Old 21st January 2008, 12:07   #136
navin's Avatar
Thanked: 4,286 Times
Originally Posted by low_bass_makker View Post
Gunbir Phaji it is a co-ax driver. The tweeter is set inside the cone midrange.
IN early 1998 Theil Loudpseakers revelaed a simialr unit.
a cutaway diagram is shown here
THIEL
Old 21st January 2008, 13:26   #137
Thanked: 21 Times
Thumbs up
Yes sir! In fact as you would have already guessed, the Genesis Studio 16 set uses drivers from Theil, optimized for car audio, while the crossovers are designed and made in UK by Mr. Gordon Taylor of Genesis. And his Absolute series use the SS Revelator drivers, again with his crossovers.
Old 21st January 2008, 14:33   #138
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by Autophile View Post
There are lot of drivers which can do this including the one mentioned below. But the question is can they be used in Car Audio Environment successfully.
FYI : "Manger Bending Wave Driver" 80Hz - 35KHz
Makes a lot of engineering sense.
How much does a pair cost? Since price is normally directly proportional to manufacturing tolerance and rarity of materials, one would expect this one to follow the "if you ask, you can't afford it" principle.
Has anyone heard it in action? Does it produce music or is the effect something like drinking distilled water? Like @santosh (where has he vanished?) had pointed out quite a while back, we are used to obvious 'distortions' in our perception of music reproduction. For example, though valve amplifiers produce more distortion than an equivalent power semiconductor version, I'd rather root for valve-amplified guitar than the tinnier 'true' sound of silicon-amplified ones.
Old 21st January 2008, 15:59   #139
Thanked: 294 Times
It all depends on what type of music taste one has. I had a old 3055 Transistor based Amplifier. It was using a Pair for each channel I used to love its sound. Never had the experience of a tube amp. But having seeing them since childhood as my father to had a hobby of electronics like me.
Old 23rd January 2008, 04:36   #140
AnniHilat0R's Avatar
Thanked: 24 Times
Default Clarion FB278RBT HU
TUNER SECTION
Frequency Bands FM: (MHz) 0.05 MHz steps 87.5 to 108
FM Usable Sensitivity (dBf) 11 FM 50 dB
Quieting Sensitivity (dBf) 17 FM
Alternate Channel Selectivity (dBf) 75 FM
Stereo Separation @1 kHz (dB) 25
FM Stereo Freq. Resp. @ 3 dB (Hz) 30 to 15,000
AUDIO SECTION
Power Output (DIN45324, +B = 14.4 V) 4 25 W
GENERAL
Dimensions (W H D), mm 178 50 152 Weight (kg) 0.6
Power Consumption: less than 15 A Speaker Impedance 4Ω (4 Ω to 8Ω allowable)
Source:Clarion UK | FB278RBT
AnniHilat0R is offline   Reply With Quote
Old 23rd January 2008, 10:20   #141
navin's Avatar
I have played with the Magner driver quite extensively.
1. the driver is really only usable above 300Hz
2. It needs a rahter complex filter ad it has some anamolies in it's response.
coupled to Vifa PL or SS 8" woofers it does make good sound especially if you listen to western classical.
conclusion
not quite the holy grail - then again I am still searching. I wish it was more revlealing like the Visaton B200 but then I wish the Visaton had the dispersion of the Manger and I wish both the Viaston and Manger had the HF response of even the lesser SS/Seas tweeters.
Der Alte,
Good wide range drivers have limiations. What might be the best option is to use a wide range driver as a midrange using the ability of the wide range to operate over 6 octaves or so to escape using complex crossovers (active or passive).
One idea that is brewing in my head is:
sub 100Hz Bass driver using a SS amp perferably is dipole (to reduce boom)
wide range from 100-6K but with a smooth roll off in the HF and hence requiring only a 2nd order Passive Line Level (PLL) low pass filter and a UL tube amp
leaf or ribbon or eliptoical tweeter operating above 6K or so using 2nd order Low pass PLL and a triode tube amp
but we re now seriously OT and this topic would be better covered on another forum (audioasylum, diyaudio, etc)
Old 26th January 2008, 15:43   #142
scarlet.fever's Avatar
Thanked: 25 Times
Could anyone update me whether GTO504/GTO1004 have been launched in India ?
scarlet.fever is offline   Reply With Quote
Old 26th January 2008, 16:01   #143
Vid6639's Avatar
Thanked: 21,083 Times
Yes I believe they are now available. It's mentioned in this month's JBL ad behinde ACI magazine.
Old 26th January 2008, 19:22   #144
Thanked: 21 Times
Cool
Originally Posted by ScarySkulls View Post
:-)Yes, Audison makes entry into Absolute SQ speaker category.
Well here is some more on that...
And now, the Audison "Bit One" processor...
Old 26th January 2008, 20:56   #145
DerAlte's Avatar
Look nice! Are the specs on the 'net yet? The Bit One looks mysterious.
What is that in the dust cap location? Mounting arrangement for selectable phase plugs? Tweet mounting a la Chameleons?
Sirji, how much will these set one back by?
Old 26th January 2008, 21:36   #146
Autophile's Avatar
Specs are yet to arrive. No the tweeter mounting options are not like ID chameleons / XS.
Autophile is offline   Reply With Quote
Old 27th January 2008, 12:19   #147
jesal's Avatar
car audio has come a long way for sure. gone are those pioneer and sony days now eh
jesal is offline   Reply With Quote
Old 27th January 2008, 14:34   #148
Thanked: 294 Times
More news here...
Board Message
Old 28th January 2008, 13:54   #149
RAC
RAC's Avatar
yes it has. i have seen it last month.
RAC is offline   Reply With Quote
Old 5th February 2008, 21:46   #150
what kinda sub's are comming out this year.....?!?! anyone's got an idea..?!?!
CAR_GOD_666 is offline   Reply With Quote
Daimler India Commercial Vehicles opens new bus plant, unveils new products Aditya Commercial Vehicles 18 17th July 2015 13:36
Right place to buy ICE Products in Dubai? kiku007 In-Car Entertainment 8 29th January 2011 10:06
New ICE Products In 2009 hellspawn In-Car Entertainment 52 21st January 2009 12:30
New ICE products for 2007. hydrashok In-Car Entertainment 175 20th January 2008 18:54
Products for 2008? anToNIcHeN In-Car Entertainment 1 29th October 2007 16:37
