Old 1st November 2007, 11:32   #16
navin's Avatar
Thanked: 4,257 Times
Originally Posted by overdose14 View Post
when we power 2 sub 300 get divided into 150 right ?
this i wanted to clarify and some monoblock (Rockford) says bridgeable
how come ??
yes 300/2 = 150.
you cant bridge a mono amp. must be a typo.
My Bad, i forgot about that.
and in DVC sub, each coil is rated half of total power rated???.
two sub irrespective of brands and feed them with same amount of power then what difference can we expect in terms of SPL.
i know SQ would differ but what about SPL.
usually DVC subs are speced with both coils i parallel so yes each coil would take half the power.
you take 2 different subs and feed them the same power, the output will depends on their specs. their sensitivity. their Fs, Vas, Qts, Bl, Mms, Cms, etc...
i've decided if dad give me more money then i'll go in for cs 60.4
the 60.4 is a marginal amp when it is used for driving a sub. it is much happier driving 6" speakers. for about the same money as a 60.4 you can get the Pio D510 monoblock which will do a better job with as sub.
navin is online now   Reply With Quote
Old 1st November 2007, 18:29   #17
ScarySkulls's Avatar
Thanked: 19 Times
D510 available for 9k or so. Check at Bansal for more.
ScarySkulls is offline   Reply With Quote
Old 7th June 2009, 00:51   #18
Since the minimum speaker impedance for bridged operation is 4 ohms in GTO75.4, if you have already zeroed on this amplifier, Use a single voice coil of your DVC and leave the other voice coil unconnected. So you got exactly 4 ohms now.
Raghu-A4U is offline   Reply With Quote
Old 7th June 2009, 11:55   #19
live2drive's Avatar
Thanked: 25 Times
^^ Buddy you have replied to 1.5 yr old post.
You will end up blowing the sub this way.
live2drive is offline   Reply With Quote
The Little Rann of Kutch-Gujarat is everything but little: Photologue robimahanta Travelogues 35 22nd April 2014 12:52
Safari Dicor & Little Rann Of Kutch Experience (Tata Motors Full Throttle) avanishphatak Travelogues 2 22nd June 2013 23:41
Question on Amp & Volt for powering up device pradipk In-Car Entertainment 8 24th June 2009 15:36
Some little news about the next gen nissan GTR _Crazi4Speed_ The International Automotive Scene 0 21st September 2004 01:31
