Old 25th August 2007, 16:50   #61
aah78's Avatar
Thanked: 1,749 Times
Originally Posted by shrivz View Post
Guys! This thread is about 1self's install!
Mods, why dont you move the irrelevant posts to a new thread, it'll make life much simpler for others!
As long as the ICE discussion is related to an Elantra, it can remain in this thread.
You do know that you can use the Report Post feature to notify regarding such issues, right?
aah78 is online now   Reply With Quote
Old 26th August 2007, 00:36   #62
shrivz's Avatar
Thanked: 92 Times
My post was with regard to the Bass controller discussion which Hijacked this thread. I'm sorry if my post made me sound rude.
Here, let me rephrase. "If the Mods could move the posts regarding the Bass controller to another thread, it would become easier for someone facing the same issue to search/post."
The bass controller discussion is definitely not a worthless discussion or anything. But for the convenience and benifit to other members, it would be better to move it to another thread.
And yes, I will use the Report Post feature next time, Sorry.
Now getting back to the Elantra's ICE.
Vivek (1self), did you get that FM interference issue sorted out yet? What was the problem?
Shrivz..
shrivz is offline   Reply With Quote
Old 26th August 2007, 19:17   #63
1self's Avatar
Thanked: 270 Times
Exclamation FM Issues
Hey Shrivz,
Nope, it has not been sorted out yet...will be going to Bafna 2moro to do the same...methinks the grounding has a lot to do with it...i did not have the problem earlier with the old system...thinking of taking the ground directly to the negative of the battery....let's see?
1self is offline   Reply With Quote
Old 15th October 2007, 00:04   #64
abhinav.gupta88's Avatar
Thanked: 310 Times
How Much did the Head Unit Cost you..
Wanted to ask you what happens to the sound or the movie being played when you apply the reverse gear and it goes into rear view mode.
Originally Posted by 1self View Post
Hey Guys,
My ICE setup is as follows:
1) Head Unit: Pioneer AVH-P6850DVD
2-DIN 7" Wide In-Dash Fully Motorized LCD Color Display with 4-Channel High-Power 6-Disc Multi-DVD/VCD/CD Receiver
Features
DVD auto play
Bookmark play (6 discs)
iPod adapter ready
Bluetooth adapter ready
Built-in MPEG 2/1 decoder
Built-in decoder (Dolby Digital)
6-disc CD/DVD changer
96 kHz/24-bit DAC (for audio)
10-bit video DAC
EEQ
5-mode preset equalizer
1-mode custom preset equalizer
3-band parametric equalizer
HPF
4-mode staging (Music Studio/Dynamic Theater/Actors Stage/Relax Living)
5 wide screen modes (Just/Full/Cinema/Zoom/Normal)
3 RCA preouts (front + rear + subwoofer)
IP-Bus input
A/V inputs and outputs
Optical digital output (DTS, Linear PCM)
AV-Bus input
2 RCA Audio/Video inputs (input 1: Audio/Video, input 2: Audio/Video or backup camera)
1 RCA Video output (rear)
Backup camera input
RGB input (26-pin)
Multi-channel processor (DEQ-P7650) control
Connectable with AVG-VDP1 Vehicle Dynamics Processor
External unit control via IP-Bus (2 units)
AUX-in (with mini jack and optional CD-RB10 and CD-RB20)
Level indicator
Spectrum analyzer
Joystick remote control
Multi-language guide - caution message only (English/Spanish/Portuguese/Traditional Chinese)
LCD MONITOR
7" wide TFT active matrix LCD color screen
AG (Anti-Glare) coated LCD color screen
Virtual GUI (Graphic User Interface)
Fully motorized unit with display angle adjustment (5 steps )
New split-screen IC
Built-in GDC (Graphics Display Controller)
2) RCA & POWER CABLING: SCOSCHE EFX
Part#: AKPA4BL
BLUE DUAL AMP P/A WRE KT
Blue / Silver EFX 4 gauge Dual Amp Power and Audio Kit (Includes 2 - A17G2BL twisted pair RCA's)
3) DAMPING: Fwd Speakers: FOCAL Propritery Damping with MDF resonance damping rings.
