Old 19th September 2007, 14:17   #1
rkbharat's Avatar
Thanked: 613 Times
Default What speakers for my Indica?
Its high time that I change the front and rear speakers in my Indica. I have JVC HU (4 yr old model) which works well. Current speakers are some junk "American Acoustics", never heard of it, right?
I am looking for speakers set around 4K-5K budget.
Should I replace the plastic tray to wooden for rear speakers.
I am not looking for a shouting and screaming setup, need crystal clear sound with good bass.
Please suggest the setup and any good shop in Gurgaon, Haryana
rkbharat is offline   Reply With Quote
Old 19th September 2007, 14:43   #2
panky12345's Avatar
Thanked: 150 Times
I've heard american acoustics....not too good, but OK for the price.
As you are on budget (I assume), go in for front and rear JBL coax without amp, and u'll be just fine.
If you can extend your budget, we have plenty of options.
panky12345 is online now   Reply With Quote
Old 19th September 2007, 14:56   #3
rkbharat's Avatar
Thanked: 613 Times
Panky,
JBL will good for me, I can extend my budget, but it does make any sense to invest too much on my 88K km driven car. I am just waiting for safari 2.2 and will spend bulk for the bucks there.
As I have planned to keep my Indica, instead of selling, I just want a decent setup. Couple of more questions..
1. What about the tray, should I changed it to wooden. current is stock plastic.
2. Should the whole wiring be changed to remove any loose wiring issue?
3. What is the better option, Front Dash speakers or front door speakers?
4. My current setup is such way that I can remove the rear tray with front speaker still running. Does this affect the SQ for rear speakers, having more joints?
Old 19th September 2007, 16:52   #4
panky12345's Avatar
Thanked: 150 Times
Originally Posted by rkbharat View Post
Panky,
Well Bharat, whether it makes sense on not it solely depends upon you. I have a 99K ODO reading Indica with a better set up.
1. Let it be OEM. No difference.
2. Speakers would come with the wires. No issues, because no amp.
3. Front door would be good, if you want you may add tweeters at the dash.
4. See if you run it purely on front speakers, there would be a difference yaar. ~Common sense~ No,having more joints will not affect SQ in your set up.
Old 19th September 2007, 17:07   #5
rkbharat's Avatar
Thanked: 613 Times
thanks Panky.
I run on only front speakers in cases I need to load something that need tray to be removed.
Indica speakers set-up luvjascha In-Car Entertainment 3 21st July 2008 16:06
Old Indica LEi / New Indica DLS / New Alto LXi shuvc Hatchbacks 20 19th February 2008 17:31
Indica TCIC vs. Indica DICOR hell_rider The Indian Car Scene 11 13th March 2007 21:22
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 1st September 2006 23:29
Indica Turbo or Indica Xeta BNB Hatchbacks 6 23rd April 2006 11:19
