Old 5th September 2007, 15:29   #91
hydrashok's Avatar
Originally Posted by nura View Post
I have just added a few more pictures of my ICE here
Picasa Web Albums - nura - My Santro ICE...
Mmm... I love unboxing pics!
Those MDF rings for the midranges are a work of art!
So when is the BIG day?
Old 5th September 2007, 16:46   #92
nura's Avatar
Me, too. In fact I must have unboxed my ICE under some pretext or other at least half a dozen times already
They sure are. And the name of the artist is Jasdeep Brar @Autophile
Well, the front doors have been cut for the midbass speakers & the rear seat modified to receive the amp. Need to get some banana connectors, heat shrink tubing & maybe a grille for the sub, some more advice from Jasdeep & then I should finally be ready. Would love to receive some tips from you too.
nura is offline   Reply With Quote
Old 6th September 2007, 00:31   #93
shuvc's Avatar
Thanked: 287 Times
So finally it has started.
Doc, are you doing all this cutting-shutting and mods yourself ? Or is your installer giving you regular visits ?
Old 6th September 2007, 02:49   #94
rocksterraghu's Avatar
Thanked: 97 Times
Thumbs up
nura, great choice of equipment there! I'm sure your installation is going to be rocking!
Congratulations! I will watch this thread to see the final install pictures. Good luck!
Old 6th September 2007, 03:12   #95
faithless_1984's Avatar
Thanked: 217 Times
Thumbs up
Great choice of equipment...Iv heard a Audison+Hertz+IDQ combo in a fellow bhpians (harsh87) Santro and it sounds awesome.
Waiting for the final pictures now.
faithless_1984 is offline   Reply With Quote
Old 6th September 2007, 23:20   #96
nura's Avatar
@Shuvc - My installer marked the front doors. I had them gas cut from a local workshop I have been visiting for bodywork for more than 25 years. My installer told me that the amplifier cannot be installed on the rear seat. However Jasdeep Brar (Autophile) patiently explained to me how it could be done & the same workshop carried out this modification too.
@Rocksterraghu & Faithless 1984 - Thanks for your appreciation.
Old 7th September 2007, 10:35   #97
nura's Avatar
Can I request someone to post a picture of the kind of nut & bolt or screw needed to fix an MDF spacer ring to the front door? The head will naturally have to be buried in the spacer ring.
Thanks in advance.
Old 7th September 2007, 13:50   #98
DerAlte's Avatar
Thanked: 2,879 Times
Thanks in advance.
You could ask for self-tapping sheet metal screw at a hardware store. Length of screw should be thickness of spacer + 1/2" at least (but not much more than that).
If you use bolt + nut, M4 or M5 would do - length as above. BUT don't forget to pick up lock washers - split or tooth type. Use those below the nut to prevent the nut from coming loose later. Use pliers to hold the nut (inside the door cavity) while you tighten the bolt from the front.
For insetting the screw / bolt in the spacer, you need to countersink the screw hole of the spacer. Can be roughly cut with a sharp wood chisel held at an angle (jugaad method), or you can find a counter-sinking bit at the hardware store (especially ones near industrial areas).
PS: Daktar-babu, we are waiting eagerly for in-process photus
Old 7th September 2007, 14:59   #99
nura's Avatar
Sir, your wish is my command
Just uploaded a few before & after pictures of my front doors here
Thank you for the wonderful reply.
Old 9th September 2007, 00:12   #100
razor4077's Avatar
Thanked: 258 Times
Cool. So the surgery is underway
Where is the work being done?
razor4077 is offline   Reply With Quote
Old 9th September 2007, 00:53   #101
nura's Avatar
The door-cutting & rear seat modding was done in a workshop near Jadu Babu's Bazaar, the ICE installation will hopefully be done next week at home in Ballygunge. Plan to fix the sub into the box & the midrange into the MDF ring myself (with a lot of help from JB).
Old 9th September 2007, 12:56   #102
razor4077's Avatar
Thanked: 258 Times
That's nice. Do it on a wknd and invite me to watch/help.
Will also take you up on that offer for a drink
I saw them fit the sub into the box as well as the speakers on the spacer rings during the Phoenix ICE install. Didn't seem too complicated, but then again, it's always easy watching an experienced installer do his stuff!
Old 9th September 2007, 22:49   #103
nura's Avatar
Sure. You're welcome. Any way. I think even after the installation is done there will be many weekends of tuning & damping & maybe eventually an HU upgrade.
Old 13th September 2007, 23:09   #104
nura's Avatar
Is it important which end of an RCA cable goes into the HU & which end into the amp?
The reason I ask is that the two ends of my Audison interconnects are shaped slightly differently from each other.
Old 14th September 2007, 11:49   #105
panky12345's Avatar
Thanked: 150 Times
nura, as far as i know its basically same....since audison are a high quality brand,there might be difference to provide you some ease while installing the same in HU.
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Lancer ICE - Installation & Tuning Queries pramodkumar In-Car Entertainment 4 25th July 2012 21:57
Ice Tuning and hardware query in santro. UniqueMods In-Car Entertainment 12 23rd March 2010 11:15
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
