Old 30th June 2009, 18:33   #211
Flying Bong's Avatar
B&T/FB/LBM,
Did either of you guys have trouble integrating the horns HF section with the conventional midbass. In FB's case his horns do duty between a conventiona midbass and "super tweeter". In my experience I found that exponential horns gave the sound a very different timber that could not be matched by a conventional bass system making the horn feel more "in your face" and the bass section feel laid back.
Well, till now, as far as output/timbre matching b/w horns and midbass goes, things sound pretty fine, atleast to my ears. The Dyns are pretty dynamic and agile sounding drivers which should get better as they break in. They are getting enough power too, I think, to avoid running out of steam before the horns at all sane listening levels.
Maybe it is often the kind of music one listens to. Many forums have had users of horns complain that horns are great for pop/rock and stuff that demands a dynamic system but can be painfull on strings, horns and brass instruments
Have been mixing genres over the last few days and nothing so far has stood out as ragged or unpleasant. Bad recordings are NOT blessed by the system but that's a different story.
I will update once the midbasses break-in and tuning is complete....
Flying Bong is offline   Reply With Quote
Old 1st July 2009, 15:00   #212
navin's Avatar
Thanked: 4,286 Times
I am assuming the horns you have use compression drivers.
Thanks for the feedback FB. Did you feel the need for a super tweeter? Also with the super tweeter so far from the mouth of the mid-hf horn do you hear any comb filtering?
Old 1st July 2009, 15:45   #213
The supertweeters kick in at 10khz. Would any comb filtering occuring at these frequencies and beyond be audible? Am guessing I would have to first deal with bigger and more audible potential comb filtering issues due to PLD b/w left and right midbasses, horns and reflections from various surfaces in the car. Please correct me if my understanding is wrong.
Old 1st July 2009, 16:12   #214
Thanked: 294 Times
Since the P80 has three way setup. How is the Super-tweeter working ?
Old 1st July 2009, 17:28   #215
Hertz HT20R supertweeters have been installed in the sail panel running off the HU via supplied passives.
Sorry should have posted this separately...
Old 1st July 2009, 19:39   #216
sk456's Avatar
Thanked: 7 Times
Darn it..should have insisted on the demo the other day. Now curiousity will certainly kill the cat.
sk456 is offline   Reply With Quote
Old 1st July 2009, 21:04   #217
frankmehta's Avatar
Thanked: 2,334 Times
DAYUUUUUMMN bong. I covet your setup! Even more than the fact that I need a new car badly!! my most favourite component in your car has to be a tough toss up between the Mille Sub (they dont make them like that anymore) and the Genesis Dual Mono. The Dynaudio midbasses are power hungry and the best way to power them is to give them over 300W each!
shucks Bong, I absolutely got jolted out of my sleep on seeing the nirvana that your system is!
cheers!
Old 2nd July 2009, 02:41   #218
rider60's Avatar
Thanked: 47 Times
cheers!
hmmm... typical and most common feeling on ICE section, i share the same thought and feeling on looking at bong's setup, heck this kind of audiophile grade components is only a dream at the moment for me, hope this materials one day for me.
awesome setup flying bong. Congrats.
rider60 is offline   Reply With Quote
Old 2nd July 2009, 09:59   #219
navin's Avatar
2. yes all those reflections are going to pose a greater issue than comb filtering. in a more critical enviroment comb filtering etc.. would be more audible. Remember comb filtering is more noticeable near field than far field. The car is a near field enviroment.
1. There is some research that shows that if the drviers are located at a distance that is more than L*10 where L is the wavelength then comb fitler effects are really diminished. assume F=10K, c=340m/s, L=340/10K=3.4cm. So if the drivers are 34cm apart the comb filtering might not be noticeable even in a more critical enviroment.
This reseach cam to light when experiements for configurations of center channel speakers (for HT) were being conducted.So a config that was T MM T where the Ts were say 160cm (2K XO) apart showed little audible comb filtering.
I have answered in reverse and it makes more sense that way.
Think of it this way.
Mile Sub = 20 RCs with caps
Genesis Mono = 30 RCs with caps.
with appologies to dentists everywhere.
When you graduate I am gonna give you a laminated version of this
The Crocodile's Toothache - Shel Silverstein
the video
Old 2nd July 2009, 10:59   #220
Thanked: 39 Times
Frank, you run Eclipse CD7200MKII, DLS Reference RA20 and Genesis P1 in your car, and you aren't even a graduate?! Dayummnnnn man!
greenh0rn is offline   Reply With Quote
Old 2nd July 2009, 15:02   #221
Coming weekend hopefully...
cheers!
I am running a DM not a DMX
Yeah Mille sub is a gem....not parting with this one....ever.
Thanks for clarifying this so lucidly
Old 7th July 2009, 20:23   #222
hydrashok's Avatar
Killer setup, FB! Good to know you found the holy grail at last. The setup must sound heavenly! *envy*
Old 7th July 2009, 22:03   #223
karankapoor's Avatar
Damn how i had missed this, Fabulous upgrades was waiting for this to happen. Do write about the difference you feel between the 2 CHAMELEON"S and DYNA'S i know it lill funny to compare both but will love to hear it.
Congrats !!!
karankapoor is offline   Reply With Quote
Old 8th July 2009, 11:12   #224
Congrats !!!
Thanks. Dyn midbass driver is more articulate than the Chameleons but at the same time sounds more natural, across the frequency range. Midbass in particular is fast and snappy, and there is lots of it
Old 10th July 2009, 21:35   #225
Gill's Avatar
Thanked: 12 Times
Congrats Mate! Must be close to Nirvana!
Dyn mid-bass is a direct fit to the slot or slot needs some adjustment?It's 7".
Gill is offline   Reply With Quote
Delhi/NCR-walas in Bong-land - New Year Meet - 1st January 2010 planet_rocker The Team-BHP Meet Section 11 2nd January 2010 12:48
Fatal3rror & Shrivz (Driving down from Pune) & KD the Bong in Kolkata - The Mini Meet planet_rocker The Team-BHP Meet Section 16 15th September 2008 09:53
Another bong in our beloved bangaluru protege Introduce yourself 10 12th April 2005 01:03
