Old 19th November 2007, 14:17   #16
amit_sound's Avatar
ya panky....actually i started thinking of upgrading that time only.
amit_sound is offline   Reply With Quote
Old 19th November 2007, 14:19   #17
amit_sound's Avatar
Originally Posted by blueraven316 View Post
Hmmm, this is a wild guess,
Pair of Digital Designs DD9100Cs ,
and a DDM-Class amp running @ 4 Ohms ?
good try......but i wish it were these.......
But a really good try
Old 19th November 2007, 14:21   #18
amit_sound's Avatar
But please do let me know, what u guys think of a good SPL system.
Old 19th November 2007, 15:01   #19
Thanked: 294 Times
How much DB are you expecting. And how much power are you putting in ?
Old 19th November 2007, 15:03   #20
ramie2400's Avatar
Thanked: 58 Times
I think you are planning for some Ground Zero SPL setup????
Old 19th November 2007, 15:17   #21
navin's Avatar
Thanked: 4,284 Times
Air displacement of the 15" is more than the 12". But the problem is that a box size of a single 15" will be very hard to fit in the boot of accent. Two 12" woofer box might just make space into the boot. But that will be tight too.
that is exactly what i was saying. before you upgrade it is better to conclude if the upgrae is going to be worth the effort.
2 12" woofers have a Sd of about 600-650cm2. One 15" has an Sd of about 430-450 cm2. so if both have the same Xmax then you get about 33% more air displaced. that will be a resoanble increase in SPL capability but if the 15" has a higher Xmax than the 12" then you might not gain that much.
navin is online now   Reply With Quote
Old 19th November 2007, 15:19   #22
Thanked: 294 Times
Hmm Ground Zero SPL sub...was talking with Ajay Bhai few day back he mentioned for a budget SPL install one can go for these subs.
:: Ground Zero :: Subwoofer / GZRW 30SPL
Priced around 16-17k price range. Not bad for a SPL sub.
Old 19th November 2007, 16:29   #23
amit_sound's Avatar
Expecting to hit somewhere around 150+ db. Would be putting in 3000 Watts RMS.
Old 19th November 2007, 16:30   #24
amit_sound's Avatar
Ground Zero!! definitely.....but only for battery i guess
Nice guess...
Old 19th November 2007, 16:32   #25
amit_sound's Avatar
Ya, i too met Ajay at the AV Mumbai expo. And if i am not mistaken the palio was playing this same sub. I hope i am right.
But 16-17k it certainly because a good SPL with tight budget.
Chalo aapne bola.....toh will consider this sub too
Old 19th November 2007, 16:43   #26
Thanked: 294 Times
Hmm they are quite different from those. They are priced 60k each and rated 4500 watts rms. But these babes are those on budget
Have you not finalize the Sub kya ?
Old 19th November 2007, 16:54   #27
hydrashok's Avatar
How about 2 x Fi BL series subs? (since you mentioned US...)
Or maybe RE SX series?
Old 19th November 2007, 16:58   #28
Thanked: 294 Times
Hmm Hydra yaar I think you like Fi subs ??
Old 19th November 2007, 17:15   #29
amit_sound's Avatar
Finalized....ordered and waiting for the babes to arrive
Old 19th November 2007, 17:16   #30
amit_sound's Avatar
Ya like i guessed Fi for LBM.....you guess the same me
Anyways wonderful brand it is. But it was a close one
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Best SPL system panky12345 In-Car Entertainment 37 29th October 2008 00:34
Its a bird....Its a plane...Its our Cycleman WhiteKnight Street Experiences 15 3rd September 2008 19:21
Pioneer SPL subwoofer for sale low_bass_makker Shifting gears 15 27th December 2006 20:07
