Closed Thread
Old 14th August 2007, 14:51   #121
jkdas's Avatar
Thanked: 1,436 Times
phew! I was gonna post pix of gas cutter
jkdas is offline
Old 14th August 2007, 15:03   #122
nura's Avatar
Originally Posted by Sam Kapasi View Post
How would you access the nut on the rear, of the (for example) lowermost corner allen bolt?
In roadside garages, usually through child-labour. Completely illegal, of course.
nura is offline
Old 14th August 2007, 17:06   #123
clipto333's Avatar
Originally Posted by low_bass_makker View Post
I agree to you Raghu.
Here is a pic of Midbass installed in my car. I use allen bolt of 2.5 inch length with nut not just self tapping screws which get loose after some time.
the black circle shows the screw which is used to just hold the wooden spacer ring on the door frame. After that the allen bolts are used which is passed through the midbass then the wooden ring and finally the door metal frame. when these 4 bolts are tighten they firmly hold the midbass in place and any vibration can allow the speaker to vibrate..
Also these allen bolts have a small head which gets allocated in the midbass nicely..
lbm,
didnt quite understand what you saying. any vibe can allow the speaker to vibrate? what vibrations paaji and why would the speaker vibrate? confusion confusion lol clear it up.
i hate allen nuts. i had a really bad experience when a nut broke while replacing a flat tire. half the nut came out and half got stuck. had to get them out by welding.
no offence
cheers
clip
clipto333 is offline
Old 14th August 2007, 17:53   #124
Thanked: 294 Times
Sir first how does a speaker produce sound. By vibrating na, so when a speaker is producing sound it must be vibrating and it will cause vibrations also the vehicle is driven on the road and there are many potholes on the road which also cause the vibration. Thus every thing is vibrating which can cause screws to get loose...
You hate allen nuts that is ok, but the one I have used are quite soild, they have nearly 3-4 times more tensile strength than a normal Mild steel bolt. I know that this much is not required here but I wanted the best for the install..
Look I have used the allen bolt on the amp rack also..
low_bass_makker is offline
Old 14th August 2007, 18:31   #125
Driven's Avatar
O K,,, thanx for that,,,
I always use to wonder how yours got loose
Driven is offline
Old 14th August 2007, 18:49   #126
Thanked: 17 Times
WoW! What are we speaking about nuts and screws here???
I think this thread has shown it's car, equipment and install in a very nice explaining way.
Why just spoil it with all the unnecessary blah blahs and funny pictures?
speedzak is offline
Old 15th August 2007, 00:09   #127
navin's Avatar
Thanked: 4,286 Times
come on guys! Please chill!
navin is offline
Old 15th August 2007, 00:10   #128
navin's Avatar
LBM, you could have used better wire though.
navin is offline
Old 15th August 2007, 00:57   #129
jkdas's Avatar
the phantom sees it all!
jkdas is offline
Old 15th August 2007, 01:06   #130
Thanked: 294 Times
Navin Ji have changed the wires. This is a old pic. and let us dicuss the same in my own thread.
http://www.team-bhp.com/forum/ask-gu...makker-52.html
Old 15th August 2007, 16:28   #131
shrivz's Avatar
Thanked: 92 Times
@gunbir/autophile: I have a little question here.
What about ventilation for the amps? Is the top cut out big enough to let in a good amount of air for ventilation?
I suppose that the amps would generate a lot of heat when played hard!
shrivz is offline
Old 15th August 2007, 17:09   #132
Thanked: 21 Times
Good question... here's how it works.
gunbir is offline
Old 15th August 2007, 18:02   #133
clipto333's Avatar
oh sirjii, i know how a speaker works. you are talkng about the cone movement but i was referring to the speaker assembly(the whole speaker) vibrating.
(when these 4 bolts are tighten they firmly hold the midbass in place and any vibration can allow the speaker to vibrate..)
dont you think it should be cant instead of can? or am i missing something?
from what i understand, you meant that by tightening the mid bass driver using nuts and bolts the vibes caused by external elements dont have any effect on the driver(the speaker does not vibrate that is)
anyway, lets not go ot now.
cheers
clip
Old 16th August 2007, 01:16   #134
shrivz's Avatar
Thanked: 92 Times
Aah, thats a nice cooling system
but then, dont you think that there should be a provision for another fan to throw in cool air into the box? or have you made holes on the side?
shrivz is offline
Old 16th August 2007, 09:03   #135
Autophile's Avatar
The amplifier rack is not closed. Its open towards the subwoofer box.
Autophile is offline
Closed Thread
Pics: Monster Jam - Monster Trucks with 1,500 horsepower! Twinn Int'l Motorsport 17 14th April 2015 05:53
Monster Trucks at the Monster Jam 2012 - IZOD Center troublemaker The International Automotive Scene 3 28th November 2012 15:08
Ducati Monster 796 Vs Yamaha FZ1 EDIT - Bought A Red Monster shayne Superbikes & Imports 130 10th February 2012 15:40
2007 Lotus 2-Eleven pawan The International Automotive Scene 5 2nd March 2007 10:51
4way Active with Seas Lotus, DLS, ID, Tru sk456 In-Car Entertainment 6 4th September 2006 15:23
