Old 8th August 2007, 09:14   #16
navin's Avatar
Thanked: 4,282 Times
Originally Posted by vkhandelwal View Post
any place between mumbai central to santa cruz. Thanks for the help
Bharat Audio at Worli (near the bridge) and Bhavi Motors at Milan Subway good enough?
Old 9th August 2007, 11:19   #17
vkhandelwal's Avatar
can someone post the prices of amplifiers options available at Mumbai?
vkhandelwal is offline   Reply With Quote
Old 9th August 2007, 11:50   #18
More questions for gurus - I do not plan to add a subwoofer in my car. as informed earlier I have JBL co-AX in rear and COMPO in front. is it good idea to install 4 channel amplifer to drive the front and rear speakers. will this setup improve the sound quality and overall bass from co-ax?
Old 9th August 2007, 13:09   #19
navin's Avatar
amplifier options in mumbai:
Sony, Blaupunkt, Pioneer, JBL, Infinity, Audison, Steg, and a dozen or so more.
Old 9th August 2007, 13:54   #20
ramie2400's Avatar
Thanked: 58 Times
the blaupunkt GTA-4 special is a good option and VFM so do check out with this.
@navin:(Out of Topic) Sir what is the lowest price range for Steg in mumbai??
Cheerz
Old 9th August 2007, 14:10   #21
navin's Avatar
Opera House has a few dealers but dont know any personally. I prefer dealers who have garages large enough to keep my car over night in case the work is not complete in a day.
Old 9th August 2007, 15:48   #22
Thanked: 294 Times
With Steg and audison on a bit expensive side..
the entry level Steg that is the Qmos series
for 20k which can do 45 x 2 or 150 x 1 and 25k for 75 x 2 or 250 x 1
Old 9th August 2007, 16:18   #23
Thanked: 44 Times
The HU itself puts out about 22 W RMS per channel. This may not be enough to drive the speakers loud, and if you crank up the volume it will certainly distort. Hence you need an amplifier, even if you don't blast the speakers, the sound will be much clearer.
filcord is offline   Reply With Quote
Old 9th August 2007, 16:25   #24
Thanked: 294 Times
Originally Posted by filcord View Post
The HU itself puts out about 22 W RMS per channel..
with 5-10 % noise in it.
Old 9th August 2007, 23:07   #25
navin's Avatar
More like 12W rms at < 0.1% THD 20-20kHz. 222W rms might be at 10% THD 1kHz.
Old 10th August 2007, 09:46   #26
Thanked: 44 Times
My Pioneer 4750 user manual says "no more than 5%THD at 22W Rms, 50-15000 Hz"
My question to the Gurus: what levels of Thd are acceptable?
Old 10th August 2007, 09:52   #27
Sam Kapasi's Avatar
Thanked: 1,473 Times
Good (high end) products are measured at 0.01%THD. Sometimes even less.
THD is not acceptable, it is tolerated while making power measurements. The level of tolerance is specified. In the case of tyour HU, while it is giving out 22W power, the THD is 5% (HIGH!) The pioneer too can be measured while it gives out 0.1% THD (for example, like navin says) but expect it to give out 10-12W rms at this point. No more.
Old 10th August 2007, 10:29   #28
Thanked: 294 Times
If you want to go louder then go for a AMP. Like Jbl 75.4
Old 10th August 2007, 10:53   #29
navin's Avatar
and the fact that THD rise at the freq extremes shows why they have loped of almost an octave in the bass and the last 1/3rd octave in the HF.
Old 10th August 2007, 15:05   #30
Sam Kapasi's Avatar
Let me simplify what Navin said (Oh nostalgia)
Instead of measuring that at 20Hz - 20Khz (the way it's supposed to be measured), the power has been measured from 50Hz to 15Khz. Because the distortion would be much higher than 5% at those frequencies. So very conveniently, the measurement has been done in the middle band. And that too shows 5% THD lol.
This is a clear example of a marketing con job.
Roadster comparison aah78 The International Automotive Scene 22 8th March 2010 08:27
A Pictoral Comparison : Hyundai Getz & Maruti Swift kbk_75 Long-Term Ownership Reviews 62 5th September 2007 11:13
comparison of eco friendly cars... babe_on_wheels Technical Stuff 1 21st June 2006 14:20
Comparison test : Skoda Laura V Octavia . Beemer Test-Drives & Initial Ownership Reports 28 7th January 2006 21:45
Performance comparison - Vett vs Maybach 57 _Crazi4Speed_ The International Automotive Scene 2 29th July 2004 17:05
