Old 29th November 2007, 15:27   #1
Lightbulb alternate way to install speakers at rear?
hello all,
is there any other way to install speakers at rear without cutting the rear parcel tray?
thanks....
sathya_j2084 is offline   Reply With Quote
Old 29th November 2007, 15:58   #2
bottle's Avatar
Thanked: 133 Times
what car ? most manufacturers provide the space to install speakers in rear
bottle is offline   Reply With Quote
Old 29th November 2007, 16:34   #3
ad75's Avatar
Thanked: 20 Times
a plank & spacer ring/s should help. ask your installer about it.
ad75 is offline   Reply With Quote
Old 29th November 2007, 16:42   #4
shuvd's Avatar
@ Sathya - There is. In my Optra I got the rear speakers mounted on slope like thingys. But, there is some drilling involved.
shuvd is offline   Reply With Quote
Old 29th November 2007, 17:08   #5
hemanthisgreat's Avatar
you can install the speakers in the doors, but depends on the car.
hemanthisgreat is offline   Reply With Quote
Old 29th November 2007, 22:08   #6
ram_hyundai's Avatar
Thanked: 48 Times
why not seperate boxes .or an mdf tray would do.there is space on dicky door in case of wr zen etc..specify the vehicle for apt solution .or else you can remove the rear tail lamp and fit them there.hehehe
ram
ram_hyundai is offline   Reply With Quote
Old 29th November 2007, 22:23   #7
Thanked: 294 Times
to install speaker most car manufacturer give space which has 5.25 and 6.5 inch as standard but if you want to install a 6x9 some car does come with that size but if not with that size one can use a MDF wooden spacer to mount them...
Old 29th November 2007, 22:23   #8
anonymous's Avatar
Thanked: 15 Times
ram
Hmm. Dicky door. I have seen few installations like this but how good and reliable is this?
Can this be done in Indica?
anonymous is offline   Reply With Quote
Old 29th November 2007, 22:33   #9
vebmetal's Avatar
Thanked: 15 Times
Um, before we go off on a tangent, why don't we wait for Sathya to enlighten us on which car he's talking about first?
vebmetal is offline   Reply With Quote
Old 30th November 2007, 21:05   #10
Magma's Avatar
Sathya
here is a pic of how i have installed it in my old car
its done with an MDF spacer ring on the sides of the booth.
i have found this arrangement very practical since it requires no MDF rear parcel tray and hence gives you a lot more bootspace(meaning you can stack up luggage over the level of the seat)
Also you need not worry about spoiling the speaker wire connections while loading luggage close to it
Also as the speaker is loaded within the car walls this acts like a kind of enclosed box itself.(this is my NOOB opinion dunno what the gurus wud think about it)
Magma is offline   Reply With Quote
Old 30th November 2007, 22:25   #11
bottle's Avatar
Thanked: 133 Times
he has a getz i think. he mentioned in another thead of his
Old 3rd December 2007, 08:24   #12
Lightbulb itz a getz!!!
my car is getz.the rear parcel tray is provided,but i dont wanna pamper it for installing speakers.Alternate ways?wat is behind the idea of using a wooden plank???
Old 19th December 2007, 18:01   #13
aks_karthik's Avatar
Thanked: 215 Times
u can use the 5 th door in the rear to accomadate the Rear Speakers.
But it might need to pierce the rear door protectors to place the speakers.
But the bass is not rich.Parcel Tray installation is good idea for GetZ.
aks_karthik is online now   Reply With Quote
Old 20th December 2007, 11:24   #14
DerAlte's Avatar
Thanked: 2,876 Times
@Magma's suggestion is very practical.
An alternative is to mount an MDF box above the wheel well projection - the speakers face the boot. Bass would be a factor of the size of the speaker you use. You could even think of using 6x9s there.
Rear Door Speakers for the RITZ. and the new install desideep In-Car Entertainment 0 22nd September 2010 08:51
Amp Install and Rear Speaker Replacement In Swift muneemmk In-Car Entertainment 35 19th February 2009 03:06
Innovative way to install ICE with CNG panky12345 In-Car Entertainment 8 4th November 2007 19:25
alternate way to fix neons on zen mclaren1885 Modifications & Accessories 11 17th August 2007 12:39
For HT front speakers - 2 way or 3 way ?? w 12 Gadgets, Computers & Software 3 4th September 2006 22:07
