Old 26th September 2007, 14:54   #1
vebmetal's Avatar
Thanked: 15 Times
Default What size speakers can I fit in Zen Estilo
I have posted some pictures of the default speaker provisions given in the Maruti Zen Estilo Vxi here. According to the service station I can put 6" speakers in the Front and 4" in the Rear.
Do I have any other options? Someone here mentioned spacer rings - what are those and what are their pros / cons?
Front Provisions
Rear Provisions
vebmetal is offline   Reply With Quote
Old 26th September 2007, 15:08   #2
moralfibre's Avatar
Thanked: 6,532 Times
I have seen an install with Illusion Audio EL 6.1 6.5" components and Illusion Audio EL 62 6.5" co-axial install in a Zen Estilo and they fitted without any issues.
Old 27th September 2007, 14:29   #3
vebmetal's Avatar
Thanked: 15 Times
Hmm... how much do they cost? And how did the installer fit 6.5" speakers in the rear 4.5" hole?
Any other suggestions / thoughts?
Old 27th September 2007, 14:35   #4
moralfibre's Avatar
The installer used a 0.75" spacer ring to fit the speakers. Was a clean job overall.
For prices of Illusion Audio products PM Bass&Trouble.
Old 27th September 2007, 15:01   #5
vebmetal's Avatar
Thanked: 15 Times
^ How exactly does a spacer ring work in terms of letting me put a bigger speaker? And do the rings have to be bolted onto the door? Can I use spacer rings to put 6x9s in the rear? Also do they come default with speakers or are they an added expense?
Old 28th September 2007, 09:16   #6
Thanked: 11 Times
I think this might help you in getting the information.
<MDF Speaker Spacer Rings>
<How to make door pods - S-10 Forum>
I do not think that they come with speakers and they are not too expensive also.
Krato is offline   Reply With Quote
Old 28th September 2007, 11:29   #7
vebmetal's Avatar
Thanked: 15 Times
So using spacer rings means that I have to get these "door pods" made, or that is just another way? If not, I assume the rings have to be bolted onto the door somehow, right?
Old 28th September 2007, 11:38   #8
Thanked: 11 Times
The door pods may not be required. your second assumption is right.... I think you tell your requirements to the guy from where you want to install, he will take care of everything
Old 28th September 2007, 14:13   #9
Bass&Trouble's Avatar
Thanked: 71 Times
The front doors take 6.5" speakers just like the Swift. The rear doors have provision for a 4" speaker. In the rear also, the mount provided for the 4" can be removed and a 6.5" can be installed without any major modification. Spacers would be required to prevent the magnet touching the glass when it is rolled down, both in front and behind. If any installer knows how to install 4 x 6.5" speakers in a Swift, he can do it in the Estilo as well.
The spacers need to be screwed on to the metal of the door. Use flat headed screws or sink them to make sure the heads of the screws dont foul with the speaker basket and cause an air leakage.
Old 28th September 2007, 15:54   #10
vebmetal's Avatar
Thanked: 15 Times
Ahh, I forgot that I might need spacers in the front as well - tsk.
So does the Swift also have a 4" provision in the rear?
I am confused about one thing - I am looking at this picture of the rear speaker provision, and am I right in assuming that if I want 6.5" speakers in there, I am going to have to get some part of the door panel cut? (Considering that the height of the 'rectangle' is only about 5".)
Thanks for your help, Bass&Trouble!
Old 28th September 2007, 16:16   #11
moralfibre's Avatar
You will have to cut a small ring right across the circumference of the space you marked as 4.5" and thats about it. Don't bother about the 5" marked part. The 4.5" grill circle has a plastic support on the inside of the panel which requires to be cut and isn't seen at all from the outside.
Old 28th September 2007, 16:28   #12
Thanked: 71 Times
Well, dont cut the door panel. The speaker mounts on the door frame thats behind the door panel, right? Although there is a problem because the opening in the grill is just 4.5". I think you should go for 4" or 5.25" if you can have someone make the right ring for it. Otherwise too much of the front of the speaker will be obstructed by the door panel.
Is it possible to fit two different size of tyre? sans33 Tyre & Alloy wheel Section 39 28th March 2014 12:09
Honda Fit (Jazz in India) gets a fit-ting facelift sidindica The International Automotive Scene 16 17th August 2011 10:03
Speakers for the new Estilo LXi emil In-Car Entertainment 0 2nd March 2010 17:47
Honda City Rim size - does it fit an Esteem Jeep Tyre & Alloy wheel Section 4 9th May 2009 12:06
ultra thin headphone size speakers arpandiv Gadgets, Computers & Software 0 13th April 2008 20:39
