Old 9th August 2007, 18:26   #1
Rtech's Avatar
Thanked: 217 Times
Default Can a subwoofer be powered directly off a Head unit?
As the title says, can a woofer be powered directly off certain head units? If you plan on listening to music at moderate to low volume, can a head unit provide sufficient power to operate a woofer?
I've seen the functions on my old Pioneer that show me some controls for a woofer. Does that mean the HU can power the woofer? If not, then what are those controls for?
Or are we destined to use a separate amp for all eternity?
Old 9th August 2007, 18:30   #2
Thanked: 294 Times
yes it can but the HU output in terms of power would be quite less to get max from the sub.
Old 9th August 2007, 20:04   #3
Vid6639's Avatar
Thanked: 20,026 Times
Not really advisable to run it off the HU as the HU will not be able to drive the sub to it's potential. It will not sound very good.
The options in the HU allow you to control the sub which is either connected to an amp to the preout or directly to the rear speaker channels of the HU if you don't have an amp.
To enable this setting, you have to switch off the pio HU and go to the settings menu by keeping function button pressed. There you can select for the rear channel to be in S/W mode or full range mode. If you select S/W mode you can then adjust the level and LPF setting for the sub.
If you have an amp and sub then the rear should be full range mode and the SW menu controls the sub connected to the preout of the HU.
Apologies if it's a little confusing.
Old 9th August 2007, 20:13   #4
Sam Kapasi's Avatar
Thanked: 1,460 Times
No Rtech, you cannot. You will need to buy an amplifier.
There are a few models from Pioneer that have the capability to drive a small subwoofer. In any case it sounds like crap. I know your HU (A double Din Clarion - yummy!) and I know your Bass tube. You need an amplifier, no matter what volume you want to play it at.
If nothing else, then even a Sony 502 or 222. But you need an amplifier.
Old 9th August 2007, 20:48   #5
esteem_lover's Avatar
Thanked: 448 Times
I had the same doubt a long long time ago & the doubt was put to rest by a friend of mine who did that & i was like, 'where is the sound coming from?' the sub just farts. A pair of good speakers sound (put out bass)way better than that.
Old 9th August 2007, 23:21   #6
navin's Avatar
Thanked: 3,983 Times
Not really. No HU I know of can swing the amps to drive a 10-12" sub. Not even the ones with Class D amps not unless the subs are 6 or 8" but then these would be woofers not subwoofers.
Old 10th August 2007, 11:33   #7
sushrutha's Avatar
Thanked: 324 Times
Ignore my knowledge.
Whats the difference between a woofer and subwoofer ?
Old 10th August 2007, 11:35   #8
Thanked: 294 Times
In layman terms woofer can give 40-150hz and the sub-woofer can give 20-80 hz.
The sub-woofer can go much low when compared to the woofer.
Old 10th August 2007, 11:36   #9
navin's Avatar
the lowest 2/3 rd octave or so.
Old 10th August 2007, 11:46   #10
Rtech's Avatar
Thanked: 217 Times
Originally Posted by Sam
No Rtech, you cannot. You will need to buy an amplifier.....You need an amplifier, no matter what volume you want to play it at.
Well thats clear enough!
And so is that!
2 channel amp it is.
Question: Once the sub is connected to the amp, are all adjustments to be done only on the amp or can the HU be used to make changes as well? Basic settings like raising/lowering of the sub effect?
Old 10th August 2007, 11:57   #11
Thanked: 294 Times
A good hu will have this function.
Components connected directly to head-unit w/o amp? dijeesh In-Car Entertainment 8 4th December 2012 09:25
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
You can Fight corruption - Contact CBI directly dadu Shifting gears 27 12th September 2008 11:33
Subwoofer unit advice? willy In-Car Entertainment 15 4th February 2008 23:20
Can it happen?? - Replacing a 2 DIN Head Unit SRK In-Car Entertainment 9 8th May 2006 11:37
