Old 1st October 2013, 23:21   #106
DRIV3R's Avatar
Thanked: 1,110 Times
Originally Posted by rajneeesh View Post
Folks, there is a problem with the fm reception of my SX4. I have had the HU checked by Nippon Auditronics and as per them it is fine. The CD player is just fine.
As per the technicians at Nippon, the problem could be with the antenna or the cables. SInce MASS I go to ( Motorcraft) is not comfortable to attending to ICE related issues, I would appreciate if you can direct me to some reliable ice service centre.
I am based in Noida.
If am not wrong, SX4 uses a printed antenna, on the rear windscreen.
Did you install any sunfilm on the rear windscreen? The ICE guy may not be able to help you on this.
DRIV3R is offline   Reply With Quote
Old 2nd October 2013, 16:04   #107
DerAlte's Avatar
Thanked: 2,876 Times
Default Re: SX4 ZXi - Integrated HU Audio Thread!!
... ( Motorcraft) is not comfortable to attending to ICE related issues, I would appreciate if you can direct me to some reliable ice service centre. ...
Any car accessories shop person would be able to check for cable breakage or connection opening out.
If there is a severe problem with the antenna on the rear windshield, as @DRIV3R says, you should replace it with an internal antenna mounted behind the RVM.
Old 2nd October 2013, 20:11   #108
Thanked: 297 Times
Thanks Driv3r & Der Alte,
No sun film on the windshield. I was worried about the feasibility of replacing the windshield in case it has a major problem. However, I like your suggestion of going in for an antenna behind the RVM.
rajneeesh is offline   Reply With Quote
New Integrated audio system for i 10 sidindica In-Car Entertainment 19 17th March 2015 18:16
Adding USB, Aux & Bluetooth to integrated in-dash audio system JLN In-Car Entertainment 6 29th September 2014 14:08
SX4 Zxi or ANHC? EDIT : Bought SX4! abhi182 Sedans 153 21st December 2009 15:54
Swift to SX4 - Booking a Black SX4 Zxi - Some queries on Pg3 joy_swift Sedans 68 28th August 2009 16:08
How about mobile ph integrated with stereo in SX4? sathya_nars Modifications & Accessories 5 4th July 2007 12:13
