Old 27th July 2007, 10:40   #16
Thanked: 294 Times
Originally Posted by NOTORIOUS View Post
i can format my pen drive to ntfs. there is no bounding in windows that you cant formay your thumb drive to ntfs. if you want it, i can do it for you
Which version of windows do you have. Are you using windows default formating tools or any third part software.
Old 27th July 2007, 11:42   #17
devarshi84's Avatar
Thanked: 118 Times
slightly oftopic, I am getting this HU for 5500 brand new. Is it worth the price?
How is the sound quality?
devarshi84 is offline   Reply With Quote
Old 27th July 2007, 11:54   #18
Thanked: 294 Times
Which one is it.
The pioneer 7950 is for 9k in grey which has a USB support.
Old 27th July 2007, 12:15   #19
devarshi84's Avatar
Thanked: 118 Times
the scorpio HU. I dont know the brand but the dealer said its kenwood nippon unit made for Mahindra scorpios. I saw the unit but the brand wasnt mentioned on it.
Also how is Sony MEX BT-2500 and how much should I pay for it in Grey?
the problem with 7950 is that it doesnt fall in my budget really. This HU is for the WagonR which doesnt run much. I may consider it for my lancer though which I am looking to get updated in the next 3 months. I am looking to spend 6K most for this HU for wagonR.
Old 27th July 2007, 12:16   #20
easyrider's Avatar
Default HU is ok, not that great.
As I just got the car recently, did not listen to ICE so much. However the Nippon HU with OEM speakers just sounds very lost even after increasing the volume to very high. Today I turned on 'loud' on HU, it sounds better now.
Cool thing about HU is the option of multiple sources like CD,FM,USB(pendrive) and SD card.
I tried SD Card and that worked too!. Will have to check if I can connect a MP3 player.
easyrider is offline   Reply With Quote
Old 27th July 2007, 12:25   #21
Thanked: 294 Times
The scorpio HU is not worth the 5k price IMHO.
Do not know the sony HU price.
Old 27th July 2007, 14:33   #22
rocksterraghu's Avatar
Thanked: 65 Times
Notorious, I know that removing the 'optimize for perormance' feature in the device manager lets you format it in NTFS. I can also think of a couple of tweaks that can get you through. But flash drives are meant for performance and it would be silly to have write caching enabled by removing the optimization. I was just talking about things in the 'default' perspective.
Old 13th August 2008, 18:40   #23
Roshun's Avatar
Thanked: 24 Times
Default Scorpio Nippon unit not playing USB
My Scorpio's Nippon head unit stopped playing music from pen drives recently.
When I plug in the pen drive, the USB indicator blinks for a few moments and then hangs. I can't switch the unit off as well until I pull out the pen drive.
I was using a Sony 512 MB pen drive initially, which played well. But in between, I had stopped using it for a few months (as I had other data on it).
Then I tried a Kingston 4GB and the problem showed up. I then tried the old Sony, but it refused to play that as well. I tried two other pen drives - same problem. I figure it's a problem with the head unit. Either the USB port (plug) is tarnished or the system has conked off.
The Nippon system has always been very sensitive. It sometimes refuses to play MP3 CDs at the first go. I have to eject it and reinsert it for it to play. It's out of warranty now - but does anyone have Nippon's number? Or should I ask M&M for it.
Most of the time it's only the radio and a couple of MP3 CDs played on it.
Roshun is offline   Reply With Quote
All about USB Flash Drives a.k.a Pen Drive / Thumb Drive / Memory Stick / Jump Drive KSM-Vtec Gadgets, Computers & Software 1 28th February 2012 12:04
800 bucks USB Pen Drive only HU with no CD & no casette kittigadu In-Car Entertainment 88 4th February 2011 13:27
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
How to connect USB pen drive to AUX port? forbhaskarm In-Car Entertainment 4 15th December 2008 12:06
USB Pen Drive speeds and HU vebmetal In-Car Entertainment 76 15th October 2008 23:27
