Closed Thread
Old 4th August 2007, 20:10   #31
kb100's Avatar
GOOD GAWD !!!
All THAT equipment ... with THAT HU ????
Grrrrrrrrrrrrrrrrrrrrrrr.......... Cant wait to get my car back!
Excvellent install as usual!!
Gunman.... on the 1 ohm thingy... these are SVC's right?... if so dont we need one more sub to get 1 ohm?? (I am going by the "they will see half" theory)
kb100 is offline
Old 4th August 2007, 20:44   #32
Autophile's Avatar
Originally Posted by hydrashok View Post
The new LRx 4channels let you give more power to the fronts even at 4ohms front and back huh? I didn't know. That's really nice. Lots of configs possible too! Mmmmmmmmmm...
So how did you guys feed the speakers? 4ohms + 4ohms itself, with 140x2 to the front and 130x2 to the back?
More upgrades/expansions? What else is left?????
Like sk456, I was also wondering at the choice of HU. The owner didn't want an IVA200? Or is it that the owner wanted the VDP, and the VDP needs a Pio front-end?
The LRx 4.1K is used with 140W X 2 powering the fronts and 130W X 2 powering the rears.
The subs wired in parallel presents 1.333 Ohms final impedance to LRx 1.1K.
Autophile is offline
Old 4th August 2007, 22:47   #33
horsepower's Avatar
The Pioneer Unit is giving much better look then the OEM. Great Install Gunbir,JB. When are we getting to hear the system?
horsepower is offline
Old 4th August 2007, 23:30   #34
DerAlte's Avatar
Thanked: 2,879 Times
Gunbir (et al): Awesome! Phweeee-phweeeiooo! 7.0 on JBGMPI scale?
Though by itself the black piano finish is superb, the color does not fit in well with the interiors; it is a bit discordant. But, gore gore mukhde pe kala sa til!!!
I think now the owner of this beauty need enter his house for biological needs only.
DerAlte is offline
Old 5th August 2007, 00:07   #35
navin's Avatar
Thanked: 4,286 Times
Originally Posted by clipto333 View Post
Navinji, what did you mean by the 12mm thing?
when the plate to cover the wiring is installed it comes close to the cone of the 12" woofers. I would just like to give the woofers a bit of room. I am conservative so I figured 12mm would not make a difference to the owner of the car and would mean that the woofer's cone was completely free of any interference.
navin is offline
Old 5th August 2007, 00:31   #36
Thanked: 21 Times
Red face
Look carefully, for God is in the details...
There is over an inch of clearance in front of the subs...
What you are missing out on... is the fact that the entire roof of the car is (now) finished in black, so when you look at the interiors, the Honda Beige & Black theme is followed through.
gunbir is offline
Old 5th August 2007, 00:55   #37
Thanked: 294 Times
Originally Posted by gunbir View Post
Kyon ki "Do se bhaley Teen" They look cool, and they are 4ohm SVC, so the net load on the mono is 1ohm, deriving most output from the mono amp.
As you wrote it is 1 ohm load on the amp but it is actually 1.3333333 ohms
LBM, the three subs are wired so... why is it so difficult to comprehend?
But after that you corrected it yourself.
low_bass_makker is offline
Old 5th August 2007, 01:04   #38
Thanked: 21 Times
LBM, whenever you post a speakers impedance do you state the exact (down to 7 decimals) measurement? No, you don't. So why the compulsive nitpicking here?
Actually, I'm quite sure you were confused about the wiring and made a mistake in assuming I was wrong. Once you figured you were wrong, you put up the above post because you don't want to admit you made a mistake.
And thats fine with me. Good Night.
gunbir is offline
Old 5th August 2007, 01:22   #39
Thanked: 294 Times
I think if we wire 3 subs of 4 ohms svc then the final result will be 1.3333333333333( as the result will be going on we can round off it to 1.34)
But since you mentioned 1 ohms I though you missed the .3 some where.
I did not expected this from you my friend, anyways....
Old 5th August 2007, 01:24   #40
razor4077's Avatar
Thanked: 258 Times
Awesome install. Very neat indeed!
Quick question: how much would one of those MDF floor-boards cost? Say for a Lancer's boot?
razor4077 is offline
Old 5th August 2007, 01:50   #41
IronWolf's Avatar
Thanked: 36 Times
Gunbir, I dont know much about such detailed installs.. however thats are really professional Install. Super job.
I would bring my car to your garage.. If I were in delhi. Got any branches in Bangy?
IronWolf is offline
Old 5th August 2007, 09:35   #42
navin's Avatar
it was this pic that made it look like the top plate could interfere with the free flow of bass from the sub.
LBM, 1.34ohms = 1ohm beside you know quite well that these are NOMINAL impedances. Woofers particularly are quite inductive.
navin is offline
Old 5th August 2007, 09:41   #43
sk456's Avatar
Thanked: 7 Times
it could be the reflection of the glossy black surface which might be making the subs look close to the boards.... although it does look close to the boards here...
sk456 is offline
Old 5th August 2007, 11:41   #44
Autophile's Avatar
If Gunbir missed / did not bother to write 0.3333333333333....ohms does it make any difference to the sound in the car? I believe NO.
Its not necessary that three 4 ohms subwoofers wired in parallel will return you 1.333333333 ohms always, the value can vary from one brand / model to another. Even in this case the impedance of 3 SEAS subs is not 1.33333333 Ohms.
Anyways FYI the amplifiers are tuned according to the final impedance presented to it. Whether it is subwoofers / speakers, each one's impedance was measured using True RMS multimeter which you might notice in the install pics.
Old 5th August 2007, 15:06   #45
anshurao's Avatar
Thanked: 53 Times
Gunbirji you are just awesome... superb. I wish we had someone who could do such a great job here in Goa.
anshurao is offline
Closed Thread
Pics: Monster Jam - Monster Trucks with 1,500 horsepower! Twinn Int'l Motorsport 17 14th April 2015 05:53
Monster Trucks at the Monster Jam 2012 - IZOD Center troublemaker The International Automotive Scene 3 28th November 2012 15:08
Ducati Monster 796 Vs Yamaha FZ1 EDIT - Bought A Red Monster shayne Superbikes & Imports 130 10th February 2012 15:40
2007 Lotus 2-Eleven pawan The International Automotive Scene 5 2nd March 2007 10:51
4way Active with Seas Lotus, DLS, ID, Tru sk456 In-Car Entertainment 6 4th September 2006 15:23
