Closed Thread
Old 13th August 2007, 21:46   #106
Default Tachomete
Originally Posted by gunbir View Post
So the system is fired up...
And thats that. Well, there are a couple of future expansions planned... so stay tuned...
Enjoy!!!
I i too own the same system, could you please let me know how to install the tachometer settings. What do we need to add to control.. I have installed this is in my SWIFT .. A small car with powerful system :-)
Raja_babu is offline
Old 13th August 2007, 23:32   #107
Thanked: 21 Times
Originally Posted by rocksterraghu View Post
I would like to know why the screw mounting looks like this: I know the entire install was done very very professionally and I am just curious whether this is common with custom spacer rings at times. The screws look inclined and it looks like the components do not have enough space for the screws.
Actually Raghu, constructive criticism is always welcome. The fact is that the SEAS Ref midbass was designed as a 7" midbass. Due to the fact that the midbass wouldn't fit stock locations, the folks at SEAS (Scandinavian Electro Acoustic Systems, Norway) shaved off part of the flange (and we ordered these). So if you use countersunk type self tapping screws they tend to look like their are angled. Thats all.
gunbir is offline
Old 14th August 2007, 00:10   #108
Autophile's Avatar
Originally Posted by low_bass_makker View Post
I agree to you Raghu.
Here is a pic of Midbass installed in my car. I use allen bolt of 2.5 inch length with nut not just self tapping screws which get loose after some time.
Wow what an innovation LBM "Allen head bolts & nuts". How did you manage to tight the nuts behind the midbass.
Morever proper self tapping screws will never get loose. I have experience of more than 10 years using self tapping screws and have never experienced a self tapping screw getting loose on its own.
Autophile is offline
Old 14th August 2007, 10:05   #109
navin's Avatar
Thanked: 4,286 Times
Originally Posted by Autophile View Post
Wow what an innovation LBM "Allen head bolts & nuts". How did you manage to tight the nuts behind the midbass..
the midbass is mounted on a spacer.
navin is offline
Old 14th August 2007, 10:30   #110
Thanked: 294 Times
I have used a spanner it looks like this..
or you can use a socket which looks like this..
along with the handle...
and hold the nut from behind and tighten the allen bolt with this..
It is a very simple task..If have trouble doing it come down to FBD I will show you how it is done.
I agree that self tapping screw are a good but till the place holding them is good. As when tighten in a wood I dont see them hold for long. As I tighten the subs self tighting screw quite often which get loose due to normal usage.
low_bass_makker is offline
Old 14th August 2007, 10:33   #111
Thanked: 294 Times
Navin Ji I could not get you here....
Old 14th August 2007, 10:33   #112
panky12345's Avatar
Thanked: 150 Times
Hahahahaha......that was a good one LBM!!
panky12345 is offline
Old 14th August 2007, 10:37   #113
moralfibre's Avatar
Thanked: 6,533 Times
Probably Navinji meant you have screw bolted the midbass on the spacer and then mounted the spacer on the door panel using normal screws.
moralfibre is offline
Old 14th August 2007, 10:43   #114
Sam Kapasi's Avatar
Thanked: 1,473 Times
This would be fine, if the midbass was mounted on the spacer and then the spacer was screwed onto the door panel, but navin, LBM says that his allen bolts and nuts are mounted through the door metal.
After that the allen bolts are used which is passed through the midbass then the wooden ring and finally the door metal frame. when these 4 bolts are tighten they firmly hold the midbass in place and any vibration can allow the speaker to vibrate..
I think LBM, (silly boy mastikhor, posting pictures of spanners) what is being asked here is, how did you get hold of the nut behind the speaker, if it goes through the metal.
By your explanation, it seems that the spacer is mounted first, on the door and then the speaker is bolted on. How would you access the nut on the rear, of the (for example) lowermost corner allen bolt?
Sam Kapasi is offline
Old 14th August 2007, 10:57   #115
Autophile's Avatar
Absolutely right Sam thats what I have asked him. Thanks for simplifying the question for him.
Don't try and teach me with pics of spanners, rachets and allen keys etc. Try and concentrate in answering the question properly which is asked to you. If you cannot, come to Delhi I will teach you how to read and understand English.
Old 14th August 2007, 11:05   #116
navin's Avatar
Since these are DLS, I think Sam is refering to either David (Dawid) Koniarski or Mats Andersen. :-)
I believe Mats is the techie (he was chief techie at QLN) and David manages sales. Atleast at the shows you usually end up talking to David.
navin is offline
Old 14th August 2007, 11:09   #117
navin's Avatar
Chill JB!
navin is offline
Old 14th August 2007, 11:15   #118
Thanked: 294 Times
Sam Bhai there was enough space to hold the nut with the spanner it was not at all difficult. If it was difficult how would I have done it here is a pic which shows there is lot of space...
How come I have posted nearly 3772 post and the medium used here is English.
Old 14th August 2007, 13:02   #119
rocksterraghu's Avatar
Thanked: 98 Times
Thanks for that information, Gunbir. I asked that out of curiosity, I know you would have had ten looks before finalizing something. I respect you a lot, just like everyone around here - in fact, I don't qualify to criticize your work.
That 7" midbass and trimming of flange is very interesting, I'll do some reading about that, thanks again!
rocksterraghu is offline
Old 14th August 2007, 13:53   #120
viper's Avatar
Thanked: 9 Times
Hey,
LBM that pic was really wacky man. On a serious note you and JB need to chill out man.
This is a fun forum so lets keep it light without getting all touchy and personal.
Viper
Off Topic - LBM you mind doing some googling for me and reply to this thread or anyone who can help out.
http://www.team-bhp.com/forum/produc...facturers.html
viper is offline
Closed Thread
Pics: Monster Jam - Monster Trucks with 1,500 horsepower! Twinn Int'l Motorsport 17 14th April 2015 05:53
Monster Trucks at the Monster Jam 2012 - IZOD Center troublemaker The International Automotive Scene 3 28th November 2012 15:08
Ducati Monster 796 Vs Yamaha FZ1 EDIT - Bought A Red Monster shayne Superbikes & Imports 130 10th February 2012 15:40
2007 Lotus 2-Eleven pawan The International Automotive Scene 5 2nd March 2007 10:51
4way Active with Seas Lotus, DLS, ID, Tru sk456 In-Car Entertainment 6 4th September 2006 15:23
