Old 9th May 2008, 10:27   #256
Thanked: 83 Times
I am sure he meant 'have to'. Now the mods have to either reprimand him for using SMS language or edit his post.
SumitB is offline   Reply With Quote
Old 9th May 2008, 13:03   #257
manson's Avatar
Thanked: 2,230 Times
Originally Posted by DerAlte View Post
You have to pay hafta for the accessories? Times have surely changed!!!
The hafta(') was intentional, doesn't hurt once in a few hundred posts
The accessories will hafta' wait till sunday, just not going to be free before that.
And, i indeed hafta' pay for the accessories, the installer does not distribute them free anymore
Could you please post the individual prices?
Sure!
Pioneer 4050 DVD HU - 10,600
Necvox 9" roof mounted LCD Screen - 7,500
JBL 607 2 way Components in the front - 3,800
JBL 607 2 way Components in the rear - 3,800
JBL 604 4 channel Amplifier to fire the two pairs of components - 5,000
Magnat Express 15" subwoofer at the rear in a sealed enclosure (From my Honda)
Sony 222 2 channel amplifier to power the Magnat subwoofer (Had this lying idle)
Wires & Cables - 1,800 (i think)
Installation - 1,000
I had quite a while with the system this morning while en route to work, it sounded nice. I did not play it loud though, was mostly at volume 3. I raised it a little for a track or two, and i think sub could do with a bigger better amplifier.
manson.
manson is offline   Reply With Quote
Old 9th May 2008, 16:01   #258
Originally Posted by manson View Post
Duplicate from my Innova review thread:
With a 50K budget:
Get the Illusion Electra Component speakers (12K for 2 pairs)
JBL 604 4 channel amplifier to power the components (8K with B&W)
Pioneer 4050 HU single din (like mine) i think that a screen upfront could distract the driver (11K without B&W)
9" or 10" Necvox screen, as per needs, avoid the Chinese stuff (8K for 9" without B&W)
Spend the remaining 10K on a decent 2 channel amplifier, subwoofer, wires and installation charges. If you could increase this by another 5k, you could add some much needed damping and probably get a better subwoofer too.
Let us know what you decide upon.
manson.
Thanks Manson, for your recommendation I will be definitely ewvaluating that. I was looking around on the threads and here are some of the other setups that I could pick up for an Innova. Some of these might be old, so I would like to know what are the better options/models for similar setups.
I have also found out that Sprocket seems to be the best installer option in Hyderbad, Hyderabadi TBhpians am I right?
Also for the in dash DVD it's more for my wife who would be accompanying me in the passenger seat rather than for me. But looks like I might not be able to fit it into the budget.
Appreciate all your inputs and suggestions. Thanks
Setup 1
1> JVC HU JVC Mobile Entertainment \ Model KW-AVX800
2> Front Speakers - JL Audio (6.5" Components)
3> Rear Speakers - JL Audio (6.5" Components)
4> Screen - Necvox 9.2" Roof Mount ( not sure of putting this )
5> Woofer - JBL OR JL Audio-please suggest which is better
6> Amp for speakers - 4ch amp JBL
7> Amp for Woofer - 2ch amp
Setup 2
HU - Pioneer DEH7950UB
Fronts : - Illusion Electra 6.1 6.5 2 way components
Rears : - Illusion Electra 6.1 6.5 2 way components
Amp - JBL GT5 - A604, 4 Channel Amplifier
4 Speaker Mounting Ring for each door
Ichibahn Audio Interconnect RCA Cable Street Series 20ft
GZPK10 Power Wiring Kit
2 x Illusion Reference Series 16AWG Speaker Cable
Noise Kill 17sq.ft for all four doors.
Wiring Harness to connect HU
Setup 3
1> HU - Sony MEX R1
2> Front Speakers - Kicker ES 6.2 (6.5" Components)
3> Rear Speakers - Kicker ES 6.2 (6.5" Components)
5> Woofer - Kicker 12" - ES 124 fitted in a box
6> Amp for speakers - Kenwood 8401 (60 x 4 WRMS)
7> Amp for Woofer - Sound Stream 240.2 - (60 x 2 WRMS)
8> Wiring - Kicker Amplifier wiring kit.
YouMah is offline   Reply With Quote
Old 9th May 2008, 19:03   #259
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by YouMah View Post
... Appreciate all your inputs and suggestions. Thanks
Setup 1
Perhaps you could consider each item separately so that there is an apples to apples comparison? It is always better that way, and you should make it a point to actually listen to the things you are considering for buying, rather than only going by what others have implemented (as your lists suggest).
1. HU: Pioneer, JVC, Kenwood, Blaupunkt
2. Front components: JBL, Infinity, Hertz, Blaupunkt, Illusion (JL Audio, Kicker, Polk etc. are unlikely to be VFM the way the others are)
3. Rear speakers - need not be components. These can be coaxials of the same brand as the front ones
4. LCD Screen - can be mounted by replacing the center cabin light (usually the screens come with built-in light); you could alternately consider LCD monitors behind the front head-rests
5. Amp and woofer: unless you really really need them, you could keep these as future additions
You have not mentioned a budget, by the way!
Old 9th May 2008, 19:10   #260
Akshay1234's Avatar
Thanked: 7,242 Times
yes he has. lol. its 50k.
Old 9th May 2008, 19:12   #261
Bass&Trouble's Avatar
Thanked: 71 Times
I am not familar with many outlets in Hyderabad, but Sprocket sure is very good for installs.
