Old 18th August 2007, 09:58   #31
Thanked: 295 Times
Originally Posted by DerAlte View Post
My college project was a 4004 based terminal using a TV as the monitor. That was before KELTRON came up with their CRT terminals - the first in India. We even jerry rigged our own keyboard, with desi switches bought from Lajpatrai Market. I still have the boards in a box in my basement. PCBs made at home with nail polish for etch masking.
I had done work on 8008 in collage, we had to do the programing in assembly language it was fun and it had 7 segment LED display in 16 hex language.
Seven-segment display - Wikipedia, the free encyclopedia
Old 18th August 2007, 16:18   #32
panky12345's Avatar
Thanked: 151 Times
Originally Posted by clipto333 View Post
hi sam,
a monoblock will be the optimal choice as he has an svc(single voice coil) sub woofer. it woud be better to get a 2ch or a 4ch amp and bridge the 2 channels to drive the sub and the other to drive the speakers.
a good mono would cost around 10-12k for pio 510, jbl cs 300.1, jbl gto 301.1. for 10-12k, i would suggest the jbl gto 75.4. i think it is the best amp in this price range.
jbl cs and the gto mono will churn out 200w rms x 4 ohms and around 300w rms x 2 ohms. the jbl gto 75.4 will give around 290w rms with 2 channels bridged. he still has 2 channels to drive the speakers.
cheers
clip
going by the RMS figures etc, its very common to arrive at this conclusion.
But the reality would be quite different, as navin indicated during my early days on this forum.....
"A 10K-13K amplifier to run 3K subs??"
That time I couldnt understand, now I can
Old 18th August 2007, 16:39   #33
Sam Kapasi's Avatar
Thanked: 1,490 Times
Der Alte, I worked on PDP 8 and System 36. .
Aaah, nostalgia!!!
8085 project builder and Zilog Z80 King here!! Waving. Oh crap, I'm almost as old as you geriatric lot!
Old 18th August 2007, 17:11   #34
abhibh's Avatar
Thanked: 34 Times
Originally Posted by low_bass_makker View Post
Thanku Sir, Right now I have 640+250+40 GB with me, not 1TB but will be adding 500 GB soon...
Which company HDD's ? because mine never lasts for more than 3 years
BTW in which enclosure the sub will sound good ported or sealed ?
Old 18th August 2007, 17:14   #35
clipto333's Avatar
hi sam,
cheers
clip
it should be "a monoblock will not be the optimal choice"
sorry for the error
cheers
clip
clipto333 is offline   Reply With Quote
Old 18th August 2007, 17:18   #36
Thanked: 295 Times
Hitachi or Seagate...and Samsung is the worst..
Old 18th August 2007, 17:24   #37
clipto333's Avatar
When I got my first "IBM-compatible" PC, it had a 40MB HDD. I used it for 2 years and still couldn't fill it.
We had got used to being miserly with disk space, since we were brought up on "OS + compiler + source + tools" on the same Floppy disk: a royal 384KB!!!
and i used to laugh at 1.44mb floppy disks. lol
Originally Posted by rocksterraghu View Post
Clip, we'll go really OT here.
If you take the GB and TB measures as per your manufacturer (a.k.a Standard bytes), it is 1000MB=1GB and 1000GB=1TB (Powers of 10)
However, if you take the OS point of view (Binary bytes), it is 1024MB=1GB and 1024 GB=1TB (Powers of 2).
I see that you've mixed up both of them there, since you are referring to Standard bytes first and switching to Binary bytes later
can you point where i mixed up? cant see ok i can see now. you referring to my 40+30 gb? itna toh chalta hai yaar :-)
Originally Posted by Sam Kapasi View Post
Of course it's a better choice clip. But if he has an amplifier, then why should I tell him to chuck it? Age has taught me to respect people's wallets. lol.
sam, i meant, a monoblock will not be an optimal choice. sorry for that.
cheers
clip
Old 18th August 2007, 17:27   #38
clipto333's Avatar
hi sam,
cheers
clip
sorry for the error
cheers
clip
Old 18th August 2007, 17:36   #39
rocksterraghu's Avatar
Thanked: 113 Times
Not there. I know, chalta hai in ICE forum
just for your info, 1TB = 1024GB so you need 1024-930 = 94GB.
1024GB=1TB is only for RAM (and OS recognition)
For hard disks (Industry and manufacturer standard) it is 1000GB=1TB.
So LBM needs another 70GB more. As I said before, it is alright as long as it is not affecting any of our major discussions.
Old 18th August 2007, 21:51   #40
clipto333's Avatar
you said na i mixed up by using the os standard first and industry standard later that is why i asked.
anyways it wont affect our discussions in anyway so discussion over on LBMs capacity expansion
cheers
clip
Urgent Help Required - Sub Enclosure manojgautham In-Car Entertainment 7 11th February 2008 15:24
my 15inch sub's enclosure issue! rider60 In-Car Entertainment 16 30th January 2008 09:12
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Need info on Sub and enclosure Gtea In-Car Entertainment 30 22nd December 2006 14:31
Fiberfill for Sub enclosure madbullram In-Car Entertainment 18 5th November 2006 00:50
