Old 20th August 2007, 14:00   #46
@ what price did you finally get the 75.4 for?
askids is offline   Reply With Quote
Old 20th August 2007, 15:01   #47
panky12345's Avatar
Thanked: 149 Times
good, how much did you pay for it?
Old 21st August 2007, 11:56   #48
vkhandelwal's Avatar
the item falls in genuine product without bill to save the Taxes . got it for RS 9800 with discount. I have installed it with 1204T tube woofer and my car has been JBLfyed
GTO930 Coax, GTP 607 Compos, CS1204T bass tube, GTO 75.4 Amplifier.
Amazing Sound quality and clarity... JBL rocks...
vkhandelwal is offline   Reply With Quote
Old 21st August 2007, 14:01   #49
vikram18's Avatar
Thanked: 20 Times
Pardon me if I sound like an Ignoramus; I am in some cases. Is the 75.4 a 5-channel amplifier? If not, doesn't the bass tube need an amp as well? So, are the co-axials not amped? This is just FMI.
vikram18 is offline   Reply With Quote
Old 21st August 2007, 14:08   #50
Vikram 75.4 is a four channel amplifier
Amp is powering my front components(JBL 607) and subwoofer in bridged mode(2 channels used). rear speakers are connected to head unit directly. my head unit has three pre outs. I can control the subwoofer level direcly from the headunit as I am using the preout for subwoofer.
Old 21st August 2007, 14:46   #51
Ajaybiz's Avatar
Thanked: 141 Times
Hi Vkhandelwal how much u paid for CS1204T, GTO607, GTO937?Even i am putting the same stuff in my car only HU is Pioneer 7950 and coax spekers are JBLGTO0637.
Ajaybiz is offline   Reply With Quote
Old 21st August 2007, 15:53   #52
panky12345's Avatar
Thanked: 149 Times
vkhandelwal : techincally incorrect and you'll be losing your fader controls, power your rear 937s also (in parallel) with your front comps and you'll be rocking.
Old 21st August 2007, 16:47   #53
how would I lose my fade control. the rear speaker are still connected to rear channel and compos are in front channel. I can still use fader control to shift the soundstage.. are you suggesting connecting both rear 937 and 607 to front channel. or adding another amp to power rear speakers?
Old 21st August 2007, 18:37   #54
Sam Kapasi's Avatar
Thanked: 1,473 Times
Why is it technically incorrect? I think it's perfect what vkhandelwal is doing.
Old 21st August 2007, 18:38   #55
panky12345's Avatar
Thanked: 149 Times
yes sir, I'm suggesting to connect both the 937 and 607 to same (front channel), your HU is NOT powerful enough to extract even 10% juice.
EDIT: SAM, I know what he is doing is PERFECT. As told above, am suggesting using both the pairs off front channels of the amp, it would be technically incorrect, cauz it'll be posing lower impedance to the amp.
Old 21st August 2007, 18:49   #56
and how would this help with fader option. what if I want more sound in front than rear or vice versa. I understand that head unit was not powerful enough that's why I invested my hard earned money in purchasing the amplifier . anyways. in future I plan to add another 2 channel amplifier and power component with that amplifer and rear with 75.4. till then if SAM says that the setup is okay I'm fine with present setup as the sound is just amazing.. waiting for input from others though
Old 21st August 2007, 20:23   #57
Bass&Trouble's Avatar
Thanked: 71 Times
Sam, panky is trying to say that his way is technically incorrect, not vkhandelwal's. lol
Panky Bhai, it wont be technically incorrect because of lower impedance posed to the amp. The amp will comfortably handle the impedance. problem will be that the 6x9s will be louder than the comps and he wont be able to control that since there wont be a fader as you correctly pointed out.
Old 22nd August 2007, 09:57   #58
navin's Avatar
Thanked: 4,282 Times
Why not just add a monoblock for the sub and let the 75.4 manage the front and rear? A good 2 ch. amp is not much cheaper than a decent monoblock (think Pio D510 or JBLCS 300.1).
Old 22nd August 2007, 10:01   #59
Sam Kapasi's Avatar
I agree. A 75.4 driving 4 speakers and a good mono driving the woofers is an excellent combo.
Old 22nd August 2007, 11:05   #60
Thanked: 17 Times
Once an ICEr, always an ICEr!
Your current setup is great, Mr VKha....! Congrats.
You can opt for an upgrade by getting a monoblock amp and adding it for powering the sub(s). Don't get a 2channel amp unless it is a good powerful one (100+W RMS X2).
Till then, enjoy the current setup to max.
Roadster comparison aah78 The International Automotive Scene 22 8th March 2010 08:27
A Pictoral Comparison : Hyundai Getz & Maruti Swift kbk_75 Long-Term Ownership Reviews 62 5th September 2007 11:13
comparison of eco friendly cars... babe_on_wheels Technical Stuff 1 21st June 2006 14:20
Comparison test : Skoda Laura V Octavia . Beemer Test-Drives & Initial Ownership Reports 28 7th January 2006 21:45
Performance comparison - Vett vs Maybach 57 _Crazi4Speed_ The International Automotive Scene 2 29th July 2004 17:05
