Old 12th November 2007, 23:55   #16
blueraven316's Avatar
Originally Posted by blueraven316 View Post
Yellow tops are notorious for dying , they are no good for car audio applications, I have had 4 bats die till date, so have stopped suggesting them to people, my cousin's battery died and he has not yet got a replacement.
Another thing to add to this, I have been running on a Stinger SP1000 Battery for the last 1.5 Years and it has been running rock solid, no problems yet and I have a lot of load on it with the system and Neons all around.
what is the gauge of wire from the alternator to the battery?
@ Raghu, this is another thing that can change the way things are. It is not necessary that your car battery has to give up with the music system you are running. There are a lot of cars with such systems today, and not all bats fail.
blueraven316 is offline   Reply With Quote
Old 13th November 2007, 00:00   #17
Thanked: 294 Times
Raghu try this. Get a multimeter and connect it to the cigarette lighter socket. observe the voltages. What do you get normally. Now don't play your ICE for one day(atleast 2-3 hrs) and see that is there any rise in voltage.
Do post all your reading.
For the optima they are **** batteries and I did not got any replacement also. Instead I got three batteries after having a fight with the dealer.
I continuously monitor my car voltage through the voltage monitor it helps a lot when some time I turn to the dark side (SPL) as dips will bound to happen. Also I have not seen a single car install which has amps and there is no dip in voltage even playing at moderate levels otherwise if there is no dip then it is not normal !!!
Old 16th November 2007, 03:02   #18
rocksterraghu's Avatar
Thanked: 98 Times
I guess they're stock wires.
Thanks Blueraven and LBM.
I am in Hyderabad now and will be back in KK very soon. I'll post the details very soon.
Thanks to everyone who has contributed. I really appreciate it.
rocksterraghu is online now   Reply With Quote
Old 16th November 2007, 10:50   #19
navin's Avatar
Thanked: 4,286 Times
why not upgrade this wire, it is short and any good ISI brand wire will do.
Old 16th November 2007, 12:43   #20
tsk1979's Avatar
Thanked: 16,422 Times
What is the alternator rating. For example the indica alternator is 90A.
If your consumption goes higher than that you will have problems. No other solution except get a bigger spec alternator.
At idling speed with AC and headlights on, a good alternator will give around 13V to the battery terminals. If you are falling below this, its a problem.
If this test passes, switch on the stereo system too and see the voltage at the battery terminals. If it falls below 12.8 it means your alternator is unable to charge the battery at idle.
If your battery is the issue get a higher spec battery which will give you longer playing time at idle. For example stock batteries in diesels are 55Ah, I got a amaron 65Ah and am very happy with it.
Old 8th January 2008, 00:10   #21
Thanked: 98 Times
Finally! Finally found time to get this fixed.
I got the alternator checked and it was supplying 14+ at about 1000 rpm.
Decided not to fiddle with it.
The culprit was the battery. Got a replacement for it and everything is back to normal. Hurray! The ICE sounds (especially the sub) much better and I am thrilled.
Thanks everyone for your time and effort, I really appreciate it.
Cheers!
Oh No! Exide battery woes again GTO Technical Stuff 331 26th June 2018 12:15
Battery Woes! sparkglow Technical Stuff 31 5th August 2017 13:10
Maruti 800 battery woes-urgent help required fergus Technical Stuff 11 27th August 2011 21:01
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
