Old 17th December 2007, 09:45   #181
navin's Avatar
Thanked: 4,265 Times
Originally Posted by JPL View Post
I also gathered the following from the DD website:
New Spiders: A new spider topology was developed to increase the linear suspension travel and further reduce sources of distortion. This dual spider design is capable of increased throw with necessary control at high excursion.
The suspension follows our philosophy of multiple spider layers for tight bass with low fatigue over the long haul..
1. notice they said dual. nothing about 4 or 5 spiders.
2. there is no need for extra ordinary knowledge of transducer design. dynamic drivers (conventional woofers and mids) use the same philosphy as the original Rice-Kellogg loudspeaker that was patented 50+ years ago.
If there are 2 or more spiders that are joined at the same location these spiders can be replaced by a single spider that has the same physical properties of the multiple spiders.
Old 17th December 2007, 11:55   #182
amit_sound's Avatar
And also Amit or Amits bro was told from the installer
"The reason he said to add more spider is that after 2 years of use the tightness of the woofer tends to reduce....To keep that intact they add more spiders to the same. But as i said, wait, a let me get it confirmed from the guy in US again"
Exactly, these were the same words!!
BTW...i have contacted DD, so expecting a reply from them soon.
amit_sound is offline   Reply With Quote
Old 17th December 2007, 15:50   #183
Bass&Trouble's Avatar
Thanked: 71 Times
Look what I found!
Team DD - Digital Designs
I love the last line.
Old 17th December 2007, 16:22   #184
amit_sound's Avatar
WOW!! COOL!! finally DD made me a member of their team
It had to be there
The game in on
Old 17th December 2007, 19:45   #185
moralfibre's Avatar
Thanked: 6,463 Times
Originally Posted by amit_sound View Post
It had to be there
The game in on
And none in India is even close to be compared to DD, so be sure that lot of people are going to go crazy after listening to it.
Amit, you made a statement like that even before you heard DD? I guess you haven't begun your install yet, have you? Or the Spiders are singing already .
Old 17th December 2007, 22:25   #186
Thanked: 13 Times
Incy Wincy spiders smashing the subs around
Down came the rain and washed the spiders to the ground
Out came the sun and dried up all the rain
Now can Incy Wincy spider push up the SPL again?
Ok that wasnt funny
Anyway, Amit congrats on the mention @ DD website. Good luck with your endeavor of bringing the cult to India.
Also I would suggest you invest in someones education as an Otologist
Old 18th December 2007, 00:08   #187
amit_sound's Avatar
Woofer box will be like this:
You see this is hand made too
Old 18th December 2007, 00:13   #188
amit_sound's Avatar
Ok, buy me a pair of Z series DD woofers and 6 Z1 amps to go with it and some performance batteries....It certainly would break some necks and heads.
Then i shall invest in someones eduction as Octologist, to get neck and head fixed.
Deal?
Old 18th December 2007, 00:14   #189
navin's Avatar
if each "wing" is 13" and 2x 13" = 26" and the port is 6" wide 26+6 = 32" you dont have much between the "wing tip" and the side walls.
also the "wing" is only 3" from the rear wall meaning that the port starts at the "wing tip".
your effective port length will then be 15"+13" = 28". A bit long. Please check the numbers.
Old 18th December 2007, 00:34   #190
amit_sound's Avatar
Arey rey rey....my typing mistake... that "wing" is not 13", its 3".
So it a 3" wing. Thanks, navin ji for bringing it to my notice...
So its 15" (port depth) + 3" (wing)+ 1" ( MDF thickness) = 19"
Old 18th December 2007, 00:34   #191
Thanked: 13 Times
Otologist baba, ear specialist !
Old 18th December 2007, 00:53   #192
amit_sound's Avatar
Oh!!...again my bad one.... I did not have a very good day today
1) Slipped in the office and sprained my ankle
2) Got a oil-pin poked in my hand today, so got a Tetanus injection for it
3) Also missed my lunch at office....work load
4) Missed a totally "khali bus in Mumbai" to vashi at 8 in the evening
5) Made a typing mistake in the woofer box diagram, 3" ko 13" likh diya
6) Made a new definition for Ocologist.
All in all, a bad Monday :(
Ok, so coming to ears specialist, again it holds true, buy me two z series woofers + 6 Z amps + performance batteries ....i'll pay for education and my ears are yours....hehehe
Hope this post does not have any more mistakes.....Goodnight, hope tomorrow is good.
Old 18th December 2007, 09:42   #193
navin's Avatar
Oh!!...again my bad one.... I did not have a very good day today.
dont worry. I am sure that pair of DDs will cure that.
Old 18th December 2007, 15:56   #194
Hi Amit
Well Pankaj Bhai too is very curious on ur set up, do let me know when do u plan to visit him so that I too could be there in its inception stage
chao
cancerm is offline   Reply With Quote
Old 18th December 2007, 18:30   #195
amit_sound's Avatar
Originally Posted by cancerm View Post
Hi Amit
Certainly Sir, will let u know the next time i plan to come down to Pankaj bhai.
PM me your contact details..
Viase i might come there next week to start ONLY the damping....probably will car the equipment if you wanna have a look at it.
Cheers,
Amit.
Good SPL Sound Jas6789 In-Car Entertainment 34 30th May 2011 22:15
New Products for 2006 - Stuff to look out for gunbir In-Car Entertainment 131 1st February 2010 19:55
Best SPL system panky12345 In-Car Entertainment 37 29th October 2008 00:34
Pioneer SPL subwoofer for sale low_bass_makker Shifting gears 15 27th December 2006 20:07
