Old 21st December 2008, 18:49   #31
navin's Avatar
Thanked: 4,286 Times
Originally Posted by FourWheelDrift View Post
So here's my pitch to you guys : what can I do to get a bit more bass, without permanently losing space in the luggage compartment ?
simplest solution is a removeable boxed sub using a Neutrik Speakon connector.
navin is online now   Reply With Quote
Old 21st December 2008, 18:59   #32
abhinav.gupta88's Avatar
Thanked: 310 Times
Rightly said
Get a good VFM sub like Ground Zero ( 5-6k)and a 4 channel amp like JBL ( 10k approx)
and if on a budget, get a GZ ( 5-6k) and a Kenwood 8401 ( 5k approx)
Old 25th December 2008, 20:18   #33
FourWheelDrift's Avatar
Thanked: 198 Times
Thanks for your responses, Navin and Abhinav.
Navin (and any other Guru in Mumbai), could you please recommend a retail outlet in South Mumbai, where I might obtain the equipment you speak of ?
Ground Zero's distributor in India seems to be :
India
Name: Adress: Contact: Hermit Audio Pvt. Ltd. #8-12, 9/D, Parel Cotton Press Compound,
Elphinstone Bridge Road, Parel (E)
Mumbai – 400019
INDIA Phone:
+91-22-2470-4048
Fax:
+91-22-3021-9099 info@hermitaudio.com
Will call them tomorrow to obtain locations where their SWs are retailed.
With regard to the amp : where could I see a JBL amp and the Kenwood 8401 drive the GZ SW side by side ? I understand that there are several persons on our board who are ... ummm ... opposed to the Kenwood 8401 - and I would like to hear for myself, before taking a call.
From JBL India's website, for car audio, this is the official outlet :
Mumbai Union Auto Industries C-106 Vaibhav Industrial Estate, Opp Oxford Chamber, Saki-Vihar Road, Andheri (E)-72 9820050919/ 9320029418
Any idea about a similar place in South Mumbai ?
Last question : is there ANY reasonably priced SW, that has an in-built amp which will connect to my set-up ? Considering I am perfectly happy with the output (loudness) of my present set-up (with the exception of bass, of course) - am I correct in assuming that the amp being suggested by you will ONLY drive the SW ? If not, please let me know what should drive what i.e. how the system should be hooked up. If so, if the amp and SW were co-located AND portable, I could disconnect them when I need the extra space in the luggage area.
Sorry to be troubling you guys ... as is evident, I am a green-behind-the-ears-noob.
Cheers,
FourWheelDrift
FourWheelDrift is online now   Reply With Quote
Old 25th December 2008, 20:32   #34
Thanked: 310 Times
Hermit audio is run by our member Bass&Trouble. Catch him. he does the installs too.
Contact him. he will be able to solve all the problems as well as do the install.
Old 25th December 2008, 22:08   #35
navin's Avatar
For JBL try Sahil International, somewhere behind Naaz cimena on Lamingotn Road.
You can get a good 12" and a 150W monoblock for less than comparable a sub-amp combo. A good 12"+ amp will run you about 16K.
Old 28th December 2008, 01:38   #36
Thanked: 198 Times
Hello Navin,
Thanks for your reponse.
As I'm already 16k in the hole with my recently acquired set-up (on account of paying MSRP, as I wanted B&W), I'm really not inclined to put another 16k into the car ... and that for a little more bass.
Is there no reasonably priced SW+amp 2-in-1 combo (say <=6k installed), that would cut it ? Recall that I'm happy with the SQ of the current system ... just don't have bass that's all.
Cheers,
FourWheelDrift
P.S. Abhinav : am trying to make contact with B&T, but he'll be back on Monday, I think.
Old 15th April 2009, 15:10   #37
wanderernomad's Avatar
Thanked: 806 Times
Gurus here is a poser. I already have a JVC DVD player installed in my marina. The speakers are in stock location with JBL compos upfront with the dash location having the tweeters. Rear stock location between the B and C pillars house 4" speakers. Now I want to add two 6X9's in the hatch. It has space to house the speakers and all that is required is a wooden plank to fit in place of the cardboard the hatch has presently.
