Old 30th October 2007, 12:20   #1
overdose14's Avatar
Question Little question about amp
hi
i was going through JBL web site and stumbled upon cs 300 monoblock
it says that it can run 2 subs, now that is ok but max rms it can belt out is 300 and connection diagram in manual shows 2 sub attached and there were 2 20A fuses.
when we power 2 sub 300 get divided into 150 right ?
this i wanted to clarify and some monoblock (Rockford) says bridgeable
how come ??
and
last one i am having Pioneer 307 D4 and want to max it out i.e how much rms can it handle without blowing coils
and what is the performance difference between a 4 or 2 channel amp and a monoblock in terms of SQ and power.
thanks
overdose14 is offline   Reply With Quote
Old 30th October 2007, 13:03   #2
blueraven316's Avatar
It would be safe to supply about 350 to max 400 RMS @ 2 Ohms to that sub. The 306D was a better sub in terms of Sound quality compared to the 307D.
Pioneers are notorious for blowing easily with some raw power amps, thats primarily because they are loud subs at a very reasonable price.
blueraven316 is offline   Reply With Quote
Old 30th October 2007, 13:11   #3
overdose14's Avatar
THANKS
and if i had to choose an amplifier for that what would be your pic
and i'm not changing the setup anytime soon.
cause i'm loving my RockFord components and sub is also good but all i want is little more bass.
i've learned a lesson that always have some extra cash while buying a sub and amp.
Old 30th October 2007, 13:16   #4
If you looking at complete VFM, then the JBL 300.1 would be fine, you can get it for some good discounts nowadays.
Old 30th October 2007, 13:25   #5
Sam Kapasi's Avatar
Thanked: 1,473 Times
You won't be able to find a CS300.1 - I don't think there are any left in the country.
Old 30th October 2007, 23:56   #6
overdose14's Avatar
so any other options any 2 channel or 4 channel amp which can be bridged into 2 channel
Old 31st October 2007, 08:13   #7
ScarySkulls's Avatar
Thanked: 19 Times
Why not GTO75.4?
Runs nice. And costs 8.5k in grey market
ScarySkulls is offline   Reply With Quote
Old 31st October 2007, 08:52   #8
overdose14's Avatar
Originally Posted by ScarySkulls View Post
Why not GTO75.4?
but i will can run only in 3 channel mode not 2 channel
thats what i wanted.
or any 2 channel amp which can run 2 ohm stable.
Old 31st October 2007, 10:01   #9
Sam Kapasi's Avatar
You can run almost all 4 channel amplifiers in 2 channel OR 3 channel mode.
It simply depends on whether you bridge one channel, or two.
Old 31st October 2007, 16:41   #10
overdose14's Avatar
My Bad, i forgot about that.
and in DVC sub, each coil is rated half of total power rated???.
and for eg we take two sub irrespective of brands and feed them with same amount of power then what difference can we expect in terms of SPL.
i know SQ would differ but what about SPL.
Old 31st October 2007, 16:46   #11
rocksterraghu's Avatar
Thanked: 97 Times
Why not the Pio Monoblock? Heard one yesterday, sounded decent.
Old 31st October 2007, 22:43   #12
Thanked: 19 Times
Yes. they should be half to total power handling each.
Regarding your second line, does that mean you are considering two different Subs? If same models then, I dont think there will be any difference in SQ.
SPL should be close to double.
Old 31st October 2007, 23:29   #13
Thanked: 19 Times
I'm so sorry dear.
Just noticed. You have the 4ohm coil version of the 307.
Sorry. GTO75.4 wont work as it supports minium of only 4ohm when bridged.
And with your current sub, you have only two options. 2ohm when wired in parallel or 8ohm in series.
Old 1st November 2007, 07:40   #14
overdose14's Avatar
I'm so sorry dear.
i've decided if dad give me more money then i'll go in for cs 60.4 as i won't be changing my setup soon( 1-1.5 years) and for Pio 307 300rms would be more than enough.
i'll be very thankful if someone can get me its price quote without b/W
Old 1st November 2007, 08:24   #15
JayD's Avatar
Thanked: 2,008 Times
I think 60.4 has been stopped. So whatever is left will be the leftover stock. Try to get them for a lower price
The Little Rann of Kutch-Gujarat is everything but little: Photologue robimahanta Travelogues 35 22nd April 2014 12:52
Safari Dicor & Little Rann Of Kutch Experience (Tata Motors Full Throttle) avanishphatak Travelogues 2 22nd June 2013 23:41
Question on Amp & Volt for powering up device pradipk In-Car Entertainment 8 24th June 2009 15:36
Some little news about the next gen nissan GTR _Crazi4Speed_ The International Automotive Scene 0 21st September 2004 01:31