Rear Fillers: FOCAL Propritery & Dynamat
Subs (In The Boot): 3RAX Antivibration Fluid & Dynamat.
4) FORWARD COMPONENTS:
TWEETER: FOCAL TN 45 Polyglass
Max Power Handling:100 W
Nominal Power Handling: 15 W
Sensitivity: 92 dB
Freq Response: 3 kHz - 20 kHz
Titanium inverted dome
Phase plug
Néodimium magnet,
20 mm (3/4") ferrofluided v.coil
WOOFER: FOCAL 6 K2
165mm (6-1/2") midbass,
40mm (1-3/8") v.coil, 100mm (4") magnet
Max Power Handling: 200 W
Nominal Power Handling: 100 W
Sensitivity: 92 dB
Freq Response: 60 Hz - 20 kHz
CROSSOVER: FOCAL FA K2
2-way separate high-pass crossover
18 dB/oct. (3,5 kHz)
Adjustable tweeter level
5) REAR COMPONENTS: FOCAL 690CV1 Polyglass
Product type: Coaxial kit
Depth from wall: 93.1mm (3.7")
Cut-out diameter: 149x222mm (5.9"x8.7")
Voice coil: 32mm (1.3")
Magnet: 90mm (3.5")
Woofer: 164x235mm (6"x9") Polyglass cone
Tweeter: Aluminum inverted dome
Nominal impedance: 4 Ohms
Frequency response (+/-3dB): 50Hz - 20kHz
Sensitivity (2.83V/1m): 93dB
Nom. power: 80W
Max. power: 160W
Description: Coaxial 164x235mm elliptical (6"x9") kit, built in crossover, rotating tweeter.
6) COMPONENT AMP: ALPINE MRP-F250 (Driving components @ 4ohms)
4/3/2 Channel Operation
High Temperature Protection
Subsonic Filter
Bass EQ Circuit
Adjustable Crossover (HP/LP)
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
STAR Circuitry
Auto Over-Current Protection
MultiMode
Top Mounted Blue LED Power/Status Indicator
Input Channel Selector
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Speaker Level Inputs
Gold Plated Power Screw Terminals
Gold Plated Speaker Terminals
4-Layer Glass Epoxy PC Board
CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 40W x 4
RMS Power (at 14.4V THD+N, 20Hz-20kHz)
Per channel into 4 ohms: 40W x 4 (0.08% THD)
Per channel into 2 ohms: 75W x 4
Brigded 4 ohms: 180W x 2
Bass Engine® Sound Tuning
Crossover Frequency : 50Hz - 400Hz HP/LP/Off(-12dB/oct)
Subsonic Filter (Fixed): 15Hz
Bass EQ Frequency (Fixed): 50Hz +12dB (Ch-3/4) On/Off
Dimensions
Heat Sink (WxHxD) mm: 232mm x 241mm x 60mm
Foot Print (WxHxD) mm: 279mm x 241mm x 60mm
General
Power Requirements: 14.4V DC (11V to 16V)
Fuse Type: 15A x 2
Frequency Response: 10Hz - 50kHz (+0,-1dB)
Signal to Noise (S/N): 100dBA (Reference to Rated Power)
Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
Input Impedance: 10k Ohm
Speaker Impedance: 4 or 2 ohm Bridged
Weight: 2.7 Kg
7) SUBWOOFER AMP: KICKER ZX 1000.1
Class: D
RMS Power @ 14.4 V In Watts @ 2ohms Mono <1.5% THD+N: 1000
Length: 425mm
Ht: 54mm
Width: 244mm
Freq Response: 20Hz - 200Hz
Signal To Noise Ratio: >95 dB, a-weighted, @ rated power
Input Sensitivity: 125mV - 5V low level, 250mV - 10V high level
Electronic Crossover: Variable Low-Pass, 50-200Hz, 24dB per octave
Defeatable High Pass 12dB per octave @ 25Hz
Bass Boost: Variable 0 to +18dB boost @ 40Hz
8) SUB WOOFERS: KICKER CompVR DCVR 12 (Dual 12 inchers with enclosure)
Nominal impedence (Ohm): 2
Sensitivity (SPLo),dB @ 1W, 1m: 98
Power Handling Watts, Peak (RMS): 1600,(800)
9) CAPACITOR: EARTHQUAKE
MODEL: PHC-15
Max Power: 2000 Watts
Capacity: 1.5 Farad
PCB working status flash blue LEDs
Fluorescent cap ring
Digital voltage meter
High-current handling
Polarity protection circuit
Audible voltage protection circuit
Lowest E.S.R. 24 VDC foil with maximum moment discharge.
