Closed Thread
Old 9th October 2007, 16:04   #1
Smile Need Audio Help For Swift Zxi
Hi friends,
I am new to ICE setups.
due to some misleading suggetions i have installed these setting in my car.
but the sound is not that great and i feel no bass.
please suggest me how to improve my sound ( with amp , sub etc ).
my current setup is:
Pioneer 7950UB.
Front Door : 6.5" Philips 2way coaxial. (180 watts)
On the Back (Tray) : 6x9 - Philipes 3 way coaxial (350 watts)
please help me to improve my sound.
thank you.
rk
testing2000 is offline
Old 10th October 2007, 09:51   #2
navin's Avatar
Thanked: 4,265 Times
Pioneer 7950UB.
change speakers budget 8K+
add amp budget 7k+
add sub budget 5K+
let us know what your budget and musical tastes are.
navin is offline
Old 10th October 2007, 14:17   #3
Smile
thankx for the reply.
As of now my budget is 10k. and i want to upgrade the sub later some time.
please suggest me good but budget constraint Amplifer and speakers.
thank you very much.
rk.
Old 10th October 2007, 15:00   #4
Thanked: 11 Times
rk.
From Blaupunkt, i can suggest to go for
GTx 693 (3-Way, 6 x 9" Oval) - 3450
Front Door - GTc 542 (2-way component, 130mm) - 2450 or GTc 662 (2-way component, 165mm) - 2950
Amplifier - GTA 2 MKII (2 channel) - 3750
Krato is offline
Old 10th October 2007, 16:00   #5
panky12345's Avatar
Thanked: 147 Times
go in for JBL CS series (err....or now GT5 series) 4 channel amp. Retain your rear speakers; and upgrade to 607C front comps. a little overbudget but i think it should suit your tastes.
panky12345 is offline
Old 10th October 2007, 16:10   #6
Smile
i am chennai,
do u suggest to both the speakers? as i have installed just a week before.
by the way i dont know where this amp will be available in chennai.
any idea?
thanks
rk
Old 10th October 2007, 18:49   #7
testing2000, You can try CATS in GP road for JBL stuff. For contact number, you can check out the JBL ads in any of the Auto magazines.
You could try Radio warehouse as well, however, be prepared to bargain.
I am not qualified to advise on components :-), however, you could specify if you drive the car most of the time or you are driven.
d.kiran is offline
Old 11th October 2007, 11:49   #8
navin's Avatar
As of now my budget is 10k..
the Blau GT4 amp is a ncie one to drive front and rear speakers. If you send 6K on those you have 4K left which will fetch you the CS (not GT5) series components for the front. Like panky said you can change your rear speaker when you add a sub and monoblock.
navin is offline
Old 11th October 2007, 13:39   #9
mithun's Avatar
Thanked: 57 Times
Have you not seen this thread ?
http://www.team-bhp.com/forum/ask-gu...io-thread.html
mithun is offline
Old 11th October 2007, 14:35   #10
thanks guys.
as i am not able to replace the speakers which i bought from the installer.
he said he will take it back the front speaker and replace with the Philips component 260Watts. and planning to buy 554ZR(sony amp) because of budget constraints. is that ok to go? can i connect this amplifier to components and later connect the remaining channles to sub?
please clarify my doubt.
thanks.
Old 12th October 2007, 09:06   #11
Thanked: 11 Times
thanks guys.
thanks.
but you said that you have 10K budget in your hand. since you getting replacement for speakers, and the sony amp costs Rs. 5990 ( as seen on the sony website).. Sony India : XM-554ZR (XM554ZR) : Details
I would still suggest you to go for Blau or other options told to you by friends here in the thread with the remaining amount.
Philips might not give you the required quality
Krato is offline
Old 12th October 2007, 12:18   #12
Smile
thank you guys for your good advice.
i have one doubt, if i install any of these components in the front door.
they will cut the door for tweeter placements.
cutting will void any warrenty?
wats the best way to put this tweeter?
thank you.
Old 12th October 2007, 13:50   #13
navin's Avatar
they will cut the door for tweeter placements.wats the best way to put this tweeter?thank you.
THe person who has done more work on the Swift than most anyone here is our very own LBM. If oyu ask nicely he is a very helpful chap.
I would suggest either the A pillar or somewhere on the door.
navin is offline
Old 12th October 2007, 14:45   #14
Smile
LBM? i dont get it? you mean its is the name of the Member?
please give me his link?
thanks.
rk
Old 12th October 2007, 15:48   #15
Thanked: 294 Times
thanks.
rk
Ya thats me...
Which component kit you plan to put in your car ?
low_bass_makker is offline
Closed Thread
Used Swift Zxi with CNG or New Swift Vdi? somebodystopme Hatchbacks 17 29th November 2008 23:54
Need Help in selecting Audio for Swift RobertClive In-Car Entertainment 141 19th February 2008 11:06
Need Help! Problem after changing to K&N stock filter in Swift ZXi Lotusking Modifications & Accessories 8 26th November 2007 15:09
First timers Confusion : Swift VXI , Swift ZXI and Palio Stile 1.6 proverma Hatchbacks 17 18th July 2007 17:29
swift (zxi/vxi) is zxi vfm? karty_83 Hatchbacks 30 10th May 2007 14:32
