Old 3rd August 2007, 11:19   #1
Praneet71's Avatar
Default Audio Gurus: Help Needed
Guys, i have just moved from Pune to Delhi. My zen met with an accident during transit. Though the car had no major damage there is a problem with the audio setup. There is a constant hissing noise in the speakers and the noise level increases with increase in acceleration.
Is there someone in Noida/ Delhi who can help? What could be the reason for the same?
Appreciate your help
Praneet71 is offline   Reply With Quote
Old 3rd August 2007, 11:36   #2
navin's Avatar
Thanked: 4,284 Times
do you have an amp? if so check the RCA wires from the HU to the amp.
Old 3rd August 2007, 12:45   #3
Praneet71's Avatar
Yes it does have an amp and the RCA wires have been checked. No problems with that
Old 3rd August 2007, 13:58   #4
navin's Avatar
ask your insallter to try another set of RCA cables and to keep RCA cables away from the ppower cables.
also check all terminals in case there is a short. the symptoms are not that of a short but given that the car just had an accident it is nicer to check.
Old 3rd August 2007, 14:04   #5
Praneet71's Avatar
Thanks Navin but as i mentioned the system was installed in Pune and am wondering who can help me with this in Noida/Delhi. As the car is here with me.
Old 3rd August 2007, 16:02   #6
Thanked: 294 Times
You can go to a good installer in your area and he can correct the problem. Which area of delhi or noida you put up.
Old 3rd August 2007, 16:15   #7
Praneet71's Avatar
I am in Noida sector 48. Went to Sector 16 the other day and there are quite a few accessories shops there but wasnt too sure of their competence thus decided against showing it to anyone there.
Old 3rd August 2007, 17:11   #8
Thanked: 294 Times
Try PM aza on the forum he knows quite good installer in Noida which can take care of your problem.
Old 3rd August 2007, 17:25   #9
Praneet71's Avatar
Thanks low bass maker - will do so.
Incase there is anyone else who can recommend any good installer do let me know.
Old 6th August 2007, 22:29   #10
Praneet71's Avatar
Hi Guys no help from anyone. Delhi members can anyone help??
Old 7th August 2007, 00:34   #11
Thanked: 294 Times
Drop down to FBD maybe I can help you with the same.. My local install can take care of this problem.
Old 7th August 2007, 00:58   #12
Zappo's Avatar
Thanked: 2,080 Times
Bah! What a thread heading. I was wondering since when did our audio gurus started calling for help.
Navin, I think that heading is a bit misleading.
Zappo is offline   Reply With Quote
Old 7th August 2007, 11:04   #13
Thanked: 294 Times
Yaar...I meant that If I am not around the installer in my town can help in rectifying the problem.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13667 19th July 2018 16:52
Ice Setup Zen Ė Audio Gurus plz help nicejits In-Car Entertainment 14 20th September 2007 15:45
Help needed from Bike Gurus ... meerkat Motorbikes 6 31st August 2006 16:34
A request to all the audio gurus .. Can this be repaired ?? mclaren1885 In-Car Entertainment 38 13th July 2006 13:21
