Old 4th October 2007, 17:21   #1
sonic_boom's Avatar
Thanked: 12 Times
Default Good Monoblock Amp under 10K for Alto
Hello all,
After a lot of reading on this forum I am thinking to go for a monoblock amp the can power my 12" Sony sub (300W RMS / 1000W Max) in my Alto.
Currently I am using a Sony XM-552ZR 2 channel amp that produces (only) 130W RMS @ 4 ohm in bridged mode. It is okay at low volume but the amp clips at higher volume.
My rear speakers are Sony 6X9 Coaxials and two way co-axs at fromt. HU is sony CDX-GT460US.
My questions are -
1) Will a 300W RMS amp provide substantial increase in the max volume and SQ of my sub.
2) If yes then please suggest a good 300W amp under 10K (B & W preferred).
3)What is the difference in power rating of amp at 2 ohm and 4 ohm and which one should I consider relevant ??
Thanks in advance...
sonic_boom is offline   Reply With Quote
Old 4th October 2007, 18:49   #2
1 ) YES. 130W is nothing when you are powering a sub. Ideally you should look at atleast 250+ for some serious bass. It will increase the loudness, but as for SQ I can't say. If the sony sub is missing beats then it still will.
2 ) You can find MANY amplifiers under 10k for this. Even jbl has the cs300.1 which I think is under 10k. Sony, pio, blaupunkt, etc are also viable alternatives. Look for one with b/w only for peace of mind. You can even post in the market section to see if someone is upgrading his amp so that you can get a good deal on the old one.
3 ) Ideally if you are buying a mono buy one which is 2 ohm stable. Also, the power at 2 ohms should be double the power at 4 ohms. Also, take a look at the THD ratings. These are also very important. Pls stay away from the desi amps. IMHO the 2ohm rating is more important as it shows how much current the amp can handle. Some amps don't deliver double the power at 2 ohms, which clearly shows the internal limit of the amp
akg7091 is offline   Reply With Quote
Old 4th October 2007, 19:01   #3
Gill's Avatar
Thanked: 12 Times
Originally Posted by akg7091 View Post
3 ) IMHO the 2ohm rating is more important as it shows how much current the amp can handle. Some amps don't deliver double the power at 2 ohms, which clearly shows the internal limit of the amp
HI,
AKG, would plz clarify this a bit more....Why 2 OHms rating is the benchmark for a monoamp..then some 1ohms stable mono amp are also available.......Why 2 ohms?
Gill is offline   Reply With Quote
Old 4th October 2007, 22:54   #4
I did not mean it is the benchmark. I meant it is more important than the 4 ohm rating ( note I said more, not most in my earlier post ). I will give you an example. I have a blau tha1400. It is rated 400@4. I may assume that the power will double at 2 ohm if I don't look at the rating and just see that the amp is 2 ohm stable. However, this amp pushes 650@2 and not 800@2. This clearly shows the limit of the amp. Also note, he is looking for amps<10K so I don't think he can get 1 ohm stable amps from any reputed brand. Maybe I am mistaken.
I think you know exactly what I mean Gill sahab. I cannot clarify it more. It is very much obvious that an amp stable at 1 ohm from a reputed brand is obviously better. Maybe I should have worded it like check the rating at the lowest ohm the amp is stable at.
Old 4th October 2007, 23:11   #5
jkdas's Avatar
Thanked: 1,437 Times
check this
http://www.team-bhp.com/forum/indian...mp-wanted.html
Old 4th October 2007, 23:18   #6
rocksterraghu's Avatar
Thanked: 113 Times
Your setup, IMO requires more than a monoblock. You'll have to upgrade the front stage and the sub as well. Just an opinion.
Old 4th October 2007, 23:22   #7
jkdas's Avatar
come on re leave him alone!
Old 4th October 2007, 23:25   #8
JayD's Avatar
Thanked: 2,008 Times
ooh boy! i see one more victim for the tbhp ice monsters!!
JayD is online now   Reply With Quote
Old 4th October 2007, 23:28   #9
Thanked: 113 Times
Don't we all enjoy doing this? Why do I seem to be the culprit?
Old 4th October 2007, 23:30   #10
Thanked: 295 Times
You can check the specs of the STEG MSK 50 SC
Old 4th October 2007, 23:34   #11
Just one word lbm sir, WOW !
Old 4th October 2007, 23:35   #12
Thanked: 13 Times
Check out some of the old school Orion HCCA series. 225/250 etc. They could be driven to insanely low ohm's while churning out serious power.
edit : LBM beat me to it with the masterstroke! Anyhow the orions are still worth checking out :-p
Old 5th October 2007, 00:32   #13
Thanked: 295 Times
Sure they are soild...
2 x 50W @ 4 ohms
2 x 100W @ 2 ohms
2 x 400 @ ohm
1 x 800 @ 1 ohm bridged
Orion HCCA250
best home speaker system under 10k? beanstalk_230 Gadgets, Computers & Software 52 20th January 2010 13:26
Good monoblock amp under 15k ilovefls In-Car Entertainment 15 22nd December 2009 08:12
Better SQ replacement for my Pio 4050 under 10k jaibir In-Car Entertainment 12 7th June 2009 12:33
Under Rs.10K smart phone - Inputs please dash Gadgets, Computers & Software 14 12th February 2008 16:21
SQ - Components and AMP under 10K - Advice pl. danny In-Car Entertainment 14 14th November 2007 23:38
