Old 9th January 2008, 02:29   #256
vebmetal's Avatar
Thanked: 15 Times
slightly OT, but from what you say, can one infer that a HU with R-Type components (no amp) in the front would give a nice tight enough sound to say avoid the need for a subwoofer, for a self-driven car? (keeping in mind that I am not too picky about music, but just need a wholesome sound?)
If not, what about with an amp?
vebmetal is offline   Reply With Quote
Old 9th January 2008, 02:58   #257
nice stuff there Amit, be careful when you give your car for wash & servicing. do not let them open the doors during the wash. i'll suggest you clean the interiors yourself.
As they say - With great powers, come great resposibilities.
One question, how much damping did you use? what brand is it? didn't you put any on the plastic door panels? and how much did it cost?
saintsinner is offline   Reply With Quote
Old 9th January 2008, 03:03   #258
amit_sound's Avatar
Components are supposed to divide the sound type like highs, mids and lows.
An speaker will start sound sweet for iteself, only when good amplification is supplied to it. More the power, clearer the sound.
Since the components are supposed to be for high sound quality, it would be injustice done to them if amplifier is not used.
Get a 2-ch amp anf use it to power the front components, and power the rear speakers from the headunit it self. It'll be worth the money put in.
Advice: Use amp with components ELSE buy simple 4",5" round speakers if u dont intent to buy a amp.
amit_sound is offline   Reply With Quote
Old 9th January 2008, 03:06   #259
amit_sound's Avatar
Nice advice
Brand....was send to FM Drive by Ajay bhai. Cost, amount of damping, will all be calculated on the final day.
Let HOPE i ge good power out of these.....i promise i'll be responsible. EispiderMan!!!
Old 9th January 2008, 11:48   #260
Thanked: 294 Times
Nice work progress. Will be waiting for the final pics.
Old 9th January 2008, 13:04   #261
Bass&Trouble's Avatar
Thanked: 71 Times
Thats what I was talking to Pankaj Bhai, while single layers will be fine for the doors, you might have to use a little more than "normal" people for the trunk. I'm sure parts of it must be already rattling due to the JBL 15s induced molestation and now its going to be sheer, er.. sodomy.
Old 9th January 2008, 21:44   #262
nitinralli's Avatar
Thanked: 797 Times
Hi Amit,
one small advice needed, as u sd that u need amp for the comp's, can it be used with a 4-ch amp? I have a 4-ch amp which is running my rear speakes and a woofer. Can i power the comp's and the woofer with the 4-ch amp, and rear coax with the HU???
nitinralli is online now   Reply With Quote
Old 9th January 2008, 23:50   #263
amit_sound's Avatar
Originally Posted by nitinralli View Post
Hi Amit,
if fact now if u install a component you will have a very good setup. Yes your 4 ch amp is perfect for the comps.
Which amp you have?
Do this, power your front component and woofer by the 4 ch amp. Run the rear speakers off the head-unit. I bet, you'll be satisfied.
Old 9th January 2008, 23:57   #264
amit_sound's Avatar
Yes Ajay, in fact i guess Pankaj bhai is already in a mood to do a double layer for the boot.
Arey serious yaar....i still dont know why i sold the GT4-15. I mean today also if I think, i was very very satisfied with the setup. You say thoda....i'd say those JBLs have troubled my car a lot. Had a lot of air gaps formed due to it. Air gaps were noticible, when driving above 120.
Now....fingers crossed!! I just hope they sound the way i am expecting. Since it gonna be done tomorrow..... i am dropping all the over expectations. I am really nervous.
Old 10th January 2008, 00:09   #265
Thanked: 294 Times
Best of luck man. But don`t expect them to perform the very first day. The subs will take few days to break in and perform to the max
Old 10th January 2008, 01:24   #266
Thanked: 71 Times
Better get used to it. The DDs will surely take the "gaps" to an advanced level.
I don't think there's anything to worry about. The car is in safe hands, and DD will sure as hell kick some ***!
Old 10th January 2008, 20:49   #267
nitinralli's Avatar
Thanked: 797 Times
Which amp you have?
Thanks for the reply amit. Well i have a sony expolde amp (i think its 552).
One more thing, if i install comp's in my car (fiesta) in the door panels, where the original front speakers are, wont it make cranking sounds when listening on high volums?? Will i need to go for damping and stuff, cause i really dont want to go for it as my car is only 1 year old . Also can u suggest any good, but not very expensive comps? I was thinking of changing my rear speakers cause they have gone old now, so should i go for JBL937 or any other good speakers.
I know i am asking tooooo many questions, but would really appericate ur help in my car setup
Old 11th January 2008, 10:24   #268
amit_sound's Avatar
For 4 ch amp, you could look at JBL CS series, also check out the prices for the new JBL GT5 series. Poineer 4 ch amps sould also be in budget.
Damping...yes, the Apline R Types installed in the front (my car) has a lot of thump. Going without damping would give a lot of vibrations and unwanted noise. Do ont thing, install the speakers and check, if you feel you need to go for damping, then do that.
JBL 937 is a goof VFM stuff. Infact i am selling mine as i have installed all four components
Old 11th January 2008, 10:26   #269
amit_sound's Avatar
Guys, kafi kaam ho gaya.....but woofer were not put in the car yest as we were out of good speaker wirings. So Pankaj, was not in a mood to compromise on the setup and suggested that we wait for today.
Rest, all is done......will upload the imgaes today some time.
Old 12th January 2008, 15:42   #270
amit_sound's Avatar
Done..... Its installed and sounding. Its got thump. Sounds preety neet for a 12" woofer.
Pics shall be uploaded soon as i forgot the data cable of cam at home. Waiting fir the coils to open a bit.
Finally DD is in, and moving out air of the car.
Good SPL Sound Jas6789 In-Car Entertainment 34 30th May 2011 22:15
New Products for 2006 - Stuff to look out for gunbir In-Car Entertainment 131 1st February 2010 19:55
Best SPL system panky12345 In-Car Entertainment 37 29th October 2008 00:34
Pioneer SPL subwoofer for sale low_bass_makker Shifting gears 15 27th December 2006 20:07
