Old 26th October 2007, 17:26   #1
Default reparing woofer voice coil??
Hi frends,
Can u plz suggest if its worth repairing the voice coil for subwoofer...one guy is selling his woofer and said the voice coil needs to be changed...he said it will cost arnd 300-400 bucks to change the voice coil....
I wanted to know if there would be any change in the music quality by locally changing the voice coil...is it possible to change the voice coil??
wat do u guyz think....how much would it affect the quality of sound??
devp24 is offline   Reply With Quote
Old 26th October 2007, 17:51   #2
panky12345's Avatar
Thanked: 149 Times
its very much possible to change the voice coil, the SQ would not be same....it'll deteiorate.
Old 26th October 2007, 17:52   #3
Thanked: 294 Times
which sub-woofer do you have ?
Old 26th October 2007, 17:57   #4
Thanked: 37 Times
Default Its possible,
Originally Posted by devp24 View Post
Hi frends,
But this change will replace the OEM voice coil and
1. Hard to match impedance of OEM.
2. Voice quality will be degrated if not properly fitted (diameter of coil and space). It should not rub anywhere from inside.
3. Voice coil is fitted in exact middle location of max magnetic field. So it will be sensitive. Same time full displacement of cone should be achieved (called Xmax).
4. Quality of adhesive must be good and used with proper quantity. Otherwise it will blow out.
5. Are you replacing cone, spiders too?? It will also affect Xmax and audio quality.
6. Finally quality of voice coil will have impact on RMS Wattage and heat dissipated by it.
OOpps... decide now
omishra is offline   Reply With Quote
Old 26th October 2007, 17:58   #5
panky12345's Avatar
Thanked: 149 Times
OOpps... decide now
given all that, buying a new sub would be recommended.
Old 26th October 2007, 18:13   #6
thanks for the quick reply guys...really appreciate that...
the woofer is Audiobahn....after hearing the suggestions from u all...i think its better not to go for the woofer....so i will probably wait for some other good deal..
thanks a lottttttt
JBL Speakers, Doubel coil woofer, Sony 4 channel amp for sale worrisomebear Shifting gears 10 12th January 2008 14:23
Focal speaker voice coil smooshed. Need help!!! cleansound In-Car Entertainment 7 28th December 2007 13:25
Need info on reparing these speakers. binz In-Car Entertainment 10 19th November 2007 13:42
Blaupunkt Speaker - BG 693 - voice coil - rough base sound vipul_bscity In-Car Entertainment 2 31st July 2007 15:19
Oops Intel voice-activated remote-control fails on vice president adya33 Shifting gears 2 1st April 2006 08:25