Old 9th May 2008, 22:01   #262
manson's Avatar
Nope, you do not need to replace the cabin light. My installer has mounted it cleanly, very cleanly just before the cabin light assembly. This way, its at a reaonable distance from the passengers, and the front row has hardly any access to the screen.
A roof mounted screen is a better option than having two individual screens embedded in the headrests. A roof mounted screen is quite convenient for the third row too.
manson.
Old 9th May 2008, 23:08   #263
navin's Avatar
Thanked: 4,284 Times
Setup 1
1> JVC - JL Audio - JBL
2> Pioneer - Illusion Electra - JBL
3> Sony - Kicker ES - Kenwood 8401 /Sound Stream
Let see we have 50K....
40K once we damp the doors and get 3 pairs of good RCA wire.
HU 15K JVC AVX11 (it has 3 pre outs and ipod in but no USB)
Speakers 15K JBL/Blaupunkt/etc.. - 6K for sub, 6K for compnents, 3K for coax
Amp 15K 4 ch amp for 7K + monoblock for 8K (JBL, Pioneer, Blau, Kenwood)
NecVox Screen 5K
total 60K. we are a bit over budget but you got DVD.
Old 10th May 2008, 00:03   #264
I really would like to do that, but apart from COAXs setup for demo really not able to find any place/people here in Hyderabad where I could listen to different setups.
manson.
The current roof mounted screen(some chineese build) is setup that way. Will be changing that with a NecVox screen.
NecVox Screen 5K
Thanks Navinji for the setup. the AVX11 sure fits the bill and the budget.
Visited Sprocket today and got an initial configuration, in a bit of an hurry so will be getting the install done today morning. Will be providing the details in the next and looking forward to inputs and suggestions.
Old 10th May 2008, 01:02   #265
Default Suggestions required for finalizing my setup
Visited Sprocket today and here is an initial setup that's about 70% final. Budget has pretty much gone for a toss with this, so would need some inputs on pricing and also the choice of different elements in the setup
Speakers
Front - JBL 607c - Rs 6500
Rear - JBL 607c - Rs 6500
4 Channel Amp
JBL GTO4060 (60th Anniversary Edition) - 10990 (Haven't read a lot about this in the forum)
JBL 1004 - 14990 (Is this really required or 4060 will do?)
Subwoofer and Monoblock(Haven't really decided on this, will listen to it and then make a decision, Inputs are welcome)
JBL 1204BR - Rs 12990 (How different would this be from 1204B Which is around 7990 will hopefully get to listen to them both before actually making a choice)
Sprocket is pushing a Panasonic Monoblock that's costing around 10990, but I am not comfortable with that. Will be looking to go with either the JBL 300.1 or any other suggestions from the gurus.
Headunit
Will go with Navinji's suggestion - JVC AVX11 if it is available here. Will also be looking at other options.
Other elements of the configuration
Damping - Wurth - Rs 4000 for all 4 doors (Is this reasonable)
Distributor - Rs 1300
RCA Cables 3 - Don't know the brand Rs 2700 (Please suggest something specific)
Wiring Monster - 2800
Installation - 1200
Total comes to around Rs 59970 with the Panasonic Monoblock Amp and 1204BR sub. Sprocket is giving a 12% discount(Thanks to Team BHP) on that and it works out to about 52500. This is without the HU and I guess the HU would be around 15K and the Roof Mount around 5-8K. This will shoot up the budget by 35% so will be looking for suggestions to cut this down.
I understand that this might not be the best way of doing this...without listening to all the equipment, but don't seem to have a lot of options unless I travel out of Hyderabad.
Hoping to get some inputs from the insomniacs/early birds before I take the plunge in the morning.
YouMah
Old 10th May 2008, 10:22   #266
navin's Avatar
JBL 1004
JBL 1204BR
JBL GT5 components (speakers, amp and sub) instead of GTO will save you about 15K.
For he monoblokc the Pio 6300M, JBL GT5, and Kenwood 9xx1 are options. I dont think the Pio D510 is available anymore. But try and get one of these for under 10K. Blau also makes a GT4 monoblock and that might be the cheapest option (8-9K?).
Old 9th January 2009, 15:24   #267
btirthankar's Avatar
Thanked: 115 Times
Default Reversi
Just wanted to share that having the Sub fitted like this made it sound better.
Thats not Isobaric BTW
btirthankar is offline   Reply With Quote
Old 10th January 2009, 10:24   #268
navin's Avatar
If you use the same box the net volume in the box would have increased substantially when you turned the sub inside out.
Old 10th January 2009, 12:08   #269
Akshay1234's Avatar
in what way does it sound better? is it louder?
Old 10th January 2009, 17:41   #270
Thanked: 115 Times
Default Looks radical but, I recommend this to everyone.
Yes this is the third day and It sounds much better in terms of increased range. (Now the RVM vibrates more)
Actually I realised, it did not matter anything for the woofer as instead of pushing it was pulling now with the bulk of itself placed outwards. (I did reverse the polarity)
Replacing our 2 lakh km Innova - Toyota Innova Crysta vs Ford Endeavour icyspikey SUVs, MUVs & 4x4s 31 16th May 2017 18:48
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
Innova'tive Interiors :D (My Mica Grey Innova with Refreshed Interiors) Bhushanrulz Test-Drives & Initial Ownership Reports 45 26th July 2011 00:48
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
Budget ICE for INNOVA sudheerys In-Car Entertainment 17 20th October 2006 10:14
