltage drops below it's tolerance.
Our previous discussion was regarding cars that actually cut off the accessory supply at the time of cranking. It has nothing to do with the condition of the battery, it is an electrical design. I suspect you don't have this feature in your car.
When your battery is healthy, the voltage stays within the tolerance of the HU and it does not shut off. But I suspect there is still a drop (completely normal)
If I was you, I'd power down the HU before I started my car.
Old 10th July 2007, 13:31   #39
tsk1979's Avatar
Ok, I guess it makes more sense to have HU cutoff and it will prevent damage.
If a car does not have this mechanism, is it possible to have it done while install process. Some king of circuit which will cut off voltage to HU/AMP while crank?
The strange Santro issue - switches off after 2kms supremeBaleno Technical Stuff 23 19th May 2018 15:42
Suzuki issues 2 million car recall globally for smoking / burning ignition switches Tushar The International Automotive Scene 0 23rd April 2015 12:09
Air Recirculator intermittently switches off in Polo TDI layndrivr Technical Stuff 4 19th May 2011 18:53
petrol smell coming during ignition in getz sathya_j2084 Technical Stuff 30 24th April 2011 21:51
Please help ---Esteem suddenly switches off kris Technical Stuff 9 17th July 2008 22:44
