Old 21st April 2009, 17:14   #61
greenhorn's Avatar
Thanked: 1,312 Times
that is what navin has suggested. I'm not sure how amps handle simultaneous inputs through the speaker and line level
greenhorn is online now   Reply With Quote
Old 22nd April 2009, 09:10   #62
wanderernomad's Avatar
Thanked: 785 Times
@Navin, could you please elaborate on your suggestions and in simple english please !! Will also appreciate a pointer to someone in Delhi in case you know of someone who can help me in this.
wanderernomad is offline   Reply With Quote
Old 28th April 2009, 17:18   #63
Thanked: 785 Times
Guys I had got the JBL CS2165c installed. Now yesterday I was asked about the location of the small "dibbi" of the compos. Now I am unable to find it. Does this model come with that small rectangular bit of equipment. Is it called as a crossover or relay? If yes then where can I look for it as it does not seem to be installed where I can see even after searching for it.
Old 28th April 2009, 17:47   #64
greenhorn's Avatar
yes, all compos come with the crossover.
Your installer probably hid it. In a rare case of the lazy installer , he might not have used it at all !
Old 28th April 2009, 18:07   #65
Thanked: 785 Times
Should I drive across to Elegant and demand that he installs one now?
Old 28th April 2009, 18:10   #66
karankapoor's Avatar
not used it not possible, why will he not use it.
i don't no whether this model comes with a proper xover or a small box type xover, but if this is a compo then there will be some type of xover, search it the installer must have hidden it somewhere.
karankapoor is offline   Reply With Quote
Old 28th April 2009, 18:24   #67
Thanked: 785 Times
Ok but the ICE installer I had been to did make a search but could not locate it. Maybe I can go and ask Elegant where did he hide them? And if he also doesnt locate them, can i ask him to put one now. Will he be able to put the correct JBL crossovers now?
Old 28th April 2009, 18:33   #68
you should go to elegant (is it lajpat nagar one) and ask him where are the xover, and if he says he had not installed them ask him, why ?.
if he had done some thing like that, he wont will be able to put the correct xover back.
Old 28th April 2009, 18:34   #69
hydrashok's Avatar
@wanderernomad, the CS2165c has inline filters. It does not have a separate crossover 'dabba'. So the installer hasn't fooled you, don't worry
Old 28th April 2009, 18:49   #70
greenhorn's Avatar
just checked the manual. there is no seperate crossover. typed the earlier post in a hurry with the UPS threatening to die out on me. should have done my research
PS: i have seen some local component installs without the crossover.
Old 29th April 2009, 09:10   #71
Thanked: 785 Times
He he Thank you guys I am so relieved. Now I can spare my back from all that bending and twisting under the dash.
Old 29th April 2009, 09:42   #72
navin's Avatar
Thanked: 3,880 Times
Some components have no LPF for the woofer and just a single cap for the tweeter that is fixed close to the tweeter.
Old 13th January 2010, 17:29   #73
Thanked: 785 Times
Is it good or bad, that is not having a separate crossover? Meanwhile I have added a Pio 4 channel amp to power the front compos. rear 4" derive from the HU only as before.
Old 13th January 2010, 18:49   #74
greenhorn's Avatar
nope, having a seperate crossover is just a matter of choice/convenience/bling.
as long as the power of the amp<=the rated RMS power of the speaker, you should be okay
Old 14th January 2010, 13:08   #75
navin's Avatar
will the amp mix the signals from the line level and speaker level ins together ?
It is not advisable to use both the speaker level and line level inputs at the same time.
Problem with ICE in Indigo Marina prakashchopper In-Car Entertainment 7 11th May 2007 21:44
Indigo LX or Indigo Marina LX windsurfer Sedans 10 23rd January 2007 14:03
Indigo Marina ICE Upgrade ritayan In-Car Entertainment 1 18th August 2006 12:26
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
Tata Indigo Marina! Reborn Estate??? v12 The Indian Car Scene 10 23rd March 2004 19:47
