Old 5th October 2008, 00:10   #286
navin's Avatar
Thanked: 4,283 Times
100Hz and 3kHz are a good place to start. Gunbir used to deal in Hertz maybe he knows more.
navin is online now   Reply With Quote
Old 5th October 2008, 00:29   #287
Gill's Avatar
Thanked: 12 Times
Hope,Gunbir adds on something to the discussion,mean while navin ji even we reduce the harshness of tweeter somehow if possible by going active like changing the slops or reversing the phase or by any medium.
One thing more would it be safe to have tweeter playing down to 3khz?
Gill is offline   Reply With Quote
Old 5th October 2008, 02:18   #288
Thanked: 21 Times
Originally Posted by Gill View Post
Navin,
I am also inclined for going active but i am not to able to find the info about the Freq range the tweet and mid can handle,On hertz site they have mentioned that full comp set range is 60hz to 23k but i doubt the midbass can go that low,mid bass would be happy around 80hz range
I was looking for Energy Crossover points in defualt crossover it comes with,but couldn't find any info.
Only concern are the drivers strong enough to handle the active system
Hi Gill,
Don't bridge the amp to the components. There is no need for that much power. Especially since it will overpower your sub stage. Ideally, a power ratio of 1:2 (eg. 100w x 2 to fronts, 400w to sub) works for most people, some prefer 1:3. By that standard if you plan to have a 500w (250w x2) front stage, you will need to at least have a 1000w sub stage.
Here's what I suggest:
Option A: Semi Active. Run your HT18 tweets (with crossover) off your HU amp's rear channels and the midbass (with crossover) off the 75.4's front channels. By using fader, you can control the level of power going to the tweeters and blend them to your taste. This option leaves you the other two channels of your 75.4 to bridge and run the sub, as it is now.
Option B: Alternative to the above, you can run the tweets off the 75.4 (with the crossover) front channels, and the midbass (with crossover) off the 75.4's other two channels. Of course, you will need another amp for the sub.
Option C: Active. Akin to option B, except, discard the passive crossovers, set the 9887 to active and set the tweeter HPF at 5KHz, bandpass the midbass between 80Hz and 5KHz.
Again, in Active mode, you can also try running the tweets off the HU amp's front channels. Or off the 75.4, as discussed in above A & B options, only difference is passive crossovers are discarded and active used. The HT18 tweeters don't need a lot of power and I suspect you will find them sufficiently loud off the HU amp. So I suggest trying this first.
Let us know if you need any further help with this.
Cheers!
Old 5th October 2008, 03:33   #289
Gill's Avatar
Thanked: 12 Times
Thanks for the Input Gunbir,I might be adding an amp for sub,shall be giving the IDQ around 500-600w.
So the JBL will be used to power the fronts only.
I woul like to use 9887 to run whole setup active.I want to see what difference does it make to run system active and what are the pros and cons of each(Passive and active),You solved my confusion about frequency cut offs,
Can tweeter play lower then 5K hz?
another small confusion with option b)How can the system be active with existing crossover of the comps
Old 5th October 2008, 03:47   #290
Thanked: 21 Times
Awesome. The iDQ15v2 will rock your world on 600w.
Yes, you can run the tweet lower than 5KHz. It would be comfortable with anything over 3.5KHz. See the enclosed data for more details on the HT18 tweeter.
As I said, it's sort of semi-active, if you power (bi-amp) the tweets, mids separately and control the level of each driver separately. The passive crossovers still do the crossover function, so its not completely active. Of course if you have the amplification, by all means go active.
Cheers!
DIY SQ install: Gill's Swift-ht18_spez.gif
Old 5th October 2008, 03:59   #291
Gill's Avatar
Thanked: 12 Times
Thanks Gunbir for the data and input,surely made things easier for me,what all things need to take care off while running the system active,i mean small things that a novice like me might look over,i know one thing for sure,gains for tweeter has to set very carefully,
gotta go to bed now,will discuss rest later,
Cheers! and thanks again Gunbir
Old 5th October 2008, 10:41   #292
hydrashok's Avatar
This option sounds the best to me. The added advantage is that you can try this right now, without waiting for a mono amp.
Old 5th October 2008, 14:16   #293
noidaboy's Avatar
Thanked: 260 Times
Waiting for this to happen
noidaboy is offline   Reply With Quote
Old 5th October 2008, 23:55   #294
navin's Avatar
1. with an fs of 1500Hz 3k/12db is about the minimum XO the tweeter can live with.
2. I like option A as it keeps the tweeter's XO in circuit. seeing the tweeter's impedance curve I would guess that the XO has an impedance flattening circuit implemented in it and by removing this XO you will loose the benefit of this.
Old 5th October 2008, 23:58   #295
navin's Avatar
Gunbir,
this is a 4 ohm tweeter right? if you see the specs it is quoted as 91db/1W, later it is quoted as 91db/2.83V (which for a 4 ohm tweeter is 2W). What gives?
Old 6th October 2008, 00:56   #296
Thanked: 21 Times
Exactly sir, in the whole trend of active, impedance correction usually gets overlooked.
Hmm... Looks like a typo.
Old 6th October 2008, 03:30   #297
Thanked: 17 Times
Gill, I 've got to salute you for your interest in DIY and the urge to try out new ways in your ICE. Keep it up!
The option A mentioned by Gunman seems a good point to start experimenting with. You don't have to change your setup much and can be done easily.
My suggestion to try that first and give us some feedback.
Old 6th October 2008, 11:18   #298
navin's Avatar
not only impedance correction but also baffle step (for home audio) and baffle difraction. Ofcourse the simpler way is to implement these at line level (cheaper too since you need small components).
Old 6th October 2008, 14:59   #299
Thanked: 294 Times
Hmm I would not take this as a ideal stuff. There can be lots of variations and it will depends on the equipment you are going to install. I have a 500 watts front and 2400 watts sub. ratio is 1:5
I have such a loud sub section because I love SPL. But it is not necessary that I will play it loud 100 % of the time. I tone it down to match it with the front stage.
Also using high rating amps with a speaker with lower RMS rating the main purpose is more headroom. The driver will play stress free without any clipping.
Old 6th October 2008, 23:40   #300
Thanked: 21 Times
I don't know where there's a debate. I did not say its absolute, just an ideal that works for most people. I did not say all people.
Rally School with Gaurav Gill - Bangalore speedmiester Indian Motorsport 31 2nd November 2010 19:33
Gaurav Gill wins the International Rally of Queensland speedmiester Int'l Motorsport 2 2nd August 2010 19:16
Gaurav Gill Wins APRC Rally of Indonesia!!! Manoj Biswas Indian Motorsport 12 26th April 2010 11:54
Gaurav Gill's Web Site c10 Indian Motorsport 0 3rd April 2010 11:26
Gaurav Gill to drive for MRF in APRC jerish666 Indian Motorsport 10 2nd March 2007 01:54
