Old 5th September 2007, 09:38   #1
kapilsharma80's Avatar
Thanked: 28 Times
Default sony2 Channel amplifier wiring
Guys, i need your help.
i have a 2 channel sony amplifier lying with me. it was earlier installed in my brothers esteem. is it advisable to install an amplifier?
when i spoke to a local dealer here in chandigarh, he suggested me to buy a new set of wiring (cost rs 850) reason being that old wiring tend to get carbon deposits in it.
is it true and what if i use the old wiring - will it affect performance?
i have a sony HU (52 x 4 W)
speakers - blaupunkt gtx 693 (50w)
kapilsharma80 is offline   Reply With Quote
Old 5th September 2007, 11:20   #2
navin's Avatar
Thanked: 4,265 Times
Originally Posted by kapilsharma80 View Post
i have a 2 channel sony amplifier lying with me....he suggested me to buy a new set of wiring (cost rs 850) reason being that old wiring tend to get carbon deposits in it.i have a sony HU (52 x 4 W)speakers - blaupunkt gtx 693 (50w)
Carbon Deposits! Wow! tell him that in taht case he can use the depoits to Date the amp. In short your dealer is talking through his hat.
Yes the old copper wire might have some corrosion but if it good why not clean it and use it. If you feel the need for better wire you can buy that too but the old wire will be fine for starters.
Old 5th September 2007, 13:02   #3
Thanked: 28 Times
Thanks navin.
being a novice i would require more advise from you.
i would also like to know whether there is a ready to use amp setting manual available coz there is a dearth of 'audio' amp setters in chandigarh.
Old 5th September 2007, 14:33   #4
crazydiablo's Avatar
Thanked: 21 Times
It is advisable to use amp. Carbon dep is all non sense.
The wire may be frayed or something, sound quality may take a hit if the wiring is not good. Fix it and listen and if you are ok save that money for something better.
crazydiablo is offline   Reply With Quote
Old 5th September 2007, 14:49   #5
panky12345's Avatar
Thanked: 147 Times
These new set of wiring for 850/- is ridicoulous. You would be just fine. go ahead.
Old 6th September 2007, 15:03   #6
ScarySkulls's Avatar
Thanked: 19 Times
Yes. It is always a good idea to add amplification to your system.
The 850/- wiring kit, though, is a sure shot Con Job.
Is it BOSS by any chance?
I would also like to know whether there is a ready to use amp setting manual available coz there is a dearth of 'audio' amp setters in chandigarh.
Yes. That is very true and frustrating. Infact, so much that a friend had to come down from Chandigarh to Ludhiana to get the install of his dream in his Swift.
You can check out the topic in this section only. DIY SQ install.
P.S.>> As you will notice on seeing the topic, you simply DONT have any good installer anywhere in Punjab. That is why, we had to go down the DIY route too.
ScarySkulls is offline   Reply With Quote
Old 7th September 2007, 10:02   #7
navin's Avatar
Crutchfiled used to publish a manual for setting up a car audio system. I donated mine to my installer in 1995. Anyway most of this is plain common sense and all you need to use is your ears.
Old 7th September 2007, 11:23   #8
rocksterraghu's Avatar
Thanked: 88 Times
Not sure if this is the one:
http://akamaipix.crutchfield.com/ca/.../amp_guide.pdf
You can find some useful information here:
A/V Learning Center: Car Audio & Video
Old 7th September 2007, 11:57   #9
navin's Avatar
Originally Posted by rocksterraghu View Post
the one I had was about 30 pages.
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
My MBQuart amplifier & Phoenix Gold wiring have arrived. blue2ki In-Car Entertainment 13 24th July 2008 22:19
2 channel or 4 channel amp harry2223 In-Car Entertainment 14 19th February 2008 22:08
FS : Alpine MRP F240, 4 Channel Amplifier (used) s0uljah Shifting gears 1 4th February 2007 00:12
800Watt MA Audio 4 Channel Amplifier for sale! shrivz Shifting gears 4 2nd August 2006 15:23
