Old 18th April 2009, 22:52   #16
Thanked: 443 Times
Originally Posted by pedrolourenco View Post
What's the location of the mic. Is it in the HU itself or external. I saw a photo somewhere of a external mic mounted on the drivers visor.
As I had mentioned, the mic in MP 57 is external. You can clip it wherever you want. Mine is mounted on the A pillar. Catches the voice quite well and causes no interference whatsoever.
directinjection is offline   Reply With Quote
Old 18th April 2009, 23:35   #17
Thanked: 152 Times
@pedrolourenco : I had recently got a music system installed in a friends car .Now we had initially planned for pioneer 7150 .Since it was not available that day the dealer said you try hamburg MP57 .If you do not like it then i will change it to Pioneer.
My review is it Blaupunkt is good on sound but navigating through its menus is a pain , time consuming .Also the said Bluetooth is not even A2DP compatible.It has a three band equalizer .Also not flashy at all.
So all in all we got it changed the very next day .(within 16 hrs).So i will suggest you try it out then make up your mind.
Also with this Blaupunkt is also giving some speakers free .(i guess they were 4 inches) were good enough.Also the cd mechanism in Blaupunkt is very abrupt and not smooth.
Trust_In_Thrust is offline   Reply With Quote
Old 19th April 2009, 00:44   #18
navin's Avatar
Thanked: 4,286 Times
The remote is currently out of stock.
price wise the deal is good. the only question is the out of stock remote. make sure you get that remote beucase it really is a nice addition.
Old 19th April 2009, 09:23   #19
pedrolourenco's Avatar
Thanked: 617 Times
The catalogue mentions that the MP57 is A2DP compatible. However the dealer said it is not. You can however access your phonebook from the HU.
pedrolourenco is offline   Reply With Quote
Old 4th May 2009, 21:04   #20
Thanked: 617 Times
This is the setup I'm planning.
The subwoofer and RC10 remote will be done later.
Old 3rd July 2009, 20:04   #21
Thanked: 617 Times
Was supposed to install today. But the front components have not arrived. Probably arriving tomorrow.
Old 3rd July 2009, 20:57   #22
Thanked: 32 Times
Have you treid St.Louis HU instead of Hamburg. I was auditioned these combination & found St.Louis very clear. The showroom guy said its because of an inbuilt equilizer. Check if you can.
kiren is offline   Reply With Quote
Old 4th July 2009, 09:36   #23
Thanked: 617 Times
Actually I selected the Hamburg as it was the cheapest Blau HU with a USB port.
Old 10th July 2009, 23:16   #24
Thanked: 617 Times
Here are the snaps of the install.
Old 10th July 2009, 23:24   #25
Thanked: 617 Times
Some more snaps. Mods please merge these 2 posts.
Old 13th July 2009, 11:03   #26
Thanked: 617 Times
The HU is not reading from an 80GB hard disk. No problem with flash drives. Any idea what to do?
Old 13th July 2009, 12:01   #27
ms001's Avatar
Thanked: 63 Times
did you install the sub also? how much did it cost and how is the performance
ms001 is offline   Reply With Quote
Old 13th July 2009, 15:40   #28
DerAlte's Avatar
Thanked: 2,879 Times
@pedrolourenco, check the manual. Page 13/14.
Blaupunkt Bahamas MP34 query nishantgandhi In-Car Entertainment 21 30th July 2010 18:47
Blaupunkt Hamburg MP57 rkavthekar In-Car Entertainment 5 27th January 2010 10:41
Kenwood6539/Hamburg/Kingston/Alpine 9884e/6, I'm totally confused. F1. F1.. F1... kaushik_s In-Car Entertainment 11 16th March 2009 15:45
Blaupunkt mp57 vinodbijlani In-Car Entertainment 2 11th July 2007 22:54
Blaupunkt 4-ch Amp, Blaupunkt ODx 6x9 3-way coaxials & 6.5" 2-way coaxials for sale hydrashok Shifting gears 3 16th March 2007 16:43