Working Voltages: 10-24VDC
I spent 5 continuous days from 10am - 10pm getting it right...the damping, especially the liquid damping took the longest time to dry (total of 10hrs).
But it is finally finished!!
Jeez.. you guys have gone way OT here..
Old 15th October 2007, 01:04   #65
rocksterraghu's Avatar
Thanked: 95 Times
Hi Abhinav. Please avoid quoting long posts like you just did, thanks
Old 16th October 2007, 15:45   #66
1self's Avatar
Thanked: 270 Times
Hi Abhinav!
just read your post...the unit cost me around 48000 without bill (70000 with bill it is). also...while the music is on...the display just changes to the reverse camera....the sound remains on....havent tried with movies....good idea will let you know!
Old 16th October 2007, 15:48   #67
1self's Avatar
Thanked: 270 Times
Exclamation ICE Update: Component Amp Upgraded!
Hey guys!
Upgraded my Apline component amp to MRP-F-450.
(70W RMS x 4@ 4Ohm impedance) now my Focals play a LOT cleaner!
Old 16th October 2007, 16:16   #68
1self's Avatar
Thanked: 270 Times
Another update:
FM problem solved! Thanks to Deralte! I moved the dual horn bodies to a thick piece of wood! Also put up a capacitor...the two measures made the sound disappear!!
Old 16th October 2007, 16:49   #69
vikram18's Avatar
Thanked: 20 Times
Hey guys!
Tu bhi na...Was gonna give you my SRX4
vikram18 is offline   Reply With Quote
Old 17th October 2007, 22:37   #70
Amey's Avatar
Thanked: 189 Times
SRX4 with a Pio HU, thats insult of that Amp
Infact insult to even the speakers.lol
*dodges eggs and tomatoes from 1Self*
Amey is offline   Reply With Quote
Old 18th October 2007, 10:13   #71
gbpscars's Avatar
hey vivek!!
that's a whole lot of equipment. you do justice to that long boatmobile of a car.
congrats on your improvised setup. i have heard it almost a month before with most of it not installed, even then it sounded like you could use your twin woofers to drive your car to the nearest petrol bunk if ever you run out of fuel. LOL
that is one moving discotheque!
gbpscars is offline   Reply With Quote
Old 18th October 2007, 10:52   #72
1self's Avatar
Thanked: 270 Times
Hi Anand!
Well...i did strike a balance between SPL & SQL!!
Old 18th October 2007, 12:53   #73
panky12345's Avatar
Thanked: 149 Times
naah re! I've seen couple of SQ installs (apparently - havent heard) here with this combo!
Old 18th October 2007, 17:59   #74
Thanked: 310 Times
Dude did you check the working of the camera when the video is playing
Eager For The Results!
And 1 more thing , does the camera show the distance also as shown is sensors or does it only show the rear
Old 18th October 2007, 18:09   #75
moralfibre's Avatar
Thanked: 6,532 Times
I am sure it doesn't measure the distance as there are no sensors. It only shows the rear.
I had a few pictures of 1self's ICE setup and a few upgrades that he did:
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