I will run these two speakers with a JVC cassette player which is being installed separately in the space under the steering column. It fits in snugly. Now my question is if I add an amplifier as per original plan to run the compos and the 6X9 through the amp while the 4" would be run through the HU (DVD player), can I put in place a switch so that the amp can be fed from both the HU's depending on which HU is up and running?
I had tried to piggyvback the CP to the DVD Hu but it didnot work out. Or am I better off runiing only the 6X9 through the CP HU and keep the amp for running the compos through the DVD HU?
Thanks.
wanderernomad is offline   Reply With Quote
Old 15th April 2009, 15:17   #38
greenhorn's Avatar
Thanked: 1,519 Times
why a Casette deck in this day and age? why not a walkman ?
you sure you cant connect the casette deck to the DVD player ( latter has no aux in?)
can you specify what you mean by "not work out"
greenhorn is online now   Reply With Quote
Old 16th April 2009, 11:34   #39
Thanked: 806 Times
Yeah though aux in option was not tried but connecting the two HUs the speakers are going dead. Hence it was suggested to run the cassette deck as a separate entity with a separate set of speakers. Cassette deck simply because I have some fantastic collection on tape and I am too lazy to go and get them burned onto a CD. Plus I got this Cassette HU lying with me. And another thing I want to have all options available.
I really hope that I can get that switch thing installed to alternate the speaker input from one of the two HUs.
Old 17th April 2009, 11:34   #40
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by wanderernomad View Post
Yeah though aux in option was not tried but connecting the two HUs the speakers are going dead. Hence it was suggested to run the cassette deck as a separate entity with a separate set of speakers. ...
Errr... How exactly did you connect the two HU's together?
No, you don't need to wire the 2 HUs as 2 different systems with their own speakers.
You have not mentioned any makes / models, so we can only speculate. Assuming that the DVD HU has an AUX-IN, and the Cassette HU has a Pre-out (very few HUs, if any, don't), you only have to do the following:
* Connect the Pre-out of the Cassette HU to the Aux-In of the DVD HU (you may need converter connectors, apart from RCA cables)
* Keep the speakers connected to the DVD HU
* Switch the DVD HU to Aux-in for playback (check the manual)
* Set the Cassette HU volume to play at a moderate volume (about 1/3 of the max possible)
* Play your cassette tape in the Cassette HU (adjust volume only at the DVD HU)
Old 20th April 2009, 14:09   #41
Thanked: 806 Times
The DVD HU is JVC KD DV6200 and it has an AUX IN. The cassette player HU is also JVC unit from a Chrysler Jeep so not sure about the model though. Incase I can connect the two from where do I get the connectors from? And what do I say what kind of connectors do I want?Any shop/installer in Delhi any one of you can recommend for the job?
Old 20th April 2009, 14:14   #42
greenhorn's Avatar
given the details you have suggested, the easiest option would be
Cassette Player -> Line out/Pre out ( if it exists) or Speaker output -> Line level convertor to the aux in of the DVD HU
Old 20th April 2009, 14:20   #43
Thanked: 806 Times
Do we get this line level converter off the shelf in car audio accessories shops? And it will be then just a mere joining of these wires? Sorry but am completely at sea with these setups.
Old 20th April 2009, 14:30   #44
greenhorn's Avatar
its a box which takes in the speaker outputs from the HU as input , and gives out Line level output
looks like
see if you have a pre out in the cassette player. chances are that it will
Old 20th April 2009, 16:51   #45
Thanked: 806 Times
Hmm how much does it cost? Ill go and check the thing out this weekend at Karol Bagh. I should just go and ask for a line level connector right? Ill also take this picture as a ready reference.
@greenhorn: Thanks mate. Would appreciate any other info that you can give me.
Problem with ICE in Indigo Marina prakashchopper In-Car Entertainment 7 11th May 2007 21:44
Indigo LX or Indigo Marina LX windsurfer Sedans 10 23rd January 2007 14:03
Indigo Marina ICE Upgrade ritayan In-Car Entertainment 1 18th August 2006 12:26
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
Tata Indigo Marina! Reborn Estate??? v12 The Indian Car Scene 10 23rd March 2004 19:47
