Old 23rd October 2007, 11:01   #16
Shan2nu's Avatar
Thanked: 89 Times
Toe in the M34i so that their axis cross about a foot in front of you.
1 foot in front is it? How does it make a diff compared to having the axis right where you sit? I thought music sounds best when the speakers are placed in-line with the listener.
Is the axis position diff for stereo, 5.1, 7.1 etc?
And where should the axis for the surround speakers be? Slightly behind the listener?
stick the sub in the center of the 2 speakers about 2 feet form the rear wall.
Will this work with a 5.1 setup as well? If so, then the sub has to be placed between the surround speakers right?
Shan2nu
Old 23rd October 2007, 11:04   #17
Shan2nu's Avatar
Thanked: 89 Times
Wouldn't it be great if speakers could come with tiny lazers. This way, you could actually see where the axis is, instead of guessing it. Lazer guided speakers!!! Hehe
Shan2nu
Old 23rd October 2007, 11:08   #18
Bass&Trouble's Avatar
Thanked: 71 Times
There is no rule. I don't know about the 1 foot in front of the listener, but Navin certainly is the champ in such matters. In a lot of cases, speakers sound just fine without any toeing-in. If there is too much reflections off the side walls, then toeing-in helps.
By 'rear wall', Navin means the wall behind the speakers. i.e. the wall in front of the listener. I think you misunderstood it to be the wall behind you.
Old 23rd October 2007, 11:10   #19
Thanked: 71 Times
Shan2nu
People do actually use laser pointers to place speakers.
Old 23rd October 2007, 12:46   #20
navin's Avatar
Thanked: 4,286 Times
Wow! and all I use are my ears. I wish I had laser pointers in my ears! Now that'd be something.
I happen to have heard the M34i (granted with different electronics) and know they are bright. By toeing them a bit more than usual you are compensating for the glare that is more obvious when you are listening on axis.
It is not diffcult to toe in for any position. Just move your chair 1 foot back after you have got the speakers toed in on axis. The toe in suggestion for for Rudra's speakers in Rudra's room with the music he listens to. Maybe I should have PMed him instead. I am sorry to have confused you, Shan2nu.
5.1/7.1 etc thrive on a diffused soundfield and delays. the same rules that apply to 2 ch stereo do not nessacarily apply to home theater.
For 5.1 etc... I always propose more than 1 sub as well as full range speakers in all of the 5/6/7 fullrange channels. Todays signals are far more sophiticated and thanks to advances in technology there is no need for compromises like there were in the days of LPs and cassette. To enjoy the effects of modern movies one needs speakers that are capable of reproducing all that is recorded.
Old 23rd October 2007, 13:03   #21
Thanked: 71 Times
Yeah. You in drag on the Brooklyn bridge with laser pointers in your ears. Sure that would be something!
Old 23rd October 2007, 13:22   #22
Shan2nu's Avatar
Thanked: 89 Times
By full range do you mean that all speakers should be of the same model and size? Coz my surround/center speakers are of the same model but they're tiny compared to the front main speakers.
This is not my room, but i have the exact same setup including sub and amp.
Shan2nu
Old 3rd January 2013, 14:47   #23
swarnava.m's Avatar
Thanked: 268 Times
Default Re: Need help understanding subwoofer controls.
Bumping up a very old thread.
I am getting a Focal Solid 4 amp for my ICE now, yet to receive it. I can see that it has an RJ45 port, and it is for remote subwoofer control. I have attached a photo of the same.
I did search on TBHP and Google it, but could not find anything relevant that shows the subwoofer control unit that I can use with this. A friend of mine told me that the unit can be used to turn the sub on/off and also control the level, but beyond that even he doesn't have much idea.
Any help?
swarnava.m is offline   Reply With Quote
Old 3rd January 2013, 17:25   #24
97_Octane's Avatar
Thanked: 76 Times
Yes, that port is meant for the wired bass controller. I have a Focal Solid 1 (which is a mono) and the controller is connected to this port. It provides remote gain level control for the subwoofer.
This is the only info I have about this (I've begun my ICE ordeal quite recently, so still a learner ). AFAIK, the controller is only supplied with monoblocks and not 4 channels (atleast here). You could try sourcing a universal controller (Scosche has 1 but not sure if its available in India) and see how it goes.
97_Octane is offline   (2) Thanks Reply With Quote
Old 3rd January 2013, 18:04   #25
swarnava.m's Avatar
Thanked: 268 Times
Many thanks. Could you kindly post a picture of the controller that you have?
Old 3rd January 2013, 19:00   #26
97_Octane's Avatar
Thanked: 76 Times
I don't have a pic of it with me. But this is the exact same one I have:
97_Octane is offline   (1) Thanks Reply With Quote
Old 3rd January 2013, 21:34   #27
car_crazy1400's Avatar
Thanked: 204 Times
Well. I have both Focal solid 1 mono amp & a Solid 4 amp as well. Got wired remotes and connecting wires with both of them ( as mentioned on the packaging box).
The remote is used to control gain levels for the subwoofer in both amps.
Will control woofer levels in Solid 4 if both the rear channels together, in mono, are connected to a subwoofer.
car_crazy1400 is offline   (1) Thanks Reply With Quote
Need help deciding on a JVC Subwoofer and Amplifier ghpk In-Car Entertainment 31 25th April 2012 03:51
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
need help for subwoofer on JVC KS-F171. amit_mechengg In-Car Entertainment 11 13th February 2008 16:38
Controls in electric car sbasak Technical Stuff 4 20th December 2005 18:46
Need help in making my subwoofer box libre sito In-Car Entertainment 6 27th August 2004 23:24
