Old 24th August 2007, 10:00   #61
navin's Avatar
Thanked: 4,286 Times
Originally Posted by Bass&Trouble View Post
... and in a lot of subwoofer amps.
I know that but we were talking HUs and like gunbir said the HXd2 has a HPF at 20Hz. I did not know that. I knew the 701 did but that is not a HU.
Old 24th August 2007, 17:30   #62
nura's Avatar
Originally Posted by shuvc View Post
Slightly OT :
How does the fader work in a HU which has only one pre-out ?
OR
If a fader works in a HU , does it indicate that it has 2 pre-outs ?
I think the fader works on the pre-amplified as well as post-amplified (direct to speakers) outputs of the HU.
Is there any way one can adjust the volume of only the rear-fill speakers connected to the HU, when the front components & sub are connected through preouts to an amp? This information is to help a friend.
Thanks.
nura is offline   Reply With Quote
Old 24th August 2007, 19:03   #63
razor4077's Avatar
Thanked: 258 Times
Thanks.
Yea, the friend is interested to know too
razor4077 is offline   Reply With Quote
Old 25th August 2007, 04:06   #64
Thanked: 21 Times
In fact, the HX-D2 can do THROUGH/16Hz/20Hz/25Hz/30Hz and so on... so its not a fixed HPF, one can choose.
Well, if you have a 3 preout HU, its simple. Sub level menu controls sub preout, while fader controls front / rear levels. But I guess you knew that. In a 2 preout HU, where you're running the rear speakers off the HU rear channels, they would fade along with the sub.
One option is to use only the front preout of the HU, through to your amp. Then choose a single input to 4ch output mode on your amp (Nura Sir, your SRx5 does this but most budget amps don't).
Alternatively, use the front preout and split it into two preouts using a Y splitter like this,
and then input them into your amps. Assuming your sub amp is a mono, or an amp that has this capability, use a remote bass knob to control the level of the sub.
Old 25th August 2007, 08:07   #65
nura's Avatar
@Gunbir - Clear, thanks. Would you recommend heat shrink tubing over spade connectors at the ends of speaker wires? Is a hair-dryer good enough to heat shrink the tubing?
Old 25th August 2007, 09:51   #66
Thanked: 21 Times
Yes, the hair-dryer will work fine. Sir, looks like you're going all out on this one.
Old 25th August 2007, 12:08   #67
nura's Avatar
@Gunbir - It's always fun to learn .
Old 25th August 2007, 15:53   #68
nura's Avatar
Besides, the humble Pioneer cables have heat shrink tubing. I don't want to deprive the Hertz Hi-Energies of them.
Old 25th August 2007, 22:13   #69
razor4077's Avatar
Thanked: 258 Times
Kolkata is growing up from the days of the black tapes!!
Btw, the Alpine CDE 9881 has 3 preouts, right?
Old 25th August 2007, 22:59   #70
shuvc's Avatar
Thanked: 287 Times
Doc, one request. You seem to be planning out every small detail of the install yourself. Please do take a lot of snaps and post them if possible.
Old 25th August 2007, 23:57   #71
nura's Avatar
@Razor - Yes. Your HU has 3 preouts.
@Shuvc - I missed an opportunity last night as I had forgotten to take my camera. Entered Chandney Market through Gate # 5 & walked nearly to the other end. Found a shop with a huge stock of Malaysian MDF sheets in all thicknesses. A little further down, 2 guys were churning out MDF parcel trays on a jig-saw (not sure of the name, they called it a jaali machine) at the speed of a tray every 2-3 minutes. Next door, they were carpeting trays, MDF rings & amplifier mounting boards. They were even ready to fabricate MDF door pads if given samples!
Old 26th August 2007, 00:10   #72
razor4077's Avatar
Thanked: 258 Times
Hey... that sounds neat doc. Will accompany you some time to Chandni. The MDF amp mounting board sounds like a good idea!
Regd my setup: I need to see how they've wired it. Like you saw that day, I cannot tune out the rear fill from the HU. The sub quietens down with it.
Old 26th August 2007, 00:27   #73
nura's Avatar
Sure, anytime.
Could they have connected the sub to the rear preout rather than the subout?
Old 26th August 2007, 01:34   #74
shuvc's Avatar
Thanked: 287 Times
But in that case, the sub should not quieten down with the rears ?
Old 26th August 2007, 11:54   #75
nura's Avatar
I think the rears & sub would quieten down together if Razor was fading the rears.
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Lancer ICE - Installation & Tuning Queries pramodkumar In-Car Entertainment 4 25th July 2012 21:57
Ice Tuning and hardware query in santro. UniqueMods In-Car Entertainment 12 23rd March 2010 11:15
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
