Old 17th August 2007, 11:05   #16
Sam Kapasi's Avatar
Thanked: 1,473 Times
So there you go. Make a box of 15"X15"X 13"
Get a 3" pipe that is 6" long. Ghusa do. Ho gaya box. Now say thank you to LBM.
Edit: Wasava has been LBMed. That sounds about right.
Old 17th August 2007, 11:08   #17
iraghava's Avatar
Thanked: 156 Times
Does he also needs to be given Butter Chicken with the thanks?
Old 17th August 2007, 11:13   #18
Thanked: 294 Times
Or we can say...Ethanol (C2H5OH)
Thanks Guys..
And Butter Chicken is welcome anytime..
Old 17th August 2007, 12:47   #19
WasavaTyres's Avatar
Thanked: 255 Times
Thanx for all the help guys. Now I know what to do over the weekend !! thanx LBm for the technical details,and thanx Sam for translating the einstein-speak to street lingo.Thanx to you too Navin. Shall put up pictures for you guys to judge when done.
And yeah LBM,next time I'm in delhi I'll make that trip to faridabad for the appy (if u expressly insist) and butter chikken treat.
WasavaTyres is offline   Reply With Quote
Old 17th August 2007, 13:04   #20
DerAlte's Avatar
Thanked: 2,879 Times
LBM to the rescue again. I vote we make him official librarian, records manager and researcher of the ICE section.
Hear, hear! I second that whole-heartedly.
"LBM" can anyhow be misinterpreted as an acronym for Library Manager.
I suspect he has more than 100 sq.m. and 1TB storage.
Old 17th August 2007, 15:41   #21
clipto333's Avatar
Hi there,
The 502 will drive the woofer, but not too well. If you already have this amplifier it's OK, otherwise it would be better to change to any monoblock.
hi sam,
a monoblock will be the optimal choice as he has an svc(single voice coil) sub woofer. it woud be better to get a 2ch or a 4ch amp and bridge the 2 channels to drive the sub and the other to drive the speakers.
a good mono would cost around 10-12k for pio 510, jbl cs 300.1, jbl gto 301.1. for 10-12k, i would suggest the jbl gto 75.4. i think it is the best amp in this price range.
jbl cs and the gto mono will churn out 200w rms x 4 ohms and around 300w rms x 2 ohms. the jbl gto 75.4 will give around 290w rms with 2 channels bridged. he still has 2 channels to drive the speakers.
cheers
clip
clipto333 is offline   Reply With Quote
Old 17th August 2007, 17:56   #22
Thanked: 294 Times
I will be waiting for the treat...
Thanku Sir, Right now I have 640+250+40 GB with me, not 1TB but will be adding 500 GB soon...
Old 17th August 2007, 18:22   #23
clipto333's Avatar
just for your info, 1TB = 1024GB so you need 1024-930 = 94GB.
\you need 500gb more? i have a 40 gb hdd + 30gb usb hdd and its more than enough for me lol. and rightnow im only using 50%.
keep on adding. i know we all will be the beneficiaries.:-)
cheers
clip
clip
Old 17th August 2007, 20:22   #24
Thanked: 255 Times
Originally Posted by clipto333 View Post
keep on adding. i know we all will be the beneficiaries.:-) cheers clip clip
Rightly said Clip !! LBM one last question, Considering the dimensions of my car (getz) should I go in for a sealed enclosure or a bass reflex one ?? I plan to mount my blaupunkt oval speakers on a MDF tray and construct the box out of solid wood as suggested by Sam elsewhere on this forum.
Old 17th August 2007, 20:28   #25
DerAlte's Avatar
When I got my first "IBM-compatible" PC, it had a 40MB HDD. I used it for 2 years and still couldn't fill it.
We had got used to being miserly with disk space, since we were brought up on "OS + compiler + source + tools" on the same Floppy disk: a royal 384KB!!!
Old 17th August 2007, 22:31   #26
rocksterraghu's Avatar
Thanked: 97 Times
Clip, we'll go really OT here.
If you take the GB and TB measures as per your manufacturer (a.k.a Standard bytes), it is 1000MB=1GB and 1000GB=1TB (Powers of 10)
However, if you take the OS point of view (Binary bytes), it is 1024MB=1GB and 1024 GB=1TB (Powers of 2).
I see that you've mixed up both of them there, since you are referring to Standard bytes first and switching to Binary bytes later
Old 17th August 2007, 22:50   #27
navin's Avatar
Thanked: 4,286 Times
Der Alte, I worked on PDP 8 and System 36. Dont get me started (hint: I know what one bit of memory looked like it was that big you could see it with a naked eye).
Old 17th August 2007, 23:21   #28
Sam Kapasi's Avatar
hi sam,
Of course it's a better choice clip. But if he has an amplifier, then why should I tell him to chuck it? Age has taught me to respect people's wallets. lol.
Old 18th August 2007, 09:28   #29
DerAlte's Avatar
Aaah, nostalgia!!! The 'set address, set data, throw switches for input, output comes on the neon lights' machines! Or did you use a TTY? If you had a VT52 you would have been working for DEC, 3270 if IBM.
My college project was a 4004 based terminal using a TV as the monitor. That was before KELTRON came up with their CRT terminals - the first in India. We even jerry rigged our own keyboard, with desi switches bought from Lajpatrai Market. I still have the boards in a box in my basement. PCBs made at home with nail polish for etch masking.
And you are referring to ferrite core memory arrays?
Yeah, yeah, start, by all means!!!
Old 18th August 2007, 09:54   #30
Thanked: 294 Times
it is a getz then go for a sealed one as it will be easy to built and there will less error in sizes...sizes mentioned by Sam Bhai are good enough.
15 x 15 x 14 it will give you 1.25 cuft approx net with woofer volume removed.
Urgent Help Required - Sub Enclosure manojgautham In-Car Entertainment 7 11th February 2008 15:24
my 15inch sub's enclosure issue! rider60 In-Car Entertainment 16 30th January 2008 09:12
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Need info on Sub and enclosure Gtea In-Car Entertainment 30 22nd December 2006 14:31
Fiberfill for Sub enclosure madbullram In-Car Entertainment 18 5th November 2006 00:50
