Old 12th October 2007, 23:42   #16
Su-47's Avatar
Thanked: 94 Times
Originally Posted by blueraven316 View Post
the 300W Sony 2 Channel amp we have been seeing till now will drive a sub as well as the JBL 60.2 as it has a flat LPF switch
You mean it is not possible to change the LPF cutoff frequency? Or, something else?
Su-47 is offline   Reply With Quote
Old 13th October 2007, 11:41   #17
blueraven316's Avatar
Yes you are right!
blueraven316 is offline   Reply With Quote
Old 2nd November 2007, 03:43   #18
NVM
Default ICE Advice for Safari 2.2 LX
Hi I am planning to get a Safari soon. For certain reasons I would need to limit myself to ICE options which are available at the dealer. These are only Blau and Pioneer HU and speakers.
I generally listen to soft music which I like crisp and clear. I need a USB option in my HU too. Occasionally with the right crowd I would like a bit of boom.
As far as possible I want to make do with minimum modifications to the vehicle itself and do not want to use up space in the car.
Please suggest what would be the best ICE setup taking the above into consideration.
NVM is offline   Reply With Quote
Old 2nd November 2007, 09:37   #19
Thanked: 11 Times
Hello NVM,
It would be more helpful to drill down the options, if you mention the budget also ?
Krato is offline   Reply With Quote
Old 2nd November 2007, 10:43   #20
navin's Avatar
Thanked: 4,282 Times
Hi I am planning to get a Safari soon. For certain reasons I would need to limit myself to ICE options which are available at the dealer. These are only Blau and Pioneer HU and speakers..
Get Blau THC/Thx speakers and either HU.
Old 2nd November 2007, 12:03   #21
overdose14's Avatar
Putting 6X9s in boxes in the back is not such a good idea, the speakers especially JBL GTOs tend to boom a bit in a box, Now, I am not sure what kind of mids you are looking for.
Which JBL 5.25" Speakers do you have ? CS ? GTO ?
Component Speakers will produce better mids and more clarity paired up with an Amp. If on a budget a CS60.4 makes sense, if you can stretch a bit then 75.4 sounds much better.
but my RockFord rock (6x9 comp) rock in boxes placed in boot and they never boom. i guess my boxes are quite good. and i've got 6'' comp (RockFord) in front but installation was bit tricky.
i'm running them directly off HU and no problem, they are loud and clear.
so if you are short of cash then drop amp idea.
Maybe you should look at a full change, maybe not, but no matter what happens the system has to be setup properly by someone who knows some tuning cos even the best stuff can sound bad when setup wrong, and even not so good stuff can sound good with a good amp and tune job.
i also agree with this suggestion.
overdose14 is offline   Reply With Quote
Need help for Friends getz 1.1 ICE setup in Pune hrishig In-Car Entertainment 3 28th January 2008 16:23
ICE Setup for Safari drifter In-Car Entertainment 64 3rd December 2007 12:36
Help for adding speakers to an existing ice setup shrayv In-Car Entertainment 3 20th June 2007 22:56
