Old 2nd October 2007, 22:14   #61
vebmetal's Avatar
Thanked: 15 Times
ok..... this is the part I lose what the hell you guys are talking about and come back to the point that for me it is a jugaad in the sense that I am not a professional or hobby electronic enthusiast. I tried my hand at soldering once and failed miserably. So I don't want to solder anything anywhere, or trust anyone else here to really do it.
What I was saying, anup, was that I don't want a 'home remedy' to fix this problem, but am comfortable using say a device that is manufactured by a reputable company to do what you describe (which btw I still do not understand!)
So could you describe what it is that you are saying in plain English and further, suggest a solution that a lay person can employ.
vebmetal is offline   Reply With Quote
Old 2nd October 2007, 22:17   #62
Sam Kapasi's Avatar
Thanked: 1,473 Times
Veb, please. Just connect the headphone out to the amplifier using a good cable, it will work well.
Old 2nd October 2007, 22:35   #63
vebmetal's Avatar
Thanked: 15 Times
Thanks, Sam! That is really all I want to hear Done and done.
Old 3rd October 2007, 07:50   #64
Thanked: 253 Times
O.K. Here goes - straight from the boss:
Old 3rd October 2007, 09:33   #65
Sam Kapasi's Avatar
lol, I'm no boss anup. Just a firm believer in K.I.S.S.
Old 3rd October 2007, 09:44   #66
Thanked: 253 Times
So tell me. 'cause I'm a firm believer in Pink Floyd!
OK, no kidding. I know you don't mean the band.
What does K.I.S.S. stand for...??
Old 3rd October 2007, 09:50   #67
Sam Kapasi's Avatar
Here you go, from wikipedia .
The term KISS is an acronym of the phrase "Keep It Simple, Stupid", and the KISS principle states that design simplicity should be a key goal and unnecessary complexity avoided. It serves as a useful and frequent verbal exhortation (or even dedicated policy) in software development, animation, engineering, and in strategic planning (especially military operations). Other versions of the phrase include "Keep It Simple & Stupid" (most recently used in west-European literature), "Keep It Sweet & Simple," "Keep It Short & Simple," "Keep it Simple, Sweetheart," and "Keep it Simple, Sherlock," and the obvious scatological variation.
Old 3rd October 2007, 10:17   #68
Thanked: 253 Times
Thanks.
_______________________
Old 3rd October 2007, 13:04   #69
navin's Avatar
Thanked: 4,286 Times
And would there be any advantage of going with a 100mV input sensitivity amp as opposed to a 200mV or 300mV one?
Also, the blaupunkt installer had said that the higher the pre-out voltage of the audio device, the better the sound I would get. He said ideally it should be upwards of 2V.
Your Blau dealer is right. The higher the Signal level you can derive from your MP3 player the less noisy it will be. If your signal level is low (200-300mv) range your cable runs will have to be well planned and short (think 1.5m). With higher signal levels your install is less suseptible.
Originally Posted by anupmathur View Post
In fact, I'm only answering this as (being a national holiday) it seems that Navin and Sam have headed out already to the neighbourhood pub for their evening W & S!
In case your MP3 player does not have a line out but has only the headphones out, you might need to 'load' your output with an appropriate resistor (8 ohms or 32 ohms, 1/2 W) to achieve best performance.
Sorry for not being available. Ipods have a line out only one needs an adapter to convert this to a standard EP female socket.
My mp3 player only has a headphone jack. I haven't seen any mp3 player with a line-out..
Ipods have a line out. Some time back I connected my nephew's ipod via a cheap YES dock to his car stereo.
Old 3rd October 2007, 13:11   #70
navin's Avatar
That's why I mentioned the 32 ohms resistor. And for that matter there are some at 600 ohms too.Again, I have said the same. But there ARE those cases.
I've seen 'phones with impedances as high as 2000 ohms.
Correction: I have opened up and messed with 'phones with impedances as high as 2k :-)! Sennheisser HD 414 I think they were. Senn's 424 were also 2k.
which MP3 player do you have?
Old 3rd October 2007, 13:22   #71
Thanked: 253 Times
No Navin, certainly not the HD414s. I think they were 32 or 52; can't remember.
Was my guess bang on or not?! C'mon, please do tell!
Old 3rd October 2007, 18:03   #72
vebmetal's Avatar
Thanked: 15 Times
I have the Creative Zen Xtra - it's a really old player unfortunately, and it's due for an upgrade. I don't really like any player in the market right now though - they just aren't innovating much. (But I plan to check out the new Zune 2s online today).
So here's what the final setup is looking like. I plan on buying everything with B&W.
Front components: Hertz DSK165
Speaker cabling: Connection Audison
Amp: Blaupunkt GTA 2 Special MK II (2 Channels)
Amp Cabling: Tsunami
Final thoughts / suggestions / price recommendations?
Old 4th October 2007, 12:42   #73
navin's Avatar
later versions of the 414 were 52 ohms (boy you remember well) but the earlier versions were 2k. we used to make small amps out of BD139/140 to drive them.
I spend my holidays with my son.
Old 4th October 2007, 13:19   #74
Thanked: 253 Times
Osh Kosh B Gosh!! He's off to an early start! Wish I had a Dad like that!
But, but, thank the lord me dad never used germaniums! (I think these were germaniums?).
Old 4th October 2007, 14:53   #75
DerAlte's Avatar
Thanked: 2,879 Times
Ama Mathur sahab, what's with germaniums and silicons? That also in relation to your pitashri?
And where did you expect @veb to find 8 or 32ohm resistors? Had he gone for it, he would have landed up using 3 or 5 resistors just to get those values.
There must be something in the air today - you are sending everyone on 'jangli batakh ke peechhey daud's.
Lo kallo baat! Bhaya, you should buy hardware from hardware-wallahs, not software-wallahs!
The Head Unit - What made you buy it & for how much? D1ISTHE1 In-Car Entertainment 40 12th March 2009 08:53
Crazy Idea 2- using pc speakers rather subwoofers - Will this work??? coolaks7 In-Car Entertainment 38 24th November 2007 18:40
Any idea about FIAT Idea? Minardi The Indian Car Scene 13 28th May 2005 12:38
